Wobble - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 13 (permalink) Old 12-11-2012, 11:05 PM Thread Starter
Main Motorcycle: bonneville cafe
Wobble
So yesterday I installed some factory pegs for the rear passenger that had been taken off of my Triumph Bonneville 2007, I had the girlfriend hop on the back to the grocery store and about half way there the bike started to wobble after picking up some speed from 15-35 mph. Immediately turned back home and drove real slow, not sure what it is, but it is a significant wobble that just started by having a 2nd rider...any ideas...
alexandercase is offline
post #2 of 13 (permalink) Old 12-11-2012, 11:12 PM
bonniemojo's Avatar
Other Motorcycle: Triumph Daytona 675<-SOLD
Extra Motorcycle: 2004 Bonneville Black
Tire pressure?
bonniemojo is offline
post #3 of 13 (permalink) Old 12-11-2012, 11:27 PM
Main Motorcycle: 08 Scramblinator 9000
ItsForrest's Avatar
Other Motorcycle: Kawasaki Darth Versys
Yup, check tire pressure. Also, if you are both over about 150lbs, crank up the pre-load on the shocks.
Get off my lawn!
ItsForrest is online now
post #4 of 13 (permalink) Old 12-11-2012, 11:33 PM
Main Motorcycle: Bonneville T100 2012
We can assume your alignment is good?
PeteV is offline
post #5 of 13 (permalink) Old 12-11-2012, 11:42 PM Thread Starter
the wobble was there even after she got off the bike. if that makes any difference
post #6 of 13 (permalink) Old 12-12-2012, 12:39 AM
Main Motorcycle: Thruxton
Other Motorcycle: Guzzi V-11
I have a tail rack (and had a box on it)...whenever I had more than a few pounds in the box (a lot less than your girlfriend), I got low speed, but tolerable wobble...nevertheless, I lost the box anyway...later at much higher speed I hit a modest pot-hole, and that caused a pretty scary wobble...I decided that was due to incorrect tire pressure (actually, too high in the front).
So I check tire pressure front and back before every serious ride and have not had a problem since...I also make sure my rubber is not more than a couple years old.
milsherut is offline
post #7 of 13 (permalink) Old 12-12-2012, 04:52 PM
Main Motorcycle: 2012 Rocket III Roadster
RickMcCl's Avatar
Other Motorcycle: N/A
The book says to set your rear pre-load at five (highest setting) when carrying a rider.
I do that when my wife's along; and have had no problems.
I also check/inflate the tires every week.
My front drops 2-3 pounds, and the rear a pound or so, so I inflate the front to 35psi, and the rear to 40psi (book calls for 33/38).
Rick
RickMcCl is offline
post #8 of 13 (permalink) Old 12-13-2012, 11:40 PM Thread Starter
hm
It is definitely the rear tire, very low, thanks for all the advice!
Anyone have any or know of any good videos on how to adjust the pre-load...?
post #9 of 13 (permalink) Old 12-14-2012, 04:44 AM
Forchetto's Avatar
Preload is adjusted by a hole in the side of the shock collar. You insert a suitable screwdriver, even the allen key supplied for seat removal, or similar implement of around 6mm diameter and turn.
Clockwise to increase pre-load. I mean clockwise as viewed from the underside of the shock.
The owners handbook has a comprehensive instructions under "rear suspension adjustment" pages 83, 84.
Triumph do make a tool, sold for around $3.00 but as you can see it's just a piece of steel rod:
Forchetto is offline
post #10 of 13 (permalink) Old 12-15-2012, 03:16 PM Thread Starter
i adjusted it to the opposite of what it was set at, wish there was a video to make sure i am setting it to what is best to ride with a passenger. I have searched youtube extensively.
So if you are looking up from underneath the bike is how they determine clockwise and counter..
Wobble gone soggybottom Air Cooled Twins Technical Talk 2 04-16-2009 10:08 PM
S4 front end wobble?? spdfour Triumph SuperSports 11 08-04-2008 01:28 AM
Tach wobble akenaten Air Cooled Twins Technical Talk 11 07-24-2007 10:37 AM
More on the wobble tstacy Speed Triple Forum 14 04-21-2006 10:42 AM
Help - Handle Bar Wobble Pugsley Sprint Forum 11 04-11-2006 11:32 AM
