Tool Kit? - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
post #11 of 25 (permalink) Old 12-03-2012, 03:38 PM
Main Motorcycle: 2013 Rocket 3 Touring
norton74's Avatar
Other Motorcycle: 2013 Torphy SE
Extra Motorcycle: 2012 Bonneville T100
Invest in the Triumph oil filter removal tool. It is used with a standard 3/8" drive ratchet.
You'll save yourself a lot of grief.
norton74 is online now
post #12 of 25 (permalink) Old 12-03-2012, 03:41 PM
Main Motorcycle: 2003 Bonnie
Demonic's Avatar
Other Motorcycle: 2003 Speed Triple 955i
Extra Motorcycle: Monkeybike!
And a dremel! Every man needs a dremel!
If knowledge can create problems, it is not through ignorance that we can solve them.
Isaac Asimov
Demonic is offline
post #13 of 25 (permalink) Old 12-03-2012, 03:47 PM
Why a Dremel unless the OP is thinking of doing some airbox mods or the like ?
denbow is offline
post #14 of 25 (permalink) Old 12-03-2012, 04:08 PM
Main Motorcycle: Bonneville 2013
mr.broad's Avatar
Other Motorcycle: Ducati Monster
Don't forget the most important thing in the toolkit- cable ties. You just never know when you'll need them...
mr.broad is offline
post #15 of 25 (permalink) Old 12-03-2012, 05:03 PM
Demonic's Avatar
Because every man needs one. Once you've got one, you will find infinite uses for it....
Isaac Asimov
Demonic is offline
post #16 of 25 (permalink) Old 12-03-2012, 05:16 PM
Ahhh, I see, so they're comparable to condoms ?
denbow is offline
post #17 of 25 (permalink) Old 12-03-2012, 05:18 PM
DUG
Main Motorcycle: T-100 2004
DUG's Avatar
Location: West of the Great Divide, Northern NSW, Australia
OUCH!!!
DUG is offline
post #18 of 25 (permalink) Old 12-03-2012, 05:35 PM
Askari's Avatar
Kit
Buy a mid range quality tool kit. Sockets, spanners,screwdrivers, allen keys plus a few other odds and sods. All are metric on bonnie. Kits tend to work out a lot cheaper than buying individually You will need to add bits as you go, like for the rear axle i use a whitworth socket!
Just dont buy cheap as quality will suffer and soft allen keys are worthless!
A haynes manual is good if you are new to wrenching. The triumph w/shop manual gives you all you need.
Askari is offline
post #19 of 25 (permalink) Old 12-03-2012, 05:35 PM
Yup, very useful for putting on your velocity stack or barrel end to keep the rain out !!!!
denbow is offline
post #20 of 25 (permalink) Old 12-03-2012, 08:17 PM
Main Motorcycle: Bonnie T100 of course
Other Motorcycle: I wish
Extra Motorcycle: Yes please
The following is a tool list & their applications that I compiled for my 2008 carbed T100 with some mods.
Hinkley Bonneville Tool List and their uses:-
3mm Allen key:- Float bowls*, Carby tops*, front guard stays.
4mm Allen key:- Carby bellmouths*, flyscreen*.
5mm Allen key:- Seat, Grab rail*, Number plate*, Front guard, Switch gear, gear lever.
6mm Allen key:- Rear M/cyl, H/bar clamp, front axle clamp, chain guard, muffler clamps, cam cover.
8mm Allen key:- Foot peg brackets, triple tree clamps, frame down tubes, center stand*, exhaust header mounts, brake pedal.
Medium Phillips screwdriver:- Battery terminals, M/cyl reservoir lids, Air filter clamps, Carby clamps, headlight.
Medium flat screwdriver:- Side covers.
Small flat screwdriver:- Carby jets.
8mm socket:- Fuel tank, oil cooler, engine covers, rectifier, air filter, starter motor, Chain adjusters.
10mm socket:- front guard brackets, igniter, tailight, cam oil feed pipe, starter terminal, solenoid terminals, clutch bolts.
12mm socket:- Top engine brace, rear shocks, headlight, front caliper, exhaust headers, breast plate, horn.
13mm socket:- Sump plug.
14mm socket:- H/bar risers, rear caliper, Centre stand*, rear sprocket.
16mm socket:- Engine mounts.
17mm socket:- Engine mounts, sidestand, swingarm.
18mm deep socket:- Sparkplugs.
19mm socket:- Oil cooler lines.
1/4" socket:- fuel line clamp*.
9/16" socket:- Brake line banjo bolts.
8mm open end / ring spanner:- Inlet manifold.
10mm open end / ring spanner:- Number plate*, Throttle cables.
12mm open end / ring spanner:- Fork brace, rear footpegs, clutch cable, rear shocks.
13mm open end / ring spanner:- Engine brace, muffler brackets*.
17mm open end / ring spanner:- Sidestand, engine mounts.
19mm open end / ring spanner:- Front axle, rear axle.
22mm open end / ring spanner:- Oil pressure switch.
24mm open end / ring spanner:- Front axle, rear axle, oil cooler lines, swingarm.
T30 Torx key:- Chain guard, rear mudguard, cam caps, ignition pickup, sidestand switch.
100mm adjustable wrench:- Substitute for 9/16" socket etc.
200mm adjustable wrench:- Substitute for 16mm socket & 22mm open end etc.
Ratchet handle(s), long & short extensions as required for sockets (1/4" & 3/8").
Small pliers for electrical work etc.
Items marked with an * are unique to my bike because of a fitted accessory or aftermarket item.
Aussie_T100 is offline
Carb adjustment tool - D shaped tool Gary_spain Air Cooled Twins Technical Talk 0 03-25-2012 05:53 AM
D-tool MARKO65 Air Cooled Twins Technical Talk 5 01-29-2012 10:05 PM
Favourite/Most useful Tool in your Tool Chest DEcosse Speed Triple Forum 21 11-27-2011 11:54 PM
tool set mjsmilford Club Cafe' 11 06-02-2007 10:44 AM
Tool Talk: Spark Gap Tool Preference? 00wabbit Maintenance & Workshop Talk 6 01-15-2005 02:02 PM
