Bonneville rear brake job - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 4 (permalink) Old 11-30-2012, 10:04 PM Thread Starter
Main Motorcycle: Triumph T100
Well I bought a bike a few weeks ago a want to get it ready for the spring. The brakes and rotor on the back are shot so I am replacing. I am going to drop the back wheel to replace the rotor. Looking for any tips or Gotcha's I need to watch out for. I was looking at the EBC rotor and brake pads for replacement.
2006 Triumph T100
Tagerine Orange
ggrimm01 is offline
post #2 of 4 (permalink) Old 11-30-2012, 11:43 PM
Main Motorcycle: '03 Triumph Bonneville
Clean up the caliper, Spiegler braided lines are a nice upgrade and of course a fresh dose of DOT4 fluid will do nicely... You should consider brake line and fluid replacement for the front too... It's not that expensive. and the Spiegler lines are a much higher quality than the stock ones...
Some folks like using the organic pads on the rear, as they have less bite and are hard to lock up... I've always used the sintered metal HH pads on both ends and haven't had a problem...
And yes, EBC is good stuff...
SCbonneville is offline
post #3 of 4 (permalink) Old 12-01-2012, 01:18 AM
Forchetto's Avatar
Prop's brake pad replacement thread can't be beat. Lots of photos and advice:
http://www.triumphrat.net/twins-tech...placement.html
Forchetto is offline
post #4 of 4 (permalink) Old 12-01-2012, 01:47 PM
tsmgguy's Avatar
Other Motorcycle: 2007 Ducati GT1000
Extra Motorcycle: 2003 Triumph T100
HH pads may give more "bite" than you want. It's an individual taste thing.
The Haynes manual is very helpful for jobs of this kind.
You might consider "quick bleeder" valves/plugs from Newbonneville.com. These make brake bleeding so much faster, cleaner and easier because you can close the valve with the bleed line still attached. These are a permanent installation and simply replace the OEM plugs.
Photo: Ducati GT1000 at Utah's Bonneville Salt Flats
tsmgguy is online now
T100 Bonneville rear brake freelander Air Cooled Twins Technical Talk 6 04-21-2016 05:48 PM
Bonneville Rear Brake Anne Maintenance & Workshop Talk 2 05-09-2006 07:29 AM
Bonneville T140 Rear Brake Problems crazypierre Maintenance & Workshop Talk 7 05-04-2005 07:21 PM
