Engine flooded. What to do? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 11 (permalink) Old 12-01-2012, 06:55 PM Thread Starter
Had another fuel leak today. Petcock was left on and my carbs filled with fuel as did my air filter. The engine won't turn over at all. The battery has power.
What are my next steps? Remove spark plugs and turn the engine over a few times?
Can I leave this job for a few days until the weather clears up?
luckyduck is offline
post #2 of 11 (permalink) Old 12-01-2012, 07:06 PM
Main Motorcycle: GasGas TXT Pro Trials
Bron-Yr-Aur's Avatar
Other Motorcycle: KTM 200 XC 2T
Extra Motorcycle: Kawasaki KX250 2T
Your cylinder(s) may be filled with fuel. Time to change the oil again
Check by removing spark plugs. A siphon can be had anywhere for only a few bucks.
Bron-Yr-Aur Garage
Bron-Yr-Aur is offline
post #3 of 11 (permalink) Old 12-01-2012, 07:12 PM Thread Starter
So ******n annoying. I think my floats are sticking and it seems like if I let them sit then they stick but I use the bike daily then they don't stick.
post #4 of 11 (permalink) Old 12-01-2012, 07:43 PM
Turning the petcock off would be a good habit to get into.
denbow is offline
post #5 of 11 (permalink) Old 12-01-2012, 07:58 PM Thread Starter
Yeah but it's just treating the symptoms. A stuck float is a stuck float and I left the petcock on this time to actually see if I get the same problem again.
post #6 of 11 (permalink) Old 12-01-2012, 08:06 PM Thread Starter
Could I also be flooding due to a degraded mixture screw o-ring?
post #7 of 11 (permalink) Old 12-01-2012, 10:10 PM
Main Motorcycle: 2012 Rocket III Roadster
RickMcCl's Avatar
Other Motorcycle: N/A
I turn mine off every time I get off the bike; it's an old, old habit that I don't want to lose.
Good luck,
Rick
RickMcCl is offline
post #8 of 11 (permalink) Old 12-02-2012, 08:50 AM
They don't normally flood unless there's some crap got into a float or they've been tinkered with by someone that doesn't know what they're doing.
I suggest drying up the leaked fuel, ride as normal and remember to turn the fuel tap off after each ride. Further investigate if it's still flooding.
denbow is offline
post #9 of 11 (permalink) Old 12-02-2012, 09:10 AM
Main Motorcycle: Thruxton
I think first step is still drain the oil because it may be full of gas. Then figure out what the problem is. If you pull the float bowls off you may find the problem.
John83 is offline
post #10 of 11 (permalink) Old 12-02-2012, 03:17 PM
Main Motorcycle: Bonneville
Other Motorcycle: Vespa PX200
Extra Motorcycle: Kawasaki GTR and Sidecar
Unhappy
Hello
If you think you have a cylinder with a lot of fuel in it, do not tryand and start it with the spark plugs in you may bend a con rod.
Good Luck
Barry
threewheelsuk is offline
Battery - Flooded vs AGM vs Gel SLY DVL Sprint Forum 25 12-02-2012 10:59 PM
Flooded in NYC Lankyq The Welcome Center 3 11-03-2012 10:46 PM
Airbox Flooded!!! signature65 Air Cooled Twins Technical Talk 3 03-23-2010 09:38 PM
Flooded Trophy TXTrophy Trophy 21 11-07-2007 09:32 PM
Starting a flooded engine?? Fuse location? jellero Sprint Forum 11 12-17-2005 04:55 PM
