One shim or two? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 17 (permalink) Old 11-23-2012, 05:32 PM Thread Starter
Main Motorcycle: Bonneville T100, 2006
gjones's Avatar
One shim or two?
What theoretically, would be achieved by adding another shim?
This is my setup:
2006 T100
140/42 jets
NBZT needles
1 x 0.5mm shim
Idle mixture screws 3 turns out
It runs pretty good
gjones is offline
post #2 of 17 (permalink) Old 11-23-2012, 05:45 PM
Main Motorcycle: 2008 Bonnie Black Special
triumphrat.net Vendor
PieMan's Avatar
A slightly richer bottom end/mid range.
Mike (UK)
PieMan is offline
post #3 of 17 (permalink) Old 11-23-2012, 06:19 PM
Main Motorcycle: GasGas TXT Pro Trials
Bron-Yr-Aur's Avatar
Other Motorcycle: KTM 200 XC 2T
Extra Motorcycle: Kawasaki KX250 2T
I don't speak out of posing to be a mechanic, only because I have the same bike.
Even with wide open pipes and Thrux needles (sorry I don't know the code, I think that's the needles you have) you should not need a shim, ever, and 3 turns is waaaaay too rich.
With 42's mine ran great at 1 1/4 to 1 1/2 turns, no shims, and that was on a dyno, not guessing with me arse. At 2 1/4 turns, I smell raw fuel.
Just my personal experience.
Bron-Yr-Aur Garage
Bron-Yr-Aur is offline
post #4 of 17 (permalink) Old 11-23-2012, 07:03 PM
+1. Mine stinks of raw fuel on tickover with the mixture screws anything over one turn with 42 pilots ...thrux needle (NBZT), no shims.
denbow is offline
post #5 of 17 (permalink) Old 11-23-2012, 08:38 PM Thread Starter
gjones's Avatar
Thanks for replying.
The three turns-out wasn't arbitrary - it was the point reached that stopped the bike backfiring and made it run better than ever.
gjones is offline
post #6 of 17 (permalink) Old 11-23-2012, 08:41 PM Thread Starter
gjones's Avatar
... by mid-range, I take this to mean better acceleration in higher gear at higher speeds, right?? - this is precisely what I'm looking for
I'm not exactly sure what you mean by "bottom end" though ....
thanks,
GJ
gjones is offline
post #7 of 17 (permalink) Old 11-23-2012, 09:48 PM
Main Motorcycle: Yes
B02S4's Avatar
Mike was referring to throttle position, not vehicle speed or gearing. Presuming you have the correct size mains, with NBZT needles, as a general rule, shims should not be necessary.
B02S4 is offline
post #8 of 17 (permalink) Old 11-24-2012, 12:28 AM
Bottom end is your lower rpm range, the twisting force (torque) off idle. B02 made a good point: you have to make sure you're running the right mains. What pipes are you using?
Bron-Yr-Aur Garage
post #9 of 17 (permalink) Old 11-24-2012, 09:51 AM Thread Starter
gjones's Avatar
I take your point. So essentially there is an equivalency of sorts in raising the needle to allow more fuel, and increasing the jet size, correct?
Could you suggest any metrics that could describe this i.e: jet size increments and 0.5mm shim equivalencies ?
thanks,
GJ
gjones is offline
post #10 of 17 (permalink) Old 11-24-2012, 09:56 AM Thread Starter
gjones's Avatar
Both the air intake and exhaust are low restriction.
thanks,
GJ
gjones is offline
Do I have a shim? Arkwright Air Cooled Twins Technical Talk 10 11-18-2012 06:22 PM
Which Shim Kit? phpbiker T3 Sport / Touring Forum 4 01-05-2012 08:56 AM
Swingarm Shim swgee Classic, Vintage & Veteran 6 10-21-2009 07:10 AM
To shim or not to shim... Kramocker Air Cooled Twins Technical Talk 6 12-07-2007 10:05 PM
to shim or not? msioda74 Air Cooled Twins Technical Talk 4 10-16-2007 09:20 AM
