Is it gapping, ignition coil, or something else? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 38 (permalink) Old 12-04-2012, 05:14 PM Thread Starter
So I've done a bunch of intake system replacements (o-rings, rubbers, stainless clamps) in order to get rid of a off-idle hesitation that is doing my head in. It's especially annoying that whilst waiting at a light and then accelerating when it turns green that my bike takes off a bit and then coughs and stumbles like it loses power or ignition for a few strokes and then moves on. It gets better as the bike warms up and it seems it's much worse when the idle screws are out 2.5 turns versus 2 turns (42 pilot jets).
Is this a gapping issue coupled with a strong (rich) mixture that's causing the problem? I would really like smooth, uniterrupted power deliver without this hesitation and coughing.
I think my next steps are testing the ignition coil with a multimeter and pulling the plugs (which I just recently replaced) and check their gapping.
luckyduck is offline
post #2 of 38 (permalink) Old 12-04-2012, 05:29 PM
With 42 pilots you should only have the mixture screws out one turn, or less.
denbow is offline
post #3 of 38 (permalink) Old 12-04-2012, 10:57 PM
Main Motorcycle: '03 T-100 & '08Tiger1050
+1 on what the above poster said...and I would add that, depending on intake and exhaust mods, you may actually need to put the stock 40 pilot jets back in the carbs to get it to run like you want.
Larry
RedBird is online now
post #4 of 38 (permalink) Old 12-05-2012, 02:52 AM Thread Starter
I forgot to mention I have snorkel removed, baffle removed and air intake hole enlarged.
The hesitation happens when accelerating at about 1/8-1/4 throttle. Sometimes the cut in power is so abrupt that I get chucked forward a bit from the engine braking that kicks in as soon as the power is gone for that split second.
post #5 of 38 (permalink) Old 12-05-2012, 07:12 AM
That means you're bogging...way too rich on the mixtures despite your intake mods. Read mine and Redbird's signatures and note the mixture screw settings.
+1 on what Redbird suggests about going back to 40 pilots if necessary.
It's going to be a lot less hassle for you setting yours at one turn than messing around with all the ignition stuff and possibly making matters worse.
denbow is offline
post #6 of 38 (permalink) Old 12-05-2012, 10:55 AM
Main Motorcycle: 2001 Bonnie
Other Motorcycle: 2002 Bonnie
Extra Motorcycle: 1250 K8 Suzuki Bandit
Yet another bike with a 42 pilot jet fitted to "fix it", throw it away, fit the 40 and set the idle mixture correctly, if there is still a problem then look to the electrcal system.
fullplat1 is offline
post #7 of 38 (permalink) Old 12-05-2012, 12:48 PM
42 pilots can work very well with suitable inlet mods and open exhausts on the 790 motor. In the OP's case he's probably better off going back to 40.
denbow is offline
post #8 of 38 (permalink) Old 12-05-2012, 03:31 PM Thread Starter
Well, I've got a nology profire coil and nology hotwires on order. I'll be going back to 40 pilots soon.
I think I need to respace my seat as well, I fear that it's contacting the igniter.
post #9 of 38 (permalink) Old 12-06-2012, 01:52 AM
Forchetto's Avatar
Right. We'll look forward to this sort of thread with those . Waste of money, cancel them if you can:
http://www.triumphrat.net/cruisers-a...-up-plugs.html
http://www.triumphrat.net/twins-tech...urning-up.html
Forchetto is offline
post #10 of 38 (permalink) Old 12-06-2012, 02:14 AM Thread Starter
Unfortunately I couldn't cancel them in time. I'll be returning them asap.
Ignition Coil Wiring Nigle Trophy 14 08-20-2012 02:16 PM
ignition coil? jsprinter Sprint Forum 4 06-04-2012 09:15 PM
Ignition coil order muchelneybandit Hinckley Classic Triples 4 07-27-2011 05:18 PM
New pick-up coil, ignition coil, & ignitor. No Dice... Flyhalf_Keith Air Cooled Twins Technical Talk 22 04-18-2010 04:19 PM
bad ignition coil Hinckley Classic Triples 4 02-15-2004 01:11 PM
