front spring size difference for magwheel bonnie ? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 11 (permalink) Old 12-03-2012, 03:51 PM Thread Starter
Main Motorcycle: 2011 Bonneville Elizabeth
dam1's Avatar
Other Motorcycle: wish i could !!!
Hello,
Could you tell me if there is a difference in size between the mag and the spoke wheel bonneville front the fork springs ?
Any other differences , spacers ?
I am planning to get progressives springs , i see different offers for different model and years of bonneville on Ebay , so i just want to make sure before ordering.
Any feed back for Wilbers springs ?
Thanks a lot
D1
dam1 is offline
post #2 of 11 (permalink) Old 12-03-2012, 04:05 PM Thread Starter
dam1's Avatar
another question ,
do i have to put the spacer back in with the new spring ? to cut it ?
dam1 is offline
post #3 of 11 (permalink) Old 12-03-2012, 04:22 PM Thread Starter
dam1's Avatar
i found some infos on bellacorse but nothing precise:
http://www.bellacorse.com/bcc163.htm
dam1 is offline
post #4 of 11 (permalink) Old 12-04-2012, 01:54 PM
Main Motorcycle: Bonny SE-R dream bike
Other Motorcycle: 2009 Bonny SE
Extra Motorcycle: 2013 S10
I ride an 09 Bonny SE.
About a year ago, I installed Ikon progressive springs. The ride improved over stock, but if I were to do over, I'd go with Sonic Springs (straight rate) dialed in for my weight and riding style.
I put Sonics on my Wee and like the ride better than the progressive type.
Sonic website has a pretty convincing argument under the Tech Articles explaining why straight rate is now favored over progressive rates.
http://www.sonicsprings.com/catalog/...ch_article.php
No affiliation with Sonic...
NFE
No False Enthus is offline
post #5 of 11 (permalink) Old 12-04-2012, 02:11 PM Thread Starter
dam1's Avatar
Thanks for your answer No False Enthus,
I get what you are saying , but you have to moderetly believe what companies are saying.
I show you what PATRIOT say about straight springs:
Straight Rate Springs have the same rate every inch that they are compressed, which is fine on flat super smooth roads, but they lack the power of the multirate springs to handle today’s unpredictable road conditions. In Multirate Springs, each inch the springs are compressed the rate increases which results in a spring that absorbs small bumps, yet is firmer at the bottom for bigger ones. That gives you a more comfortable ride whether you are on a smooth or rough road.
dam1 is offline
post #6 of 11 (permalink) Old 12-10-2012, 02:40 PM
Main Motorcycle: 2012 base bonneville
Other Motorcycle: 2013 victory hammer
straight rate springs are cheaper to fabricate, $$$$ usually has a lot of influence on products recommended especially when said product being advertised is also sold by same, many companies spend more $$$ on promotion while actually making an inferior product IMO
rodhotter is offline
post #7 of 11 (permalink) Old 12-11-2012, 07:50 AM
Main Motorcycle: 2004 Thruxton
Other Motorcycle: 1954 BMW R25/3
Extra Motorcycle: 1971 CB350
Originally Posted by No False Enthus View Post
....if I were to do over, I'd go with Sonic Springs (straight rate) dialed in for my weight and riding style..
+1.
The problem I have with progressive springs is that the initial spring rate is too soft and the high spring rate is too firm. This is the result of trying to fabricate a 'one size fits all' spring.
Anyway, the typical outcome of dialing in the proper amount of initial sag on a progressive spring often takes out so much of the softer rate portion of the spring that you are into the firmer rate on even moderate bumps. Get whatever you want, but there is a reason why folks go from stock springs to progressive springs, only to upgrade the forks further to improve compliance (e.g. emulators)...these later upgrades generally result in kicking the progressive spring to the curb.
Regards,
--Rich
beemerrich is offline
post #8 of 11 (permalink) Old 12-12-2012, 11:32 AM
yes one-size-does not fit all, i believe thats where the $$$ comes in, cutting manufacturing costs adds profit and sometime a lower price, in the past i found that the better quality and correct fitment for YOU is the best buy. thats where this forum helps, granted opinions vary but usually when most people agree one way or another results are usually good. with varying rider weights and preferred riding styles + comfort levels motorcycle suspension setups are a crap shoot!!! unless custom made for YOU!!!!
post #9 of 11 (permalink) Old 12-12-2012, 12:54 PM
Main Motorcycle: Two wheeled
Retro-Racer's Avatar
Other Motorcycle: several
Extra Motorcycle: next one
One size does not fit all... but is a much better solution for street riding vs. closed course (track) use. Single rate springs are ideal for a perfectly smooth race track and can be better matched to a specific rider's weight. However, on public roads which vary from silky smooth to near lunar surface-like with pot holes, speed bumps, cracks, uneven pavement and such, progressively-wound (or "rising rate" if you prefer) springs are a better solution.
On the street, when a bike hits a bump at speed, single rate spring are more prone to bottom-out resulting in a hard jolt and possible instability. The same bike & bump using progressively-wound springs will not have the same sever jolt and will not bottom-out nearly as quickly as the single rate springs.
Most sport bike suspension specialists are so myoptically focused on race track prep and (understandably) they sell what they understand. The street is a much different beast and should be properly outfitted accordingly.
/M
"With integrity, nothing else matters. Without integrity, nothing else matters."
Retro-Racer is offline
post #10 of 11 (permalink) Old 12-12-2012, 01:07 PM
Main Motorcycle: Triumph Thruxton EFi
Other Motorcycle: Yamaha R1, Honda CB1000R
Ultimately the only reason to use progressive springs in our bikes is because the damping is somewhat medieval and really it is a band-aid which treats symptom rather than cause. I've found Intiminators very effective even with the standard springs (whch are probably a bit light for my weight) some of the cartridge systems such as Biturbo are apparently even better
GDCobra is offline
I didn't appreciate the size difference between Bonnie and Speedy ohiorider Air Cooled Twins Talk 18 12-14-2012 07:10 PM
Front spring spacer size sonicboom Air Cooled Twins Technical Talk 21 08-10-2012 03:48 AM
GT Front spring size taximan62 Sprint Forum 3 06-15-2012 04:24 AM
weak magwheel centerstand spring tdisme Air Cooled Twins Technical Talk 2 07-12-2011 09:22 AM
front rim size difference in ride handling sodapop Air Cooled Twins Talk 7 04-02-2009 08:04 PM
