Fuel filled airbox! Need direction. - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 6 (permalink) Old 11-28-2012, 03:54 PM Thread Starter
Today I walked up to my '01 Bonnie to find a rainbow river flowing downslope from the bike.
I removed the left-side cover and found that the airbox was filled with fuel and that it was dripping down onto the swingarm and then then the fuel would travel back along the swingarm and drip off onto the ground from the very end.
Conditions:
1. My petcock was turned to "on". I know, this is a bad habit. I usually remember to turn it to "off" but this time I didn't. Still, if everything is working correctly, it shouldn't get leak.
2. My choke/enrichener was about 1/4 to 1/2 the way out. Could this have caused the problem?
What I also found was that the little oil catchment tube under the airbox was filled with fuel. I pulled it out to drain the fuel from the airbox and stood the bike upright to get it all out. The leak was relatively slow, only about a drip a second off the end of the swing arm.
I was able to start the bike (it reluctantly came to life) and ride it home 3 miles where it now sits.
This seems like a float problem to me and I'm planning on pulling the carbs and measuring and adjusting my float levels asap. Is there any way to at least measure them when they are on the bike? I hate dealing with the throttle cable connections.
Anyways, I've attached pictures. Let me know if there is anything else I should look at. I looked at the fuel hose from the petcock and didn't notice any problems.
ID:	57492   Click image for larger version
ID:	57493   Click image for larger version
luckyduck is offline
post #2 of 6 (permalink) Old 11-28-2012, 04:25 PM
Main Motorcycle: GasGas TXT Pro Trials
Bron-Yr-Aur's Avatar
Other Motorcycle: KTM 200 XC 2T
Extra Motorcycle: Kawasaki KX250 2T
Was your bike parked with the rear downhill? Or how? I ask because if fuel made it into your cylinders, it could have (and probably did) drained down into the oil. If that happened, I wouldn't drive it again until you drain and replace the oil. Worst case scenario: you could spin a bearing=a lot of repair money. And yes, sounds like a stuck float to me.
Bron-Yr-Aur Garage
Bron-Yr-Aur is offline
post #3 of 6 (permalink) Old 11-28-2012, 04:50 PM
Main Motorcycle: 07 bonnie black
kartooo's Avatar
don't know about modern synthetic oils but in the old days with dino oil...
we would take a match to the dipstick, if it flamed right up you had gas in the oil. the oil would not feel slippery, it would feel more like a solvent. i remember seeing cams with no lobes after an engine being "gas washed"
in dog yrs i'm already dead
kartooo is offline
post #4 of 6 (permalink) Old 11-28-2012, 05:52 PM
Main Motorcycle: Thruxton
Gary_spain's Avatar
Other Motorcycle: Rieju Tango
Probably a float needle is not properly seated or is stuck open - maybe gummed up.
I would check this before messing with the float height.
07 Thruxton: TEC 2 into 1, K&N, TTP Breathe Bellmouth, 135 mains, 40 pilots, std. needles, 1 shim (0.65mm). All baffles removed. Bitubo Fork Cartridges. Bitubo Rear Shocks. TEC Steering Damper. 3 Pot Nissin (Honda) brake caliper.
Gary_spain is offline
post #5 of 6 (permalink) Old 11-28-2012, 07:24 PM Thread Starter
Thanks for all the replies. I guess I should do a oil change very soon regardless.
It was parked with the rear slightly downhill.
I'm going to rap on the carbs a bit with a plastic handled screwdriver and see if that loosens up a float.
post #6 of 6 (permalink) Old 11-29-2012, 02:05 AM Thread Starter
Fixed, or fixed so far. I think my vent tube from the carbs (from removing Cali evap system) was getting pinched by the sidestand causing the bowls to overflow. I rerouted the vent, tapped the float bowls and I don't have any leaks so far. What should I do about my filter element? It's a uni filter. Clean and re-oil?
More fuel for the pod v airbox fire train5 Hinckley Classic Triples 20 09-13-2016 12:40 PM
HELP! Fuel backing up into the airbox! IwannaGoFast Air Cooled Twins Technical Talk 7 03-27-2010 04:56 PM
Fuel pouring from airbox! Marcus Ash Trophy 4 03-06-2010 05:11 PM
Fuel leaking from airbox?? j_nelson335 Hinckley Classic Triples 3 06-05-2009 02:09 PM
Airbox and Fuel Questions Panthermark Air Cooled Twins Talk 31 07-21-2005 05:04 PM
