Longer throttle cables for wider bars - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 6 (permalink) Old 11-29-2012, 09:39 AM Thread Starter
R0B
Main Motorcycle: FJ1200
Other Motorcycle: building a custom bonnie
Extra Motorcycle: Bonnie with a sidecar
Hello, I've fitted some western bars on my scrambler, as as a result have fitted a new clutch cable from an America...........I also thought that I was going to fit some new throttle cables from the same, but have hit a problem........the fixings are different. My bike is a 2008 EFI scrambler, and the cable from the America are also EFI. I'll attach some pictures to show the differences......I'll add the America part numbers later, as they are in the garage. Has anyone fitted longer throttle cables to an EFI bike?, I presume that I'm going to have to change the throttle actuator?
Rob
ID:	57517   Click image for larger version
ID:	57518   Click image for larger version
R0B is online now
post #2 of 6 (permalink) Old 11-29-2012, 12:21 PM
triumphrat.net Vendor
Main Motorcycle: 2008 Bonnie Black Special
PieMan's Avatar
The Bonnie, America and Speedmaster have a combined throttle/brake housing where as the Scrambler and Thruxton have separate throttle and brake housings, this is where the difference is. It may be worth re-routing the throttle cable across the top of the engine and to the right side of the headstock and see if that gives enough extra length in the cables. Good luck.
Mike (UK)
04 Bonnie Black Special
PieMan is offline
post #3 of 6 (permalink) Old 11-29-2012, 02:33 PM Thread Starter
R0B
and I suppose the added bonus is that they will only fit 1" bars?
Cheers Rob
R0B is online now
post #4 of 6 (permalink) Old 11-29-2012, 11:31 PM
Main Motorcycle: '67 Rickmann Metisse
dkreidel's Avatar
Other Motorcycle: first bike: '64 Yamaha 80
Extra Motorcycle: Wish I kept: '69 Trident
Give Barnett a call; they will make you anything you need and will know exactly what to build if you tell them what you are doing/using.
EDIT: Oops, just noticed you are in UK so Barnett is probably not a good option
dk
'09 T100 50th Anniversary- Togas, Hagons, PC V
'09 T100 green/white- Togas; Hagons, PC III
'07 T100 tang/opal- Togas, Hagons, Sun rims (18" rear)
'06 Scrambler blue/white - Arrow 2>1; Sun rims 19" F&R, Maxxis DTR
'68 T120R - original owner
dkreidel is offline
post #5 of 6 (permalink) Old 11-30-2012, 05:26 AM
dk
Same advice but use Venhill engineering, Dorking , Surrey. You may have to send them the old cables with instructions for how much longer you need them. They will make up any new cables and hoses you need. Check their website they may have these cables already on their list in which case just specify the length you need.
Scooter Paul is offline
post #6 of 6 (permalink) Old 11-30-2012, 06:00 AM
Main Motorcycle: 2012 bonneville T100
Choprocker's Avatar
re route em to the outside of the fork legs
Choprocker is online now
Longer Cables tspapa Air Cooled Twins Technical Talk 3 08-21-2008 11:00 AM
Longer Cables tspapa Air Cooled Twins Technical Talk 2 12-19-2007 03:37 AM
Wider tires/longer life span? sharpshooter Air Cooled Twins Technical Talk 7 03-10-2007 08:38 PM
S4 high bars - longer throttle cable wanted neil1052 Triumph SuperSports 2 07-14-2006 04:22 PM
