Is it gapping, ignition coil, or something else? - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
post #11 of 38 (permalink) Old 12-06-2012, 11:46 PM Thread Starter
I have a feeling now that my problem may be the rubber diaphrams in the tops of the carburators. People seem to have trouble refitting them and I simply dropped them in and screwed the tops back on. Are they supposed to fit in a groove somehow because I never noticed that when I had them off the carbs.
luckyduck is offline
post #12 of 38 (permalink) Old 12-07-2012, 12:00 AM
Main Motorcycle: 2014 Scrambler
bluesforchallah's Avatar
Yes. I normally take the flat end of a small allen wrench and use it to carefully seat the edge of the diaphragm into it's groove, then carefully bolt the caps back down.
Chris / RudeBoy BIR #309
2014 Scrambler: Arrow 2-1 high pipe. TTP Tune 4 with Breathe airbox cover no baffle.
Past rides:2008 T100, 1975 Honda CB400/4, 1989 Honda GB500, 1965 Honda CB450 Black Bomber, 1972 BSA A75 Rocket3
bluesforchallah is offline
post #13 of 38 (permalink) Old 12-07-2012, 12:29 AM Thread Starter
Gotcha! Well that might be my problem right there. I never fitted the diaphram back into the groove.
post #14 of 38 (permalink) Old 12-07-2012, 10:23 AM
Main Motorcycle: GasGas TXT Pro Trials
Bron-Yr-Aur's Avatar
Other Motorcycle: KTM 200 XC 2T
Extra Motorcycle: Kawasaki KX250 2T
Just know that it doesn't really snap or click into place, it more just lies there. Make sure you see all the way around and that it won't get pinched, and gently replace spring and carb top. Any little bump can move it, thereby pinching it. What I look or feel for is, as I drop the top onto the carb, I get on eye level with the lid and watch it drop onto the carb. It shouldn't offer resistance, just metal touches down to metal. If it wants to float and requires effort for the surfaces to mate, I've pinched it.
If you did pinch it, not all is necessarily lost. Inspect the pinch very closely, slightly stretching it in different directions to see if you tore the diaphragm. If not, carefully reinstall. If you did damage it, the cheapest I've found (don't ask me how I know ) was Bike Bandit. Around $75 each, and that was a savings of $30 (!) each over my dealer.
Bron-Yr-Aur Garage
Bron-Yr-Aur is offline
post #15 of 38 (permalink) Old 12-07-2012, 11:30 AM
+1, and also make sure the spring is located properly around the two lugs inside the cover as it's replaced.
denbow is offline
post #16 of 38 (permalink) Old 12-07-2012, 12:08 PM
Also, make sure the hole at the bottom of the slide isn't obstructed by the foot of the spring spider.
post #17 of 38 (permalink) Old 12-07-2012, 05:51 PM Thread Starter
Checked the diaphragms today and they pop in and out of the groove without a problem. So no problems there.
I have a feeling it's either the pickup coil or the ignition coil. Getting a Nology coil tomorrow so we'll see what happens.
post #18 of 38 (permalink) Old 12-07-2012, 07:16 PM
I'd look more into your jetting first. Already denbow, redbird and fullplat have said you sound like you're running rich, so I'd explore that first. An off idle stumble sounds like a tuning problem to me. I'm no mechanic, so you may very well be right, but electrical problems from the parts you've mentioned usually leave riders sitting for a length of time. Usually best to eliminate the easy stuff before you go spending your hard-earned money.
Bron-Yr-Aur Garage
post #19 of 38 (permalink) Old 12-07-2012, 09:01 PM Thread Starter
Well indeed it was a fuel mixture screw problem. I was actually too lean. After much trial and error, it seems as if 2.5 turns out on each produces very little off-idle coughing back through the airbox. At about 1.5 turns, I was getting repeatable cough-backs through the air box that I could feel when placing my hand at the airbox opening.
Could my valves also need an adjustment? I'm at about 11300 miles.
post #20 of 38 (permalink) Old 12-07-2012, 09:48 PM
Mine did at it's 12,000 mile service.
Ignition Coil Wiring Nigle Trophy 14 08-20-2012 02:16 PM
ignition coil? jsprinter Sprint Forum 4 06-04-2012 09:15 PM
Ignition coil order muchelneybandit Hinckley Classic Triples 4 07-27-2011 05:18 PM
New pick-up coil, ignition coil, & ignitor. No Dice... Flyhalf_Keith Air Cooled Twins Technical Talk 22 04-18-2010 04:19 PM
bad ignition coil Hinckley Classic Triples 4 02-15-2004 01:11 PM
