T100 Spark plug removal and reinstall - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 8 (permalink) Old 10-25-2013, 06:37 PM Thread Starter
Newbie
Main Motorcycle: Bonneville
I'm a novice with maintenance and about to put my 2012 Bonneville T100 in storage for about 4 months or so. The owner's manual says to remove the spark plugs and pour some oil into the cylinders, but it doesn't tell you how to remove them or how to reinstall them. I'll be honest - I'm not even sure I've located the spark plug location correctly. So, if anyone out there could give me some guidance on this process, it'd be much appreciated. Thanks!
df1524 is offline
post #2 of 8 (permalink) Old 10-25-2013, 06:50 PM
mik
Main Motorcycle: My 2012 Bonneville
Send a message via AIM to mik
If your really want to do it, the plugs are behind the SAI pipes.....you need a thin socket or you have to lift the tank.
mik is offline
post #3 of 8 (permalink) Old 10-25-2013, 08:11 PM
Main Motorcycle: 2007 bonnie black
killian101's Avatar
Other Motorcycle: 68 BSA (RIP)
Extra Motorcycle: 2015 Daytona
Since your AI is still intact, might be easier to remove the tank. Craftsmen sells a thin walled 18mm deep socket.
-paul
killian101 is offline
post #4 of 8 (permalink) Old 10-26-2013, 02:05 AM
Forchetto's Avatar
Tank removal on EFI models like yours is rather more involed that on carbed ones. This link takes you to a post with details, including a video:
http://www.triumphrat.net/twins-tech...ml#post2579926
Easier to remove the plugs, Clean out the space around the plug as dirt tends to collect in there and could fall inside the cylinder. Compressed air is best, but a paint brush and small vacuum cleaner nozzle helps.
Obtain an 18 mm thin wall (very important) tube or box wrench. This will seem too long but there's room under the tank just above the plugs to insert the wrench upwards and then lower it above the plug.
Use a bar or screwdriver as a tommy bar to undo plug.
To replace, although the plug manufacturer (NGK) gives a torque setting they realise that in a lot of vehicles you can't get a torque wrench in there.
They advise that in the case of our 12mm-thread plugs, that you bottom them by hand and then turn the wrench a further 1/12th of a turn (about 30 degrees of rotation).
That's in the case of used plugs. For new ones with uncrushed sealing washer they advise rotation by 1/2 turn (180 degrees).
Obtain a suitable wrench like this:
Or this:
Forchetto is offline
post #5 of 8 (permalink) Old 10-26-2013, 10:21 AM
Main Motorcycle: 203 T100
Other Motorcycle: 1968 Truimph Daytona
Extra Motorcycle: 2006 Ducati Multistrada
If you're only going to store it for four months, oil in the cylinders is overkill. I would do it if I was going to store it for a year, though.
Hard work may pay off some day, but laziness always pays off right now.
Bill
View my photo album
billstokes is offline
post #6 of 8 (permalink) Old 10-26-2013, 10:35 AM
Main Motorcycle: Yes
B02S4's Avatar
If you appreciate a high quality tool (and who doesn't ) then the Motion Pro plug wrench for the Honda XR400 works very well with Hinckley twins. Here is one source: http://www.ebay.com/itm/Motion-Pro-1...-/270922210736
B02S4 is offline
post #7 of 8 (permalink) Old 10-26-2013, 11:38 AM
I wouldn't bother doing it for just the winter, especially if the AI is in the way.
A Craftsman 18mm spark plug socket will fit.
Marty
Baltobonneville is offline
post #8 of 8 (permalink) Old 10-27-2013, 06:51 PM Thread Starter
Newbie
Great! Thanks so much, everyone.
df1524 is offline
Spark Plug removal gcoll T3 Sport / Touring Forum 2 12-31-2011 01:49 PM
Spark plug removal Steiny Speed Triple Forum 7 06-18-2011 03:16 AM
Spark Plug Removal SoCalNewbie Air Cooled Twins Technical Talk 6 08-02-2007 12:29 PM
Spark Plug Removal wenzel850 Air Cooled Twins Talk 7 01-04-2006 09:15 PM
spark plug removal cameracsc Air Cooled Twins Talk 7 08-02-2005 09:31 PM
