Speedometer Reinstall - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 7 (permalink) Old 11-26-2012, 01:40 AM Thread Starter
Main Motorcycle: bonneville cafe
The previous Owner of my 2007 Bonneville, removed the speedometer, he of course provided it when he sold it to me, I was wondering if anyone could help out with how to successfully reinstall it. I mainly have worked on vespas and have owned a couple, this is a little different as I am not as familiar. Is this something that is easily done or should I just take it to a certified triumph mechanic and pay to have it done.
It seems easy enough, seems to be mounted with 4 mounting screws and has a white cluster cable, what else should I be aware of if anything... Any help and or pictures would be of great help!
alexandercase is offline
post #2 of 7 (permalink) Old 11-26-2012, 07:26 AM
Main Motorcycle: 2001 Bonneville
Did the previous owner also provide the mounting hardware? The job is mostly trivial either way. You will need four stainless hex cap screws, the thread of which eludes me at the moment. The speedo cable just screws on, and I'm assuming you have that. The lighting connector goes into the headlamp bucket, the lens of which comes off with two screws and is a rat's nest inside.
You didn't mention tach, and I don't have one, so can't help you on that one.
schuitz is offline
post #3 of 7 (permalink) Old 11-26-2012, 07:43 AM
sprouty115's Avatar
Take a look here:
http://www.bikebandit.com/2007-trium...7310#sch569207
And here:
http://www.bikebandit.com/2007-trium...7310#sch569208
This should give you an idea of what you have vs. what you're missing.
- Stephen
sprouty115 is offline
post #4 of 7 (permalink) Old 11-26-2012, 05:49 PM
The instructions for the tachometer add-on kit might help:
http://www.motorcyclestore.us/triump...ter%5B1%5D.pdf
Marty
Baltobonneville is offline
post #5 of 7 (permalink) Old 11-26-2012, 10:03 PM Thread Starter
so..
I got it remounted today, the idiot lights and backlight work, i assume that the cable that screws directly into the back is what makes the speedo tell you your speed? What does the cable look like, and where does the other end screw into? So close yet so far... He gave me what he said was everything in a box he took off to make it a bit more cafe looking...
post #6 of 7 (permalink) Old 11-27-2012, 08:48 AM
Mechanical speedometer. The cable is a sheath with a wire inside, looks on the outside like the other cables. If you don't have one, order it. Order the screw for the bottom end also, if you don't have it.
Route the sheath through the wire clip on the left fork where the brake line should already be.
The bottom end of the cable attaches to the wheel hub with the flathead screw--don't overtighten it. You have to engage the cable properly to the hub; if you look at it carefully, you should see how it engages.
You can remove the cable from the sheath at the bottom if that makes anything easier. Wipe it clean once a year and put a thin film of light grease on it.
Marty
post #7 of 7 (permalink) Old 11-27-2012, 02:55 PM Thread Starter
awesome
got it up and working last night with your help and some youtube vids, can anyone link to the 2 screws, 1 for the bottom flathead screw in the last comment and I am missing 2 out of the 4 allen key screws that mount the speedo. Thanks!
Top triple clamp reinstall Bruno317 Air Cooled Twins Technical Talk 6 09-25-2012 04:38 AM
Need little help with Misc Parts reinstall tomcat114 Speed Triple Forum 2 10-30-2010 10:11 PM
Digital Speedometer - Bicycle Speedometer crlarsen17 Sprint Forum 16 09-15-2010 01:00 PM
Head removal and Reinstall fat frank Air Cooled Twins Technical Talk 25 07-27-2009 08:08 AM
Engine light stays on after reinstall of gastank. cafejim Sprint Forum 3 05-31-2007 10:28 AM
