Timing cover & clutch cover replacement - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 6 (permalink) Old 12-11-2012, 11:42 AM Thread Starter
Main Motorcycle: '09 Triumph Thruxton
Burgandy25's Avatar
Other Motorcycle: 1963 Suzuki TS250 Savage
I was looking into replacing my stock brushed aluminum looking timing cover and clutch covers with either a speed merchant fined covers or just powder-coated covers. How difficult is it to do this? all I need to do is drain the oil and get new gaskets to complete this task?
Burgandy25 is offline
post #2 of 6 (permalink) Old 12-11-2012, 12:16 PM
Main Motorcycle: 2007 bonnie black
killian101's Avatar
Other Motorcycle: 68 BSA (RIP)
Extra Motorcycle: 2015 Daytona
You will need new gaskets. Make sure to scrap off all the old bits. Its pretty easy to do...plan it around an oil change.
killian101 is offline
post #3 of 6 (permalink) Old 12-11-2012, 04:00 PM
Main Motorcycle: 07 Bonnie Black
Derby Boy's Avatar
Replacing the covers is a simple mechanical job, but remember you will have to remove the stator from your "Timing Cover" which isn't to bad, just be careful when removing the wires & gromet.
The clutch side is a little more complex. You'll have to swap out the clutch actuating mechanisms. There is a cover plate, the clutch shaft, a pin & a spring and what looks like a rubber cush drive but I think it's there as a damper. Also there are bearings for the clutch shaft that may have to be installed in the new clutch cover. Make sure you note exactly how it all comes apart. One end of the spring fits into a hole in the end of the shaft. It can be a little tricky, but doesn't require a high skill level. Just patience and note how everything comes apart.
"Another Trumpet Rat enslaved to a Bonnie"
07 B/B, AI gone, TEC stainless exhaust, K&N Pods, ARKed 40/142, 1 shim, +1 risers, Custom gauge bracket, never ending tinkering
Derby Boy is offline
post #4 of 6 (permalink) Old 12-11-2012, 05:59 PM
Main Motorcycle: 2002 Bonneville
Other Motorcycle: 2007 Tiger 1050
Extra Motorcycle: 1964 Bonneville Project
This sticky in Twins Technical Talk contains a wealth of information on maintenance/repair:
http://www.triumphrat.net/twins-tech...and-so-on.html
When I had to change my clutch cover gasket, I had a terrible time cleaning the old gasket off, but the following link was helpful (even though I wash't messing w/ the springs).
http://www.triumphrat.net/twins-tech...ngine-oil.html
RevnUp is offline
post #5 of 6 (permalink) Old 12-11-2012, 06:01 PM
Main Motorcycle: Bonneville
It can be very helpful to take detailed photographs while disassembling and then look at them as you put it back together.
2005 Bonnie, Sleepers and Unifilter, AI gone, restrictor gone, Modre's peg kit, headlight & brake modulator, tach, NC wind deflector, gaiters, steibel, vmax mirrors, Hagons & Progressives, PIAA. http://TexasCoastGeology.com
geolpilot is offline
post #6 of 6 (permalink) Old 09-22-2014, 01:32 AM
Main Motorcycle: 2007 Triumph Thruxton
blight's Avatar
Other Motorcycle: 2010 Harley XR1200
Extra Motorcycle: 1969 BSA 441 Victor
I did the Speed Merchant stator cover and it was easy. Just order a new gasket from BikeBandit.com or whoever you choose. BB has expensive shipping, but they will get you the parts you need.
The Speed Merchant items are top notch... gorgeous!
I leaned my bike against a tree and was able to remove the old cover and install the new one without draining the oil.
You will need to unbolt the stator from your OEM cover and transfer it to the SM cover... easy.
It looks great I think:
BLIGHT
blight is offline
Replacement clutch cover for 06 speed triple SpeedyinCA Speed Triple Forum 5 02-04-2012 07:58 AM
TR6C Timing cover crack! and replacement? Landon Classic, Vintage & Veteran 6 06-13-2011 06:17 PM
New Clutch Cover replacement process Mingo09 Air Cooled Twins Technical Talk 15 10-26-2010 04:18 PM
06 Thrux Alternator Cover & Clutch Cover Redrider736 Club Cafe' 2 06-12-2008 09:07 PM
GSG clutch cover and stator cover sliders! HiVel Speed Triple Forum 5 01-09-2007 10:04 PM
