Rear Brakes Stopped Working - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 25 (permalink) Old 12-02-2012, 03:41 AM Thread Starter
Main Motorcycle: 2010 Bonneville
So I had a funny one today whilst riding through heavy traffic for about 6kms. It was stop start and tight so I rode the read brake for a bit, however after a while it stopped working! Worth mentioning it was also around 34 degrees out.
If I pressed the brake I could push the lever all the way down with no resistance at all.
After that I stopped filtering and just used my front brake, after another 20 min the rear brake comes back to life and works again.
Whats the deal? A 2008 Bonneville doesn't have electronic brakes?
Mr*Beaver is offline
post #2 of 25 (permalink) Old 12-02-2012, 04:49 AM
Main Motorcycle: Thruxton
plodalong's Avatar
Other Motorcycle: 08 Bonneville efi
Most likely moisture of possilby air in the brake fluid. Moisture (water) is absorbed into the fluid and lowers the boiling point of the fluid creating vapour bubbles which are compressible and either gives more lever movement or stop the brakes working completely when they get hot. Time for fluid replacement, Ment to be replaced every couple of years.
07 thrux,breathe,Dna airfilter,airbox X restrictor,135 mains,tp +3 ignitor,yss emulators,hp springs, Bitubo shocks,pingle steering damper,D9 layflat,3" rise clipons,corbin seat, tt350 taillight,alloy indicators.shorai battery,Changes daily
plodalong is offline
post #3 of 25 (permalink) Old 12-02-2012, 09:41 AM
Main Motorcycle: 2013 Rocket 3 Touring
norton74's Avatar
Other Motorcycle: 2013 Torphy SE
Extra Motorcycle: 2012 Bonneville T100
You may have had the rear master cylinder piston hang up due to corrosion. Probably not the case; but, it's what happened to my '79 Bonneville.
As a precaution, I would flush the brake fluid and bleed the brakes both front and rear.
norton74 is offline
post #4 of 25 (permalink) Old 12-02-2012, 01:37 PM
Main Motorcycle: Ducati Monster S4RS
Hypurone's Avatar
Other Motorcycle: 2010 Thruxton RS
You are on the right track. The M/C probably experienced a "by-pass" due to an internal cup sealing or check valve issue. Hence the intermittent workings... Flushing can help if the system's fluid is degraded, contaminated or has moisture etc. But once it happens it usually only gets worse and happens more often. I would cut to the chase and replace the M/C flush the fluid and call it a day...
Chuck's Garages Thruxton
Camaro
Monster
'10 Thruxton RS 944cc - In the Faster Color
"You Were Really Flyin' When I Passed You Back There!"
Hypurone is online now
post #5 of 25 (permalink) Old 12-02-2012, 05:50 PM
Main Motorcycle: 05 T100
Sounds like boiling brake fluid to me too. Has it ever been changed? As Plodalong said, it should be changed every 2 years as a matter of course irrespective of mileage. Try the simple (and cheap) stuff first, before making it more complicated than it probably is.
Paul.
Herts. UK
PAAS is offline
post #6 of 25 (permalink) Old 12-02-2012, 05:53 PM
Main Motorcycle: 2003 Bonnie
Demonic's Avatar
Other Motorcycle: 2003 Speed Triple 955i
Extra Motorcycle: Monkeybike!
Yup, spend a couple quid (dollars, whatever) on fluid, rather than hundreds (or whatever they cost) on new parts...
If knowledge can create problems, it is not through ignorance that we can solve them.
Isaac Asimov
Demonic is offline
post #7 of 25 (permalink) Old 12-02-2012, 06:16 PM
Main Motorcycle: 2007 Bonnie T100
bonza's Avatar
Other Motorcycle: Jeep Wrangler
with the amount of rain and humidity they get in Brisbane I'm betting moisture in the brake fluid as plodalong says. change the fluid on both brakes
2007 Tuxedo T100.
Dom Tourers, TTP breathe, DNA filter,baffle gone, 40/140/1 shim 3 turns, TTP igniter tune, Hagon Nitros, Thruxton Bars, Halcyon bar end mirrors, Pingel fuel valve, Monza gas cap, Burton seat, Avon Roadriders
bonza is offline
post #8 of 25 (permalink) Old 12-03-2012, 05:32 AM Thread Starter
I'm gona roll with brake fluid as first course. I didn't get any service history with the bike, although I know some things have been done, this isn't one of them.
It's just annoying as I was planning on doing it along with the pads in a couple of weeks, but haven't sourced the pads... anyone know where I can get some pads from quickly without paying premium prices?
post #9 of 25 (permalink) Old 12-03-2012, 05:38 AM
Main Motorcycle: 2006 BONNEVILLE T100
RICHW's Avatar
Other Motorcycle: 1999 TITAN PHOENIX
On a 2008 I would also check your rear pads - they tend to wear out.
please keep your distance
• 26 B0NNEVILLE T1
my garage pics and specs
RICHW is offline
post #10 of 25 (permalink) Old 12-03-2012, 07:22 AM Thread Starter
rear pads are *fine* at the mo - this isn't the issue in this case.
Tachometer stopped working pochie Classic, Vintage & Veteran 5 09-05-2011 10:01 AM
Rear Stop Light suddenly stopped working rnexussix Speed Triple Forum 7 06-04-2010 08:52 PM
Tach stopped working Tonka Air Cooled Twins Technical Talk 4 09-01-2009 05:01 AM
Speedometer stopped working DanR Air Cooled Twins Technical Talk 3 02-11-2008 10:30 AM
RS speedo stopped working jellero Sprint Forum 7 06-16-2005 09:55 AM
