swing arm - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 6 (permalink) Old 11-27-2012, 08:47 AM Thread Starter
Main Motorcycle: 07 speedmaster
wildchild's Avatar
Other Motorcycle: 07 675 Daytona
swing arm
Does anybody know if there is bushing or something like that in the swing arm that would need to be replaced at some point. Have 79000 miles on it think some thing would need to be checked or not
Thanks
Jerry
toys for big boys
wildchild is offline
post #2 of 6 (permalink) Old 11-27-2012, 11:12 AM
Main Motorcycle: 2012 base bonneville
Other Motorcycle: 2013 victory hammer
looked in my 2012 bonnie manual shows spacers and bushings mentions bearings as well, if your doing it yourself a cleaning and relube prolly a good idea you could check for play as well, i just got a drive belt which said can be installed in an hour by trained pros, requires removing swing arm according to directions, said some charge 8 hrs labor be aware $$$$
rodhotter is offline
post #3 of 6 (permalink) Old 11-27-2012, 10:58 PM
Main Motorcycle: 2001 Bonneville
Yes by god yes. Search for posts by me to see what that probably looks like back there. There are a two sealed bearings and a roller bearing and sleeve, plus seals, and mine had disintegrated. Further, the pivot bolt was totally corroded and had to be drifted out.
You can source replacement bearings locally if you need them, but unlike the hubs you can forget pressing them in yourself without specialized tools. I took the bag o bearings and bare swingarm to the dealer and paid for an hour of labour. Was worth it.
Unless it's acting up, just plan to pull the swingarm on your next rear tire change. Mine was creaking, and no wonder. It's on my regular inspection now.
schuitz is offline
post #4 of 6 (permalink) Old 11-27-2012, 11:03 PM
Here:
http://www.triumphrat.net/twins-tech...t-ruh-roh.html
Though I didn't take a photo of what's left of the roller bearing. I kept it though, as a souvenir.
schuitz is offline
post #5 of 6 (permalink) Old 11-28-2012, 06:40 AM
Askari's Avatar
Y/N
Thanks
Jerry
There are bearings, dust seals and bushes. If the seals are good then most likely all else is good. But if you end up going to the trouble of checking the seals then you might as well check the bearings and relube all.
Askari is offline
post #6 of 6 (permalink) Old 11-28-2012, 08:37 AM Thread Starter
wildchild's Avatar
Thanks for your response I will look at it this winter
Jerry
toys for big boys
Swing Arm Bag? Severeign Cruisers - America, Speedmaster 24 03-18-2014 07:29 PM
swing arm daveyl Daytona Deliberations 15 07-23-2012 06:36 PM
Carbon swing arm Greyboy Speed Triple Forum 11 07-03-2009 02:18 AM
'06 swing arm daveyl Daytona Deliberations 4 06-10-2008 02:21 PM
Swing Arm .... NewMetal Air Cooled Twins Technical Talk 4 05-09-2007 04:24 AM
