Removing Rear Wheel Nut - What Size? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 12 (permalink) Old 12-12-2012, 02:52 AM Thread Starter
Main Motorcycle: '11 Speed Triple
Moogs's Avatar
Other Motorcycle: '13 Mag Wheel Bonnie
What tools do I need to remove the nut as seen in this picture for a 2013 mag bonniville?
I guess whatever size socket/wrench to remove the tire is what I need. Might as well get it all.
Thanks!
Whomever said all good things in moderation certainly never rode a bad ass Bonneville
Moogs is offline
post #2 of 12 (permalink) Old 12-12-2012, 04:38 AM
Main Motorcycle: Bonneville SE
peejay49's Avatar
Other Motorcycle: No need
Mag bonneville with spoked wheels!
My 2010 mag bonneville uses 24mm socket one side and 19mm spanner on the other side.
peejay49 is offline
post #3 of 12 (permalink) Old 12-12-2012, 04:53 AM
Sir is right.
Plasma.
plasma is offline
post #4 of 12 (permalink) Old 12-12-2012, 11:46 AM Thread Starter
Moogs's Avatar
Thank you sir.
Moogs is offline
post #5 of 12 (permalink) Old 12-12-2012, 07:12 PM
Main Motorcycle: 2012 base bonneville
Other Motorcycle: 2013 victory hammer
you can download an instruction sheet for the belt drive i installed at scootworks.com has all sizes + torques and instruction to install belt as well as a one piece chain not using a master it shows removing rear swingarm
rodhotter is offline
post #6 of 12 (permalink) Old 12-12-2012, 07:23 PM
Main Motorcycle: 2007 Bonnie T100
bonza's Avatar
Other Motorcycle: Jeep Wrangler
if you don't have metric spanners, 3/4" and 15/16" is a precise fit, matter of fact the latter fits snugger
2007 Tuxedo T100.
Dom Tourers, TTP breathe, DNA filter,baffle gone, 40/140/1 shim 3 turns, TTP igniter tune, Hagon Nitros, Thruxton Bars, Halcyon bar end mirrors, Pingel fuel valve, Monza gas cap, Burton seat, Avon Roadriders
bonza is offline
post #7 of 12 (permalink) Old 12-13-2012, 01:58 AM
Askari's Avatar
Whitworth
1/2 " whitworth is i think the snuggest fit. No rounding to the bolt head. Oh and just use a stilson on the other end!!
Askari is offline
post #8 of 12 (permalink) Old 12-13-2012, 02:08 AM Thread Starter
Moogs's Avatar
Ok I'll see what I have in standard. I bought the tools suggested but don't mind getting whatever is needed for proper fitment. I am building my collection.
What is a stilson?
Gonna do shop tomorrow night.
Moogs is offline
post #9 of 12 (permalink) Old 12-13-2012, 04:55 AM
What is a stilson?
Askari is just having a little joke with you,a Stilson is a plumbers tool.
Plasma.
plasma is offline
post #10 of 12 (permalink) Old 12-13-2012, 04:57 AM
Askari's Avatar
Tongue in cheek!
What is a stilson?
A stilson is often called a pipe wrench and is not to be used on your pride and joy. It is about as far removed from a well fitting spanner as you can get!
At the end of the day the most important thing is fit. So if you only have an A/F spanner and it fits well, then use it.
Askari is offline
removing the rear wheel jnicosia Speed Triple Forum 10 02-11-2009 08:58 PM
Removing Rear Wheel Without a Paddock Stand HoustonTriple Speed Triple Forum 7 05-17-2007 08:49 AM
Removing the rear wheel blinker Speed Triple Forum 16 07-27-2006 04:16 PM
Removing Rear Wheel msparks Sprint Forum 6 08-08-2005 05:49 PM
Removing & Replacing rear wheel on Y2K-TBS Maintenance & Workshop Talk 29 07-29-2003 06:38 PM
