grinding rear end noise - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
post #11 of 16 (permalink) Old 12-11-2012, 04:59 AM
Main Motorcycle: Bonnie T 100
Crackon's Avatar
Originally Posted by mikeinva View Post
The bearing in the rear sproket hub give alot of trouble on these bikes
My rear sprocket bearing went in the first couple of hundred miles. Done under warranty, fortunately.
Crackon is offline
post #12 of 16 (permalink) Old 12-11-2012, 04:07 PM Thread Starter
Main Motorcycle: 2008 bonnie black
macca47's Avatar
Other Motorcycle: 1970 Norton Commando
Extra Motorcycle: 1969 trophy [sold]
Rear brake
macca47 is offline
post #13 of 16 (permalink) Old 12-11-2012, 10:56 PM
klem's Avatar
macca47
What was wrong with it?????
KLEM KADIDDLEHOPPA
2012 Triumph Bonneville T100: NH Togas, AI Removed, 02 Sensors Removed, TTP Breathe Cover, DNA Filter TTP Tune 3,Bitwell Tracker Bars, CRG bar end mirrors, D9 gauge brackets, Burton DSOO3 seat.
klem is offline
post #14 of 16 (permalink) Old 12-12-2012, 01:35 AM Thread Starter
macca47's Avatar
Pads were very badly worn , only 5500 km also the piston is quite slow to retract so pads are on order and ill take the caliper off tomorrow and pull it apart to see what i can find
cheers
macca47 is offline
post #15 of 16 (permalink) Old 12-12-2012, 05:08 AM
Main Motorcycle: 05 T100
Because of the position of the caliper they get covered in crap and it's not unusual for the piston to become a bit sticky or even seized, hence the tendency to eat rear pads on occasions.
Paul.
Herts. UK
PAAS is offline
post #16 of 16 (permalink) Old 02-08-2013, 12:03 AM Thread Starter
macca47's Avatar
the final update on this saga
rear disc replaced
rear caliper overhauled with new pistons [ scuffing marks on old ones] new seals fitted
new brake fluid
new pads [ metal gear]
and still the grinding noise would come and go so today i fitted genuine triumph brake pads [actually SBS] and on measuring both sets found the metal gear pads were 1mm thicker so no wonder the pistons would not retract all the way in as there was an extra 2 mm of brake pad to compensate for !
oh well its all good now and a lesson learnt
macca47 is offline
The 'ol rear grinding noise? TvZ Air Cooled Twins Technical Talk 9 07-23-2016 07:51 AM
Engine covers off to polish, now grinding noise when I hit the start button ryanniles Air Cooled Twins Technical Talk 21 05-09-2012 08:37 PM
Question about TUNE-UP and front wheel grinding noise nagibe Air Cooled Twins Technical Talk 7 10-24-2009 02:05 PM
Scraping/Grinding Noise? Legman Speed Triple Forum 7 11-06-2005 07:09 AM
