Confirmation this is wrong! - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 6 (permalink) Old 11-24-2012, 04:25 AM Thread Starter
Main Motorcycle: Bonneville
Arkwright's Avatar
Extra Motorcycle: Yamaha XJ600 Diversion
I started a thread a while ago about shims and would just like confirmation that the black rubber washer on the needle in the pic below should NOT be there, before I put on aproper shim and reassemble my carbs....
many thanks
Arkwright is offline
post #2 of 6 (permalink) Old 11-24-2012, 04:38 AM
Other Motorcycle: Honda Postie
Extra Motorcycle: Suzuki DL650 V Strom
Hello
Yes that is wrong, it should not be there. Shims are metal and thin. If you are tuning your bike start with the main jet and move on to needle, shims and pilot. I had shims in (as per Jenks Bolts guide) but a session on the dyno resulted in me taking them out. YMMV
Tasmaniablue is offline
post #3 of 6 (permalink) Old 11-24-2012, 04:40 AM Thread Starter
Arkwright's Avatar
Originally Posted by Tasmaniablue View Post
Hello
Cheers...
I kinda knew it shouldn't be there, but just wanted confirmation.
post #4 of 6 (permalink) Old 11-24-2012, 05:18 PM
Main Motorcycle: Triumph Thruxton EFi
Other Motorcycle: Yamaha R1, Honda CB1000R
Bloody hell! The bodges some people will resort to. That is why I hate anyone else working on my vehicles.
GDCobra is offline
post #5 of 6 (permalink) Old 11-24-2012, 05:44 PM
Main Motorcycle: GasGas TXT Pro Trials
Bron-Yr-Aur's Avatar
Other Motorcycle: KTM 200 XC 2T
Extra Motorcycle: Kawasaki KX250 2T
I had my carbs cleaned by a local shop. I got them back and couldn't quite get things right. After much confusion, I took things apart to find 2 shims on one needle and none on the other. This was the same guy who told me to use brake parts cleaner to clean my motor.
I, too, work on my own stuff unless I'm in over my head. It's sad when I can do a better job than a "trained" mechanic.
Bron-Yr-Aur Garage
Bron-Yr-Aur is offline
post #6 of 6 (permalink) Old 11-24-2012, 05:48 PM
It looks like an O ring. No wonder you haven't been getting many mpg, the thickness of that must be the equivalent of 4 x .5mm shims !!!
denbow is offline
Map Confirmation - 2007 S3 V-twinner ECM and FI Tuning - Help, Tips & Tricks 0 04-01-2012 11:25 AM
06 tiger ecu confirmation liam Tiger Chat 9 11-02-2011 08:25 PM
Just after confirmation after TuneECU'ing my s3.. metaltriumph ECM and FI Tuning - Help, Tips & Tricks 7 02-23-2011 04:50 AM
I need a little confirmation quagmire Classic, Vintage & Veteran 7 05-23-2008 12:08 PM
Wrong primary-case = wrong timing happyray Classic, Vintage & Veteran 3 04-05-2007 11:27 AM
