Bonnie Died Whilst Idling - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 10 (permalink) Old 12-26-2012, 08:13 PM Thread Starter
Main Motorcycle: 2010 Bonneville
So a quick one for the xmas holidays. My bonnie died whilst idling. I'm not too worried as it is a one off so far.
I was moving it on my drive (slight incline) and fiddling with the steering lock as I'm leaving her for a couple of days.
Anyway, I was off the bike whilst it was idling (max 5 min). The kick stand was down, I didn't touch any switches and I doubt it wan't running very hot. It just died, no chuggers, no dramas.
It has a full tank, I haven't fiddled with anything recently, just ran some carb cleaner through the tank.
Any ideas?
Mr*Beaver is offline
post #2 of 10 (permalink) Old 12-26-2012, 08:34 PM
Main Motorcycle: Bonneville
Other Motorcycle: Honda Postie
Extra Motorcycle: Suzuki DL650 V Strom
Hello
Did it start again? Was it fully warmed up? Was the "choke" on? What is the idle set at? Need a bit more detail to diagnose.
Tasmaniablue is offline
post #3 of 10 (permalink) Old 12-26-2012, 09:37 PM Thread Starter
It started fine straight after, temp is around 30 degrees at the time so the engine is never truly cold cold but it was running for about 3 min after it died. The choke was off - never had to use this and unsure on idle setting, it doesn't have a tachometer so am unsure on revs, but again I haven't adjusted this.
post #4 of 10 (permalink) Old 12-26-2012, 09:48 PM
Hello
Sounds like a one off that should not give rise to concern. Idle may be set a little low, try increasing it a nudge. I do not think that you have a real problem but keep us informed...........good luck.
post #5 of 10 (permalink) Old 12-27-2012, 07:41 AM
Main Motorcycle: 04 T100 blue/white (his)
Wooly's Avatar
Other Motorcycle: 07 T100 red/black (hers)
Extra Motorcycle: 1971 Yamaha DT2 250
Assume the fuel tap was set to on??
Sorry - had to suggest it, mine will idle for about 5 minutes only if I forget to switch it on,
Phil.
Wooly is offline
post #6 of 10 (permalink) Old 12-27-2012, 09:49 AM
Main Motorcycle: 06 scrambler
Other Motorcycle: 05 Weestrom
Extra Motorcycle: 70 norton commando
Carb heater not working (icing) it thaws out after it quit .
Gonzo 61 is offline
post #7 of 10 (permalink) Old 12-27-2012, 02:16 PM
Main Motorcycle: Triumph Thunderbird Sport
BIKERPIPER's Avatar
Other Motorcycle: bonnie t100
dont change the idle till shes fully warmed up.Otherwise she will run like a demented rabid dog when warmed up...)))
bikerpiper irish by birth cork by the grace of god
BIKERPIPER is offline
post #8 of 10 (permalink) Old 12-27-2012, 04:59 PM Thread Starter
@Wooly - no fuel tap on my model
@Gonzo 61 - we don't get ice in Aus ;p it's roasting over here
@BIKERPIPER - thats some good advice, I will look at the idle screw at some point although it will have to wait a couple of weeks
post #9 of 10 (permalink) Old 12-27-2012, 06:25 PM
Forchetto's Avatar
A few reasons for cutting out at idle on EFI models:
Low idle speed, set to 950-1050 rpm when engine is hot.
Throttle bodies out of balance
Low fuel pressure caused by loose fuel pipes to the fuel pump and filter
Low fuel pressure due to faulty pump, regulator or fuel filter blockage
Weak mixture caused by air leak at manifold to cylinder head face
Forchetto is offline
post #10 of 10 (permalink) Old 12-28-2012, 07:38 AM
Oops my bad! I should have looked closer, your 30c isn't our 30f.
Gonzo 61 is offline
Bike died while idling and not able to start again. xanth Street Triple Forum 9 05-22-2012 11:41 PM
HELP - Bonnie Died! gusman Air Cooled Twins Technical Talk 10 08-24-2007 03:29 AM
HELP! Bonnie died in the middle of nowhere! bobmig Air Cooled Twins Technical Talk 3 08-14-2007 09:25 PM
Bonnie died, then lived again. Eastside Air Cooled Twins Technical Talk 6 06-06-2007 11:04 AM
New Bonnie died MotoSayle Air Cooled Twins Talk 5 08-26-2005 04:31 PM
