Lucas Tail lamp/Turn Signal relocation - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 23 (permalink) Old 12-09-2012, 12:34 PM Thread Starter
Main Motorcycle: Triumph Bonneville T100
deadbroke's Avatar
I have a 2012 Bonnie T100.I would like to change the factory tail lamp/signal assembly to the better looking Lucas tail lamp. I like the Maund adapter kit,but am wondering if I should just get the LED lamp assembly from Bellacorse and drill some holes in the fender.At the same time I'd like to relocate the signals to the shock mounts using the much smaller aftermarket type. My concern is that they'll get damaged by a passenger getting on and off the bike. Any input would be greatly appreciated.
deadbroke is offline
post #2 of 23 (permalink) Old 12-09-2012, 02:01 PM
Ripper's Avatar
Before you get the LED assembly, take a look at this thread:
http://www.triumphrat.net/twins-tech...onversion.html
If you carry passengers you may want to mount the turn signals a little further back than the rear shock mounts. I have a Triumph grab rail on mine, which is mounted to a dresser rail. I have relocated my turn signals to the point where the grab rail bolts onto the dresser rail. They are rougly level with the rear end of the seat. The side of the rear fender is also a good mounting point if you don't mind drilling a hole in each side.
Ripper is offline
post #3 of 23 (permalink) Old 12-09-2012, 03:54 PM
Main Motorcycle: 2003 Triumph T100
Sheepdog's Avatar
I've used the shock-mounted mini-indicators on my '03 T100 since '05 with nary a problem. However, if I used soft saddlebags I would have to move them further back...
Sheepdog is offline
post #4 of 23 (permalink) Old 12-09-2012, 04:32 PM Thread Starter
deadbroke's Avatar
Nice Bike! what brackets and signals did you use? Any pics of the front signals? I don't plan on running bags.I did install the grab rail that comes on the 110th anniversary edition.
post #5 of 23 (permalink) Old 12-09-2012, 04:36 PM Thread Starter
deadbroke's Avatar
Any pics of your install? I really don't want to drill the fender .
post #6 of 23 (permalink) Old 12-09-2012, 06:56 PM
Ripper's Avatar
There is only 1 pic I have that shows them. They are just triangular flat brackets with 3 holes which mount by bolting them onto the Grab Rail. Hope this helps.
Ripper is offline
post #7 of 23 (permalink) Old 12-09-2012, 08:43 PM
Main Motorcycle: GasGas TXT Pro Trials
Bron-Yr-Aur's Avatar
Other Motorcycle: KTM 200 XC 2T
Extra Motorcycle: Kawasaki KX250 2T
For the signals, I just used bookshelf brackets that I painted black. I did have to cut and redrill them. Very sturdy and in no danger of being in the way for a 2nd rider.
I'm afraid, unless someone has come up with another idea, you'll have to drill the fender to make the Lucas light look right. I tried and tried, but to get it level, I couldn't use the pre-existing holes. I did a DIY that the moderators put in the stickies. I think it's on page 3.
Edit: oops, it was pg 2. Here's a link. Hope it helps
http://www.triumphrat.net/twins-tech...ocate-diy.html
Bron-Yr-Aur Garage
Bron-Yr-Aur is offline
post #8 of 23 (permalink) Old 12-09-2012, 09:42 PM Thread Starter
deadbroke's Avatar
I really like the way you did the tail lamp/signal install. This is the way the factory should have done it, in my opinion. I've bookmarked your link for future reference.Thanks to everyone kind enough to post replies to my question.
post #9 of 23 (permalink) Old 12-10-2012, 12:51 AM
Sheepdog's Avatar
You can get both shock mount and rear mount brackets from New Bonneville:
http://www.newbonneville.com/html/bl..._brackets.html
I believe I bought the mini-indicators from BellaCorse, but they don't carry them any longer. However, they're widely available...I found these at the Dennis Kirk site:
https://www.denniskirk.com/k-and-s/u....prd/21465.sku
My front indicators are the same as the rears. I installed them in the same holes as the stockers:
Sheepdog is offline
post #10 of 23 (permalink) Old 12-10-2012, 02:54 AM
Main Motorcycle: Thruxton R
Other Motorcycle: Honda CB750 K0
Extra Motorcycle: Honda CBX 750f cafe
I'm going to mount one of the Lucas mt110 round lights to my Thruxton. I'll be custom fabbing a bracket from aluminium using the existing fender holes. I'll post pics in the next few days.
Timinoz is offline
Lucas tail lamp installation bobbed or stock fender Canyon Racer Air Cooled Twins Technical Talk 4 06-15-2014 06:23 AM
BC turn signal relocation kit solesrfr Club Cafe' 8 03-25-2010 03:58 PM
BC Lucas FEK install, and help with turn signal relocation!!! Vegas_07Bonnie Air Cooled Twins Technical Talk 2 02-12-2009 08:18 AM
Turn-signal Warning Lamp Replacement MarcP1956 Air Cooled Twins Technical Talk 0 07-09-2007 07:04 PM
turn signal relocation 05Truxter Club Cafe' 11 05-14-2007 11:42 PM
