Valve cover bolts stripped - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 20 (permalink) Old 07-01-2013, 07:36 AM Thread Starter
Main Motorcycle: 2001 Triumph Bonneville
Tomjukic's Avatar
Damn!!
I was replacing the gasket and washers on my 2001 Bonneville valve cover as it has developed a leak after all these years. Anyway as I was torquing down the bolts to 10nm as stated in my Haynes manual, alternating R front, L back, L front, R back gradually getting tighter I felt L back strip.(insert expletives here)
What are my options from here?
Will it still be okay to ride with the other 3 bolts torqued down?
I have never applied a heli coil which is what I presume will be my best option, is it difficult? And will it be more or less reliable than the original useless threads?
Thanks in advance
Tom.
Sent from Motorcycle.com Free App
Tomjukic is offline
post #2 of 20 (permalink) Old 07-01-2013, 07:40 AM
Main Motorcycle: '06 Triumph Bonneville
P-twin's Avatar
Location: West of the east coast & east of the west coast
The torque setting for the cam cover was changed to 14Nm. I would bet money that the cover is going to weep on you even with three torqued down and one on the loose side. Do you have an impact wrench you can use with a heat gun? Get it loose and you can always order a new set of cam cover bolts...is the head on the cam cover bolt that stripped or the thread going into the cam holder?
P-twin is offline
post #3 of 20 (permalink) Old 07-01-2013, 11:16 AM
Motorcyclist
Supernova
Main Motorcycle: 2013 Tiger 800XC
propforward's Avatar
Other Motorcycle: 2007 Bonneville, ST1300
Extra Motorcycle: G12DL, ZX1100, KLX400
Helicoil repair is a very good way to fix the stripped thread in those caps. It will actually result in a stronger thread (when done properly) than the original thread.
It is not hard to do. Using a drill press is best to make sure that you get the new thread square. You have to lightly drill out the old thread. Then use the drill press to hold the tap for the repair, and turn the chuck by hand to start cutting the thread on the cap. Then you can take the tap out and finish by hand - this way the thread is square.
Before he did it, I'd have said it couldn't be done.
propforward is online now
post #4 of 20 (permalink) Old 07-01-2013, 02:25 PM
Forchetto's Avatar
Good Helicoil repair thread here:
http://www.triumphrat.net/twins-tech...p-threads.html
Forchetto is offline
post #5 of 20 (permalink) Old 07-01-2013, 05:27 PM Thread Starter
Tomjukic's Avatar
Thanks, I went for a short ride to work this morning and so far no leak, but I would like to get it fixed properly. I will have to get me a helicoil kit.
Is there really no way to replace the cam holder bracket without replacing the whole cylinder head? Surely one of the CNC guru's could make something like that, or is there more to it?
Tomjukic is offline
post #6 of 20 (permalink) Old 07-01-2013, 05:51 PM
Motorcyclist
Supernova
What do you mean by the cam holder bracket?
post #7 of 20 (permalink) Old 07-01-2013, 06:45 PM Thread Starter
Tomjukic's Avatar
I meant the cam cap, this thing;
Couldn't think of the name
Tomjukic is offline
post #8 of 20 (permalink) Old 07-01-2013, 06:49 PM Thread Starter
Tomjukic's Avatar
Unfortunately it's the cam holder thread.
Tomjukic is offline
post #9 of 20 (permalink) Old 07-01-2013, 07:10 PM
P-twin's Avatar
Attachment 70482
On that holder there are three sets of threads...two on each side and the one in the middle. It is the one in the middle that stripped on you correct? If that is the case then I would definitely get it helicoiled...I think that is your best option. Keep in mind the center thread on that holder is for the cam cover bolt to thread into. You could even ride it into a garage if you are not comfortable doing the job yourself but I think you will be fine. Put in helicoil on youtube and you will get full blown demonstrations on how to do it.
P-twin is offline
post #10 of 20 (permalink) Old 07-01-2013, 08:34 PM
Motorcyclist
Supernova
Ah, yes. Well those are machined while bolted to the cylinder head. So it would not be impossible to make a replacement one, but would be very difficult to get the camshaft journal accurate and matched - not impossible, but difficult.
But really, just helicoil the thread. The helicoil will actually be stronger than the original thread, it is a very good repair.
How to: Repairing stripped Valve Cover/Cam Cap threads sweatmachine Air Cooled Twins Technical Talk 16 11-12-2014 04:14 PM
head bolts stripped adam13 Classic, Vintage & Veteran 22 04-11-2010 07:59 AM
Loctite the valve cover bolts? radix99 Sprint Forum 2 05-28-2009 03:12 PM
stripped valve cover thread guitarsavior T3 Sport / Touring Forum 3 04-27-2009 01:44 AM
Valve cover bolts jttrout Air Cooled Twins Technical Talk 10 06-14-2007 10:42 PM
