Nice hot weekend coming up (over 101 F) and I got a few Bonnie projects I need to do ie. new inline gas filter and football grips (providing they arrive).
I've been talking to some HD gearheads here at the plant about my 5250 RPM horsepower and torque dip and how I would like to smooth that out as best as possible before attempting to get another dyno run.
They suggested that I get the bike up to 5250 RPM or there abouts, shut the engine off coast to a stop and inspect the plugs. Adjust shims on the needle as required until the plugs look like the bike is running too rich and then shim down a bit. Sounds logical to me realizing though that "sparkplug diagnostics" are still a guessing game, but what do you Triumph Gearheads think? Thanks in advance for your thoughts.
That is the way tuners did it before the advent of O2 sensors and dynos ........It is harder to read the plugs than you might think
......Here is another trick,,,,,, if you have access to the air inlet of the carbs you can slide a blocking plate accross the Inlet slowly at the desired rpm range and feel for the engine to change as it goes rich....This is hard to do at speed and isn't all that safe to be reaching down and taking your attention off the roadway......This is more of a track only method.....
What I do is the stopwatch method.... I find a fairly level "test & Tune" section of road far away from traffic and intersections. Then I stick the bike in one gear (higher the better) and I sweep the rpm from 4 K to 6K while WFO and click the watch on at 4.5K and off at 5.5K...... Any change becomes quite clear .
Does around where you live have a dyno? If they do reasonably priced runs, it may be worth just taking it over to them and let em have at it, but do the work yourself as thats where it will kill you, with the labor, if they start getting into it like that!
Thanks for your input sofar.
Motorboy...blocking the air is a little too risky for me, but I've tried pulling the choke at 5250 to see if that made any difference (I couldn't tell). I do plan on doing it with new plugs though.
Cobra...going rate for dyno runs are between $45-60 here in Dallas. I just paid $60 a few weeks ago and have doubts about the results (my air/fuel ratio did a perfect flatline at 13.7 with max hp at 57.3 and torque at 46.6). I'm planning on going to another dealer for a second opinion but feel that I'm still a little on the lean side. Full blown dynos with assistance from them are about $230 a pop, but it's hard to find someone with carb experience...everybody is an EXPERT with EFI though :-D . Hard to believe for a place as big as this town, you'd think there would be more options.
Here's what I'm trying to smooth-out (click on dyno graph). The flatline on the ratio makes me think that the sensors might have been clogged.
As you can see, Torque takes off like a SOB but maxes at about 3500 RPM, drops and settles at about 42 ft/lbs to the rev limiter. Power gradually increases to the dip and then takes off, That's why I'm thinking that my pilots (42) and mains (120) are doing their job and more needle work is required (they're Thruxton needles w.1-shim).
Shorty
[ This message was edited by: Shorty on 2006-07-13 11:10 ]
monkeyboy...airbox is modified with snorkel and restrictor plate removed, polaris bellmouth installed and a unifilter. Freeflowing Sprint teardrop pipes (similar to NH Toga's).
Can't tell any difference by riding the bike and even the Dyno Technician mentioned that he couldn't tell and was quite surprised by the graph readings. Also at the time of the dyno run I had 125 Mains installed which I've since then dropped to 120's to see if it makes a difference (over the months of trial and error I've decreased the Mains from 140 by "5's" at a time to the present setup. Above 130's I couldn't hit the revlimit in 4th and barely made it in 3rd before running out of road. Now I'll hit it every time PDQ. I knew I was running too rich before for sure.
Thanks for the reply and input. I'm pretty much set up like the Jenk's bolts suggestions with similar modifications.
The "restrictor plate" is a plenum divider. I suppose it does restrict airflow a bit, but it enhances intake velocity. This fast airflow smooths the transitions between slide positions. Our carbs are designed to work with constant vacuum (thus the CV in the name). The slide moves in reaction to pressure differentials. When the airbox is eliminated or modified, the carbs suddenly have to deal with far less vacuum than the Triumph engineers calibrated it for. When the air velocity does catch up and starts raising the slide, it does so with a vengeance and the venturi momentarily opens too quickly. Thus the power dip. Some riders who have removed the airbox or the "restrictor" have had luck opening up the bleed hole on the slide. This allows a smoother opening of the slide when higher volumes of air (vs high velocity air) are entering the carb mouth. This is a more desireable solution because, as someone stated earlier: the dyno run is conducted with the throttle wide open. If the needles or any of the intermediate circuits are altered to deal with the power dip, performance will suffer at partially open throttle settings.
From the dyno runs I've seen on the net on the 790, both stock and modified, it seems to me like the midrange dip is inherent in the 790 by bore/stroke/cam configuration etc, and not easily remedied by jetting changes alone.
I think this is one of the reasons for the 865cc engine. Milder cams, roughly the same top end power, smoother power band.
Great input folks, gives me a couple more things to verify before taking the bike for another dyno run.
Sheepdog...I did drill out the slide (forgot to mention it) but didn't quite go the full 3.0 as specified in the jenks procedures due to not wanting to screw it up. I split the difference at 2.75 mm and am now wondering if I should just go the full 3 mm?
Before I do that though I think I'll get another run scheduled as monkeyboy suggested because as I've stated before I'm not convinced that the dyno worked properly (I would expect the air/fuel ratio graph to deviate at least somewhat with peaks and valleys and not flatline over the complete run). This is the first time I ever had one of my bikes dyno'd and I confess that I really don't know what I should be looking for.
Like ivar said, maybe that's just the nature of the beast with the 790 engine and unrestricted airflow.
Thanks again to all.
Yup ! if the mixture is aok thru the "dip",,,, then it is resonance in the intake/exhaust systems and that is inherent and is only affected by changing parts and lengths and volumes......In the "sportbikes" they sometimes have an exhaust butterfly valve computer controlled in order to minimize these effects....Perfectly normal......
Related Threads
Triumph Rat Motorcycle Forums
3.9M posts
167.7K members
Since 2002
