Is it gapping, ignition coil, or something else? - Page 4 - Triumph Forum: Triumph Rat Motorcycle Forums
post #31 of 38 (permalink) Old 12-10-2012, 08:42 AM
When you replaced the white plastic guides in the carbs did you make sure none of the feet were obstructing the holes in the pistons ?
denbow is offline
post #32 of 38 (permalink) Old 12-10-2012, 02:54 PM Thread Starter
Yes indeed. I've seen that the plastic thing with feet has little shallow slots to fit into in the slide. If you look down into the slide you'll see that it has a definite position to slot into. Thus I've always found it hard to imagine slotting it in and having it cover up that little hole.
However, I just let gravity put the white holder in. I don't push on it or anything. Is that fine?
luckyduck is offline
post #33 of 38 (permalink) Old 12-10-2012, 06:00 PM
Main Motorcycle: 2007 thrux
mjsmilford's Avatar
maybe you need a set of these https://secure.powerapt.com/smartcarb-green.php no jets to worry about...
Mike
2007 triumph thruxton
mjsmilford is offline
post #34 of 38 (permalink) Old 12-12-2012, 09:41 PM Thread Starter
After further testing, I have a gut feeling that that the fuel metering by the idle mixture screw is nonlinear. The reason I think this is that because there is a distinct and sudden change in engine character between 1-1.75 turns out to 2.0-2.5 turns out. Immediately, the richer settings produces better throttle response and idling characteristics and less coughs back through the intake and airbox.
Perhaps it's the taper of the needle or the fuel mix requirements of the engine, but I think 2.0-2.5 turns might be the optimal operating range for my 790 engine at least (regardless of jet size, to a point). Thus, I'm going to try the 40 size jets at 2.5 turns out and see how the bike copes.
post #35 of 38 (permalink) Old 12-18-2012, 04:41 AM Thread Starter
Regapped one of my plugs to right at .8mm. Messed with the mixture screws again and have 'em right at around 2 turns out.
Bike starts right up on a 50-degree day and picks up on the enrichener very nicely. I'll leave it on the enrichener for a half a mile and then push it in and the bike will settle into a nice steady idle.
Still stumbles now again with hesitation at part throttle, but it's running much much better.
post #36 of 38 (permalink) Old 12-18-2012, 09:05 AM
Keep in mind it wont reach normal operating temperature for at least 15 - 20 minutes and the odd stumble can be expected until then. It's no good setting the mixtures to run well with a cold engine or it'll be too rich when hot.
denbow is offline
post #37 of 38 (permalink) Old 12-18-2012, 01:08 PM
Main Motorcycle: 2014 Scrambler
bluesforchallah's Avatar
That's about where I'm at now as well. I have a spare igniter and P/U coil that I want to try for nits-n-giggles, but being wet/cold, not sure when I'll have an opportunity to do that. If I do, I'm still going to do one at a time so I can eliminate either one or both as possible causes.
Did you ever crack your alternator cover to check the gap on the P/U coil?
I'm just curious if either running Iridium plugs or simply indexing the plugs wouldn't take care of the occasional hiccup or stumble at dead stop idle.
Chris / RudeBoy BIR #309
2014 Scrambler: Arrow 2-1 high pipe. TTP Tune 4 with Breathe airbox cover no baffle.
Past rides:2008 T100, 1975 Honda CB400/4, 1989 Honda GB500, 1965 Honda CB450 Black Bomber, 1972 BSA A75 Rocket3
bluesforchallah is online now
post #38 of 38 (permalink) Old 12-18-2012, 06:05 PM Thread Starter
I've decided to wait on that job until my next oil change (in about 3000 miles).
Ignition Coil Wiring Nigle Trophy 14 08-20-2012 02:16 PM
ignition coil? jsprinter Sprint Forum 4 06-04-2012 09:15 PM
Ignition coil order muchelneybandit Hinckley Classic Triples 4 07-27-2011 05:18 PM
New pick-up coil, ignition coil, & ignitor. No Dice... Flyhalf_Keith Air Cooled Twins Technical Talk 22 04-18-2010 04:19 PM
bad ignition coil Hinckley Classic Triples 4 02-15-2004 01:11 PM
