fork lube - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 4 (permalink) Old 12-11-2012, 08:58 PM Thread Starter
Main Motorcycle: 2007 T100
Dave NEO's Avatar
Other Motorcycle: 1972 T100R Daytona
fork lube
anybody spray their exposed forks after cleaning to keep them slippery? need something that sfe for the seals that drys after application -maybe new WD40 synthetic or a spray dry lube of some sort..
Dave NEO is offline
post #2 of 4 (permalink) Old 12-11-2012, 09:07 PM
Main Motorcycle: 1972 T120V
Bombman's Avatar
Other Motorcycle: 2009 Kawasaki Versys 650
Try Maxima Racing Oil SC1
I would use Maxima Racing Oil SC1. It is a silicone based product that sprays on slightly wet. You let it set a few minutes and buff off. It repels dust and dirt but leaves a slick surface and is completely dry and water resistant. I use it on all my plastics, windshields, headlights, forks, rear suspension, taillight/turn signals and anything else I want to look great. It especially looks good on black plastic, leaves it looking wet. It lasts a long time and should do the trick for you. Since it is silicone it should not hurt any seals. I even use it on all my helmets, especially visors. Dead bugs wipe right off. Make sure you buff it really well.
Bombman is offline
post #3 of 4 (permalink) Old 12-12-2012, 09:06 AM Thread Starter
Dave NEO's Avatar
sounds good. thanks. Might go ahead and install these fork boots and really don't want to overdo any lube underneath them that will collect dirt and dust and start grinding away at the metal.
Dave NEO is offline
post #4 of 4 (permalink) Old 12-12-2012, 10:29 AM
Main Motorcycle: 01 Triumph Bonneville
Other Motorcycle: 01 HD Night Train
Extra Motorcycle: 87 Honda Super Magna
Fork boots will do more to protect the seals then any polish or lubricant you can apply. They should be standard equipment on all bikes
DUCKMAN is offline
To Lube the chain or not to Lube...that is the Question Clanrickarde Air Cooled Twins Talk 58 02-14-2013 05:00 PM
what lube is this? Gone Cat Hinckley Classic Triples 5 07-24-2009 02:08 PM
Cam Lube thirdbike Classic, Vintage & Veteran 8 03-02-2009 09:56 AM
New Speedo Cable - To Lube or Not to Lube oregonthruxton Air Cooled Twins Technical Talk 4 04-30-2008 10:58 AM
Wax or lube? Kem770 Hinckley Classic Triples 9 10-06-2006 07:13 PM
