Installed HID kit on the Scrambler. - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
post #1 of 16 (permalink) Old 12-13-2012, 02:03 AM Thread Starter
Main Motorcycle: 2012 Scrambler
Luxlamf's Avatar
Other Motorcycle: 2002 VROD
Replaced the stock bulb set up with an 8000k HID kit from DDM Tuning, Did it to my other bike and the difference is amazing from stock and crappy Auto Parts store bulbs.
1st since I hit my 1st 1000 miles on the bike (in 2 weeks time) I decided to wash it
Tore off the tank to run the wire through there cleanly, and the Ballast fits nicely inside the headlamp housing. Best $43 I have spent.
Hi
Lo
ID:	57970   Click image for larger version
ID:	57971   Click image for larger version
ID:	57972   Click image for larger version
Luxlamf is online now
post #2 of 16 (permalink) Old 05-22-2014, 09:37 PM
Av8rPaul's Avatar
Other Motorcycle: 2011 Harley FLHX
I happened on this older thread a couple days ago and immediately ordered 5000K kit for my Scrambler. I had a dark ride on Hwy from Lodi to Fairfield, CA a few weeks ago and it is Dee double DARK out there, really emphasizing I needed to get some more candles burning.
So dang near 2 1/2 years later I say THANKS!
IBA #33
Av8rPaul is offline
post #3 of 16 (permalink) Old 05-23-2014, 02:04 AM
Main Motorcycle: 13' Thruxton
Awesome, what kit did you order?
Sent from Motorcycle.com Free App
CMoore is offline
post #4 of 16 (permalink) Old 05-23-2014, 03:23 AM Thread Starter
Luxlamf's Avatar
It really is one of the best mods I have done, last week my brother came to town and we rode up to San Fran he on the Triumph and I could always find him in my mirrors no matter how far he was behind me due to brightness and the blue tint my 8000 bulb has. Had a small problem with my set up and DDM took care of replacing the parts ASAP
post #5 of 16 (permalink) Old 05-23-2014, 06:45 AM
Main Motorcycle: 2010 Bonneville
I was going to do this last month, however it was suggested not a good idea. Due to the type of light etc, the throw could be all over the place. Can you snap a photo the other way showing the beam?
Mr*Beaver is offline
post #6 of 16 (permalink) Old 05-23-2014, 09:48 AM
Av8rPaul's Avatar
I ordered the 35w 5000K kit.
http://www.ddmtuning.com/Products/HI...rcycle-HID-Kit
IBA #33
Av8rPaul is offline
post #7 of 16 (permalink) Old 05-23-2014, 11:18 AM
Main Motorcycle: 2013 Triumph Scrambler
Other Motorcycle: 2013 KTM 500 EXC
Checking this out also, as the standard lighting on this bike leaves alot to be desired.
A couple of questions
Which bulb is compatible?
Do I need the mounting brackets as well?
hbmichael is offline
post #8 of 16 (permalink) Old 05-23-2014, 11:33 AM
Av8rPaul's Avatar
It's an H4 bulb. I have the mounting bracket coming with mine, right now I have no idea if I'll use it.
IBA #33
Av8rPaul is offline
post #9 of 16 (permalink) Old 05-23-2014, 12:30 PM
Thanks Paul!
post #10 of 16 (permalink) Old 05-24-2014, 12:44 AM Thread Starter
Luxlamf's Avatar
The wiring harness comes doubled up, comes with a long lead and a short, you just cut the short one off, I ran the wire to the battery along the frame secured with zip ties with tank removed and everything else fit in the bucket, takes a little maneuvering but works fine. The ballast will plug directly into your existing light bulb socket and your new HID bulb plugs into your new wiring harness with 3 wires.
How I installed a Scottoiler on my Scrambler. xmastree Air Cooled Twins Technical Talk 14 07-15-2014 03:17 AM
2mm oversize valves installed into EFI Scrambler. Aussiebikerdave Air Cooled Twins Technical Talk 20 07-05-2010 06:17 PM
Scrambler solo seat and rack on bonne, installed. 2112 Air Cooled Twins Technical Talk 28 10-01-2007 01:58 PM
Installed Air Box Elimination Kit on Scrambler Sid Air Cooled Twins Technical Talk 3 09-29-2006 12:32 PM
