Which Shorai Battery - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 12 (permalink) Old 12-07-2012, 12:31 AM Thread Starter
Main Motorcycle: 2005 Thruxton
magrahamkp08's Avatar
Other Motorcycle: 1984 Moto Guzzi V65
Extra Motorcycle: 2006 BMW k1200r
Which shorai battery do i need to order for an '05 thruxton. Different websites give up different model numbers for the battery. Or does it not matter?
magrahamkp08 is offline
post #2 of 12 (permalink) Old 12-07-2012, 02:16 AM
Main Motorcycle: Thruxton
plodalong's Avatar
Other Motorcycle: 08 Bonneville efi
I went for the 18ah one although they say both will work. You do know they don't perform well in low temps, isn't a worry for me (mild winters) but if you ride in cooler weather it could be a problem.
07 thrux,breathe,Dna airfilter,airbox X restrictor,135 mains,tp +3 ignitor,yss emulators,hp springs, Bitubo shocks,pingle steering damper,D9 layflat,3" rise clipons,corbin seat, tt350 taillight,alloy indicators.shorai battery,Changes daily
plodalong is online now
post #3 of 12 (permalink) Old 12-07-2012, 12:56 PM
Main Motorcycle: Ducati Monster S4RS
Hypurone's Avatar
Other Motorcycle: 2010 Thruxton RS
Yup, run the LFX18A1-BS12. It is only .43lb heavier (still only 2.31lvs!) than the standard 14ah model (you can't even tell) and it has 60 more cranking amps plus a longer reserve. Helps with those "OH **** I LEFT THE F*$ING xxxxx ON!" moments and if you ever mod and raise compression etc....
I haven't had an issue yet with cold starting on my 944cc 11:1 comp Thrux or my 998cc 11.4:1 comp Monster S4RS. At least down to 40 degrees. And if you simply turn on the ignition and draw power from the battery for a minute then shut the key off, this "warms" the battery internally and it will boost its own voltage and crank better the next time.
I tried it for kicks and giggles on a low charged one that my buddy bought used for his Bonnie (14AH) when it cranked over slowly. Worked!
Chuck's Garages Thruxton
Camaro
Monster
'10 Thruxton RS 944cc - In the Faster Color
"You Were Really Flyin' When I Passed You Back There!"
Hypurone is online now
post #4 of 12 (permalink) Old 12-07-2012, 03:12 PM
DEcosse's Avatar
Go with the biggest capacity you can afford - 18 ideally.
Just to clarify further - the battery will give indication similar to a lead/acid battery in state of discharge - it will appear to be unable to turn over the engine, or at least very slowly. However the significant difference is that the LiFePO4 battery is NOT really discharged - just that the ions are quite immobile at low temp.
The work-around is to pre-heat the battery - you can self-heat it very simply by just turning on the headlight for 30s to a minute before attempting to start. The headlight will provide a 5A load that will get the unit warmed up. (lower temps may require longer)
That sounds counter-intuitive - with a discharged battery, drawing that kind of load will just make it worse. But again, the battery is not discharged - just need to get those ions moving. Don't worry that you will discharge it - it will run for quite a while (especially an 18) without getting into trouble. So if in doubt - and it is really cold (bike been left outside at night in freezing temps) - just leave light on a bit longer before attempting to start.
It is an odd quirk, but treat it right and it will be trouble free.
DEcosse is online now
post #5 of 12 (permalink) Old 12-07-2012, 03:17 PM Thread Starter
I ordered the The 18 today. Thanks for the insight
post #6 of 12 (permalink) Old 12-10-2012, 03:10 PM
Main Motorcycle: 2012 base bonneville
Other Motorcycle: 2013 victory hammer
i have been reading about the lith-ion batteries from what i have seen in several places Shorai advertizes the most but is not the best performing in same price range, others for more $$$ far excede in performance. less weight is better for sure but at double the cost it should perform better since most of us are not pro racers but its your $$$$
rodhotter is online now
post #7 of 12 (permalink) Old 12-10-2012, 04:31 PM
Hypurone's Avatar
Shorai's are NOT Lithium Ion. They are Lithium Iron (LiFe). Big difference. I beg to differ on the performance aspect. I have used another brand and had piss poor results from them. There are other LiFe options out there aside from Shorai and Ballistic(total crap!) but the ones I have found are MORE expensive than Shorai and have no discernibly better track record performance wise....
Camaro
Monster
post #8 of 12 (permalink) Old 12-10-2012, 10:35 PM
Main Motorcycle: 2007 Bonnie T100
bonza's Avatar
Other Motorcycle: Jeep Wrangler
I found that very interesting.
does this also apply with other batteries like lead acid, etc?
and could this be valid for EFI bikes that have trouble starting in low temps as reported in other posts?
2007 Tuxedo T100.
Dom Tourers, TTP breathe, DNA filter,baffle gone, 40/140/1 shim 3 turns, TTP igniter tune, Hagon Nitros, Pingel fuel valve, Monza gas cap, Burton seat, Avon Roadriders
I like a man who grins when he fights -
Winston Churchill
bonza is offline
post #9 of 12 (permalink) Old 12-11-2012, 01:17 AM
Forchetto's Avatar
Yes but there's a limit due to the space available. The newer Bonnies have had the larger battery installed as fitted to carbed bikes, the YTX12-BS, but as this is a little larger than the one they've been fitting up until May 2011 or so, the YT12B-BS, there has been some alterations to the airbox and the routing of the battery cables to accomodate it.
I don't know the details of the alterations needed though.
Forchetto is offline
post #10 of 12 (permalink) Old 12-11-2012, 10:11 AM
Main Motorcycle: 06 Thruxton
Other Motorcycle: '69 Bonneville
Extra Motorcycle: '71 Bonneville
I think the biggest advantage (and the one I am willing to pay the additional money for) is their low self discharge rate. If you have a bike that you ride regularly, like a daily commuter, then this is not really an issue for you. But, if you have a bike that sits and isn't ridden regularly, not having to deal with a battery tender is convenient.
I bought one for Tweety, my track bike, because it sits all summer long when it's just too hot to ride in all the gear. This past summer I pulled the battery out and, following Shorai's instructions, placed it in at zip lock bag. It then got stored in the back of the refrigerator and forgotten about. Six months later I pulled it out, set it in the sun to warm, and when I reinstalled it, it started the bike crisply and with out hesitation.
It will remain in the bike until next summer when I will repeat the same procedure. Until then it will only be charged when ridden during track days.
If you have a computer bike this doesn't work as the electronics will drag it down there by negating the advantage.
I just bought a second one for the '71 Bonneville that I just completed. It doesn't get ridden regularly so a battery tender would be a must. Further more, the charging system is such that normal riding doesn't really keep it charged. But, what I am doing is placing it on charge after riding, removing the charger once it is fully recharged, and then I don't have to bother with it until I ride it again which might be a week or more.
But, they are light and small so for others that might be enough to justify the price.
Art.
BirdoPrey is offline
Battery Box delete and install of Shorai Battery on my 07 Thruxton SouthofHeaven Club Cafe' 33 05-28-2015 11:25 AM
Shorai battery Wayne's Striple Street Triple Forum 19 12-16-2013 06:20 PM
Shorai Battery Keltriple Speed Triple Forum 110 12-20-2012 03:21 PM
Shorai Battery briclark1 Speed Triple Forum 0 04-11-2011 06:38 PM
