*** did I do wrong now ? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 6 (permalink) Old 12-05-2012, 09:44 PM Thread Starter
Main Motorcycle: 07 Thruxton
Mekagojira's Avatar
Extra Motorcycle: '75 CB750 caffinated
Hi any help appreciated !
Gas leaking from Pod.
Just had carbs off to make sure the idle circuit was was clean as I was running lean at idle after installing BC air box delete. With Thier 42s and 140 jets. At 2.5 turns now.
Bike will turn over after much cranking but does not stay on...
With pet cock on gas pours from left pod...
At least it was running yesterday if not ideally... Geez. What did I do wrong ? The carb assemble seemed straight forward at the time...
Mekagojira is offline
post #2 of 6 (permalink) Old 12-05-2012, 10:35 PM
Main Motorcycle: Bonneville
Other Motorcycle: Honda Postie
Extra Motorcycle: Suzuki DL650 V Strom
Hello
Sounds like the float valve is not sealing off. Off with the carbs and check it out. Also check that jets are properly installed.
Tasmaniablue is offline
post #3 of 6 (permalink) Old 12-05-2012, 10:41 PM
Main Motorcycle: '03 Triumph Bonneville
Two things to check... float sticking (fix by draining float bowl & tapping the bowl w/a screwdriver handle)... and I know this sounds really stupid... but it has happened before... by any chance did you hook up the carb vent line to the petcock? The vent line is the piece of tubing (non "pre" kinked/shaped) that runs down to the lower plastic T fitting on the carbs...
SCbonneville is offline
post #4 of 6 (permalink) Old 12-06-2012, 12:26 AM Thread Starter
Mekagojira's Avatar
Thanks SCBonneville - wait where does the fuel line go? not to the T in the middle/ I don't think I ever saw a vent line - I have a thin rubber tube connecting the two carbs thats it. And then I have a fuel line from the tank… I very well may be confused.
post #5 of 6 (permalink) Old 12-06-2012, 01:21 AM
If you removed the Cali EVAP system, check that carb vent hose that SCBonneville mentioned.
I had the same problem as you just recently. Either my problem was a stuck float, or I think the rain shot water up into the carb vent hose, soaking the filter element I had stuffed in there and thereby making the venting almost non-functional.
luckyduck is offline
post #6 of 6 (permalink) Old 12-06-2012, 07:39 PM Thread Starter
Mekagojira's Avatar
Yep. I'm an ass. Had the fuel line hooked up to the vent. Need to pay more attention during disassembly.
What went wrong kiwichrisbassett Tiger Chat 1 08-09-2010 01:17 PM
Wrong place, Wrong time rixmix Biker Hang-Out 8 02-24-2009 10:10 AM
wrong thing at wrong time fugitive Biker Hang-Out 9 09-16-2008 08:03 PM
Wrong primary-case = wrong timing happyray Classic, Vintage & Veteran 3 04-05-2007 10:27 AM
Did I use the wrong oil? Berta Air Cooled Twins Technical Talk 7 03-06-2007 04:07 PM
