Remapping ECU Necessary? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 15 (permalink) Old 12-08-2012, 10:26 AM Thread Starter
Main Motorcycle: "Thai" Triumph T100
Other Motorcycle: Previous: 1970 Bonny
Extra Motorcycle: Learned on Sports Cub
EFI Bike. OK so have opened up the air box and fitted a K&N. Fitted Emgo Dunstall mufflers and removed the Air Injection. Bike is running better than new, more power, smoother at low speed and slightly better MPG. Checking the plugs they appear to be burning ever so slightly rich but well within bounds.
I can see that remapping will have additional power benefits but is it necessary?
wyomingpat is offline
post #2 of 15 (permalink) Old 12-08-2012, 10:49 AM
Ripper's Avatar
I would have thought that opening the airbox and fitting a free flow air filter, plus more open pipes would weaken the mixture rather than richening it, making remapping neccessary. Do you still have the O2 sensors in place? It could be that they are compensating for a weaker mixture but this would only happen at low throttle openings. If the O2 sensors have been removed then a remap is neccessary because the ECU would have to fall back on the map data in the absence of an O2 sensor signal. Another thing to consider is, was the bike remapped already when the Emgos were fitted.
Ripper is offline
post #3 of 15 (permalink) Old 12-09-2012, 02:27 PM
Main Motorcycle: 2009 Blue & White America
MattyMo's Avatar
I would agree. Fuel mapping is lean to begin with. Adding more air into the motor and less restriction on the exhaust will make it more so.
Pat, how did you "open" the air box? Remove snorkel? Cut parts away? Or did you just replace the filter? TOR fuel map at the least would be called for with better air filter and exhaust. Custom tune if more air flow was added.
2009 America with some mods, a lot of fun that I can ride all day. (sold and miss my 2008 Bonneville, a great daily driver)
this message was created using recycled electrons
MattyMo is offline
post #4 of 15 (permalink) Old 12-09-2012, 02:52 PM
Main Motorcycle: 2012 Bonneville
Pat, I have somewhat the same set up as you.
Given that the stock mixture is quite lean to meet emission standards, and that you have removed the puffing air injection,
your ECU setup right now is good enough to just leave it alone.
BUT, you could go to your dealer and have him remap with the TORS factory ECU map as suggested above.
Personally, given your plug color comment and satisfaction with performance, I probably would consider it perfect and do nothing.
norton828 is offline
post #5 of 15 (permalink) Old 12-09-2012, 08:47 PM Thread Starter
No remapping to date. The snorkel is removed and the opening to the airbox opened out. Baffle still in place but that will come out soon. Air injection removed as per the post. O2 sensors still there as I cannot see a benefit of removing them. Now the dealer did say that the bike was set up for high altitude - 5,500ft North of Denver and I am in Cheyenne at 6,000ft. But I don't necessarily believe that as they told me a bunch of other incorrect stuff. The plugs are a mid grey colour which in the old carb days was good.
post #6 of 15 (permalink) Old 12-10-2012, 08:17 AM
MattyMo's Avatar
Your current configuration calls for the "TOR/aftermarket exhaust" fuel map at the least. If you remove the internal air box baffle even more air will flow. The stock map will be very very lean. I believe a custom tune or one from TTP/TPUSA would be called for. Those would also likely do away with the O2 sensors.
MattyMo is offline
post #7 of 15 (permalink) Old 12-10-2012, 01:27 PM
sprouty115's Avatar
...The plugs are a mid grey colour which in the old carb days was good.
I'm not sure how much experience you have reading spark plugs, so no offence intended, but there is a specific procedure and a number of variables to consider. Do a search for "plug chop" and take a look at what pops up. Also, as a more direct answer to your question, I would recommend a re-map. Most likely you are running lean.
- Stephen
sprouty115 is offline
post #8 of 15 (permalink) Old 12-11-2012, 10:40 AM
richm's Avatar
I would say it's necessary and, given the minimal cost and effort in doing so, why wouldn't you?
richm is offline
post #9 of 15 (permalink) Old 12-12-2012, 01:07 AM
Main Motorcycle: 2007 Bonneville
El Moderatore
Calliway's Avatar
Other Motorcycle: 2007 Kawasaki Versys
This gets asked so many times....anytime you do exhaust mods you need to remap. Throw in airbox mods and there is no question. You can't get more air in and out and not tell the compute to add fuel. Remap and get the full benifits of the mods or run very lean and very hot.
Calliway is offline
post #10 of 15 (permalink) Old 12-12-2012, 10:25 AM Thread Starter
Distance
It is a 220 mile round trip to Denver and it is December! Have wait to April.
remapping with bafflectomy Samfish Air Cooled Twins Talk 3 01-15-2013 09:51 AM
Remapping questions Locky Air Cooled Twins Technical Talk 3 08-16-2012 11:20 PM
Remapping Nortlas Cruisers - America, Speedmaster 5 06-09-2012 04:07 PM
Remapping EFI Swedish America Air Cooled Twins Technical Talk 4 07-14-2010 02:15 PM
Remapping Fi Sport Maintenance & Workshop Talk 1 07-23-2002 11:34 AM
