What fell off my Scrambler? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 12 (permalink) Old 11-30-2012, 12:18 AM Thread Starter
Main Motorcycle: 2012 Scrambler
tvscum's Avatar
I am in the process of removing EVAP, O2 and AI all at once. I just notices this small, square, rubber gasket underneath my 2012 Scrambler. Is about the size of a dime (US currency) Any idea what it fell off of? Maybe a gasket for one of the electrical connections I unplugged?
Current: 2012 Scrambler, Bitubo forks, YSS shocks, Arrow 2-to-1, 33mm DB killer, TTP tune #4, Breathe, DNA filter; O2, AI, Airbox baffle, EVAP removed, Up-N-Over, Pivot Pegs, Ventura rack.
Past: '83 Honda XR500; '84 Honda XL600; '86 Yamaha XT350
tvscum is offline
post #2 of 12 (permalink) Old 11-30-2012, 12:57 AM
Main Motorcycle: 2013 triumph bonneville
looks like a seal for a multi pin plug especially since its that small.
villageidiot327 is offline
post #3 of 12 (permalink) Old 11-30-2012, 02:27 AM Thread Starter
tvscum's Avatar
Here's a better shot. All I can think of is it fell off the multipin connection to the EVAC canister when I was unplugging it.
WAIT A MINUTE!!!... look what else fell off my Scrambler!
tvscum is offline
post #4 of 12 (permalink) Old 11-30-2012, 04:02 PM
Main Motorcycle: 2010 Triumph Scrambler
Yep, it fits inside one of the connectors. =) Based on the size, I'm guessing it's the one for the EVAP canister. That connector (unless you unpinned it from the ECU like I did) should still be on your bike. Flip it over and see if there's a clean spot where a seal was.
casida is offline
post #5 of 12 (permalink) Old 11-30-2012, 04:24 PM Thread Starter
tvscum's Avatar
I already wrapped the connector in shrink tubing, but it looks like it might be the right size. Hey, how hard was it to disconnect it from the ECU? Does it just plug in on the top side, or is it hard wired into the main harness?
tvscum is offline
post #6 of 12 (permalink) Old 11-30-2012, 07:08 PM
Mm, you have to split the harness and run up one side to the ECU. The other side connects to a shared ground, and that needs to be unwrapped and the one wire clipped, then the other goes into the ECU. Pulling the pin requires you unclip the purple retainer clip at the back, then use a pin removal tool or a small screwdriver to gently pry up the plastic pin retainer and slide the pin out.
Pretty easy if you're used to doing such things, but not really worth it unless you're pulling looming for lots of other stuff, like, say, AI, alarm connectors and both O2 sensors. I'm super, super picky about my wiring, though, so if it doesn't drive you nuts like it does me, then I don't recommend it. =)
casida is offline
post #7 of 12 (permalink) Old 11-30-2012, 08:56 PM Thread Starter
tvscum's Avatar
errr... I'll pass. I may have to re-install all that crap someday. After all, I do live in California! Thanks for the info!
EDIT: I see you're in Cali too!
tvscum is offline
post #8 of 12 (permalink) Old 11-30-2012, 09:49 PM
i dont understand why you got rid of the O2 sensors?
does the bike not need them for proper air fuel ratio? whats the deal?
post #9 of 12 (permalink) Old 12-01-2012, 12:24 AM
Main Motorcycle: 2010 Bonneville T100
Other Motorcycle: 2007 150cc Retro-scooter
Nope, once the AI is gone there's no need for them.
Owenbrau is offline
post #10 of 12 (permalink) Old 12-01-2012, 12:55 AM
Main Motorcycle: Bonneville black 2007
sonicboom's Avatar
Other Motorcycle: Honda CBR600RR
Extra Motorcycle: Honda CB500F
Did you remove a baffle from the exhaust system? Is that what that part in the top right hand corner is? HOw easy did that remove?
sonicboom is offline
07 TBA Fell Over....Looking for TIPS BCTriumph Air Cooled Twins Technical Talk 12 12-07-2012 01:32 AM
What fell out of my Scrambler headlight? tvscum Air Cooled Twins Technical Talk 2 08-25-2012 12:56 AM
Ouch I fell down... yakoo11 Triumph SuperSports 14 10-27-2009 03:32 AM
Bike fell over!!!! Duality Street Triple Forum 0 04-01-2009 03:09 PM
Damn! She fell over.......! dubvmv Sprint Forum 13 08-04-2008 12:55 AM
