grinding rear end noise - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 16 (permalink) Old 12-10-2012, 05:55 AM Thread Starter
Main Motorcycle: 2008 bonnie black
macca47's Avatar
Other Motorcycle: 1970 Norton Commando
Extra Motorcycle: 1969 trophy [sold]
hi
ive got a 2002 bonneville with 30000km , and after about 60km i geta nasty sounding grinding noise from the rear end . i have replaced spokets and chain recently but didnt check the swing arm is this the likely culprit
cheers macca
macca47 is offline
post #2 of 16 (permalink) Old 12-10-2012, 06:35 AM
Main Motorcycle: 05 T100
Could be a number of things, but I would take a good look at the rear brake first.
Paul.
Herts. UK
PAAS is offline
post #3 of 16 (permalink) Old 12-10-2012, 07:11 AM
Main Motorcycle: Speed Triple (2011)
Are you wiping your arse correctly?
sorry, had too
"Time flies like an arrow, fruit flies like a banana"
brumfitt is offline
post #4 of 16 (permalink) Old 12-10-2012, 07:47 AM
Forchetto's Avatar
If not, try this...:
Forchetto is offline
post #5 of 16 (permalink) Old 12-10-2012, 08:39 AM
Main Motorcycle: 2008 B&W T-100
clydeturbeaux's Avatar
I would agree with Paas on checking the rear brake first. Then I would check for proper rear wheel alignment, chain adjustment and torque on the rear axle.
Finally, I would suspect the rear wheel bearings or maybe an error in re-assembly due to the spacer location on the axle.
Is your cush drive in good shape?
Is it okay "cold", but after 60km it consistently makes the noise?
How long after stopping before it makes the noise again? Overnight? A few hours/minutes?
If feasible, pull over as soon as you notice it and carefully feel around the rear wheel components for abnormal heat.
Let us all know what you find out.
Good Luck!
clydeturbeaux is online now
post #6 of 16 (permalink) Old 12-10-2012, 07:22 PM
Main Motorcycle: 03 T100
mikeinva's Avatar
The bearing in the rear sproket hub give alot of trouble on these bikes
mikeinva is offline
post #7 of 16 (permalink) Old 12-10-2012, 08:36 PM
Main Motorcycle: Black T100
fliplid's Avatar
Pure class
Sent from my GT-S5670 using Motorcycle.com App
From the outside of the asylum.
fliplid is offline
post #8 of 16 (permalink) Old 12-10-2012, 09:28 PM Thread Starter
macca47's Avatar
sorry, had too
hey brumfitt he is a you tube song you could probably relate to
macca47 is offline
post #9 of 16 (permalink) Old 12-10-2012, 09:32 PM Thread Starter
macca47's Avatar
macca47 is offline
post #10 of 16 (permalink) Old 12-10-2012, 09:41 PM Thread Starter
macca47's Avatar
Good Luck!
ok i had done a lot of that but kept the initial post short to see what i missed
the alignment was out a bit and the rear axle torque and chain tension was also out
the bearings feel ok after 60km ie not hot and everything feels tight
the noise comes and goes so ill have another go on wednesday and aim for the brake [ which had new pads about 5000 kms ago]
cheers
macca47 is offline
The 'ol rear grinding noise? TvZ Air Cooled Twins Technical Talk 9 07-23-2016 06:51 AM
Engine covers off to polish, now grinding noise when I hit the start button ryanniles Air Cooled Twins Technical Talk 21 05-09-2012 07:37 PM
Question about TUNE-UP and front wheel grinding noise nagibe Air Cooled Twins Technical Talk 7 10-24-2009 01:05 PM
Scraping/Grinding Noise? Legman Speed Triple Forum 7 11-06-2005 06:09 AM
