Tool Kit? - Page 3 - Triumph Forum: Triumph Rat Motorcycle Forums
post #21 of 25 (permalink) Old 12-03-2012, 08:39 PM Thread Starter
Main Motorcycle: Triumph Bonneville T100
Originally Posted by Aussie_T100 View Post
The following is a tool list & their applications that I compiled for my 2008 carbed T100 with some mods.
Hinkley Bonneville Tool List and their uses:-
3mm Allen key:- Float bowls*, Carby tops*, front guard stays.
4mm Allen key:- Carby bellmouths*, flyscreen*.
5mm Allen key:- Seat, Grab rail*, Number plate*, Front guard, Switch gear, gear lever.
6mm Allen key:- Rear M/cyl, H/bar clamp, front axle clamp, chain guard, muffler clamps, cam cover.
8mm Allen key:- Foot peg brackets, triple tree clamps, frame down tubes, center stand*, exhaust header mounts, brake pedal.
Medium Phillips screwdriver:- Battery terminals, M/cyl reservoir lids, Air filter clamps, Carby clamps, headlight.
Medium flat screwdriver:- Side covers.
Small flat screwdriver:- Carby jets.
8mm socket:- Fuel tank, oil cooler, engine covers, rectifier, air filter, starter motor, Chain adjusters.
10mm socket:- front guard brackets, igniter, tailight, cam oil feed pipe, starter terminal, solenoid terminals, clutch bolts.
12mm socket:- Top engine brace, rear shocks, headlight, front caliper, exhaust headers, breast plate, horn.
13mm socket:- Sump plug.
14mm socket:- H/bar risers, rear caliper, Centre stand*, rear sprocket.
16mm socket:- Engine mounts.
17mm socket:- Engine mounts, sidestand, swingarm.
18mm deep socket:- Sparkplugs.
19mm socket:- Oil cooler lines.
1/4" socket:- fuel line clamp*.
9/16" socket:- Brake line banjo bolts.
8mm open end / ring spanner:- Inlet manifold.
10mm open end / ring spanner:- Number plate*, Throttle cables.
12mm open end / ring spanner:- Fork brace, rear footpegs, clutch cable, rear shocks.
13mm open end / ring spanner:- Engine brace, muffler brackets*.
17mm open end / ring spanner:- Sidestand, engine mounts.
19mm open end / ring spanner:- Front axle, rear axle.
22mm open end / ring spanner:- Oil pressure switch.
24mm open end / ring spanner:- Front axle, rear axle, oil cooler lines, swingarm.
T30 Torx key:- Chain guard, rear mudguard, cam caps, ignition pickup, sidestand switch.
100mm adjustable wrench:- Substitute for 9/16" socket etc.
200mm adjustable wrench:- Substitute for 16mm socket & 22mm open end etc.
Ratchet handle(s), long & short extensions as required for sockets (1/4" & 3/8").
Small pliers for electrical work etc.
Items marked with an * are unique to my bike because of a fitted accessory or aftermarket item.
****! My Man...
That, is what you call a reply to a post. I so owe you a beer or 19.
Thanks brother.
d.
dustinsleeping is offline
post #22 of 25 (permalink) Old 12-03-2012, 09:45 PM
Main Motorcycle: Bonnie T100 of course
Other Motorcycle: I wish
Extra Motorcycle: Yes please
Originally Posted by dustinsleeping View Post
****! My Man...
Thanks brother.
d.
You are welcome, if I ever make the journey across the Pacific and find myself in LA I'll take you up on the beer.
Aussie_T100 is offline
post #23 of 25 (permalink) Old 12-03-2012, 10:18 PM
Main Motorcycle: 07 Thruxton
Mekagojira's Avatar
Extra Motorcycle: '75 CB750 caffinated
Props AussieT100 !
I was also looking for a comprehensive list .
Mekagojira is offline
post #24 of 25 (permalink) Old 12-03-2012, 11:04 PM
DUG
Main Motorcycle: T-100 2004
DUG's Avatar
Location: West of the Great Divide, Northern NSW, Australia
Thumbs up Great answer
Hi AussieT100
You have now set the bar as far as answering threads, congratulations, you win a free set of steak knife's.
I've just changed the brake lines and found the original bolts a wee bit hard to get out, useing metric as I was told all bolts were that,I thought some one had rounded of the tips, till I checked out my mate's yesturday and saw his wwere the same
The bolts that came with the HEL line's were no probs.
Cheers Doug
DUG is offline
post #25 of 25 (permalink) Old 12-03-2012, 11:21 PM
Main Motorcycle: '11 Speed Triple
Moogs's Avatar
Other Motorcycle: '13 Mag Wheel Bonnie
In case you drop your scissors into somewhere, down there.
Whomever said all good things in moderation certainly never rode a bad ass Bonneville
Moogs is offline
Carb adjustment tool - D shaped tool Gary_spain Air Cooled Twins Technical Talk 0 03-25-2012 05:53 AM
D-tool MARKO65 Air Cooled Twins Technical Talk 5 01-29-2012 10:05 PM
Favourite/Most useful Tool in your Tool Chest DEcosse Speed Triple Forum 21 11-27-2011 11:54 PM
tool set mjsmilford Club Cafe' 11 06-02-2007 10:44 AM
Tool Talk: Spark Gap Tool Preference? 00wabbit Maintenance & Workshop Talk 6 01-15-2005 02:02 PM
