Rough running in the rain fix - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 3 (permalink) Old 12-06-2012, 06:26 PM Thread Starter
Main Motorcycle: 2011 Bonneville SE
Here is a tip I got from a veteran wrench who owns a newish Speedmaster. The engine was coughing, farting and stalling in wet weather. The guy traced it to the fuel overflow/breather tube that descends from under the tank and drains low down on the right side. The setup is the same on my 2011 Bonneville SE. Anyway, the front tire was throwing up water into the bottom end of the tube, causing an obstruction in the line and a vacuum in the fuel tank that eventually impeded fuel delivery and led to coughing and farting. The guy corrected it by trimming the tube at an angle, with the opening toward the back. Probably it is best done preemptively.
It occurs to me that this could be an issue on almost any bike with the breather tube thus situated, as it usually is.
Prairie Wrench is offline
post #2 of 3 (permalink) Old 12-06-2012, 08:45 PM
Forchetto's Avatar
Thanks. Good reminder of a problem that's been with us for some time. The Factory still doesn't get it, even though slash cuts in carb, tank, battery, etc drain hoses are normal practice in Japanese bikes.
The problem is talked about on this thread both in the original post and further on post 11 with photos courtesy of member Verde:
http://www.triumphrat.net/twins-tech...-and-tips.html
Forchetto is offline
post #3 of 3 (permalink) Old 12-06-2012, 11:18 PM Thread Starter
I figured someone else might have thought of this, but I hadn't seen it in the forum. Funny, though, that Triumph engineers would not have picked up on it as the Japanese apparently have.
Running Rough in the Rain eelmgren Hinckley Classic Triples 1 08-14-2012 02:24 PM
running a little rough after the rain rug rats Sprint Forum 16 12-22-2011 06:21 PM
rough running budfin Vintage Technical Tips & Tricks 1 05-15-2011 02:50 AM
05 running rough- TPS? Anthouse Tiger Workshop (archive) 6 04-23-2011 04:05 AM
new and rough running? maxed66 Speed Triple Forum 2 06-21-2006 06:39 PM
