One shim or two? - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
post #11 of 17 (permalink) Old 11-24-2012, 10:18 AM
Main Motorcycle: Thruxton
Gary_spain's Avatar
Other Motorcycle: Rieju Tango
Originally Posted by kreemsicleT100 View Post
Even with wide open pipes and Thrux needles (sorry I don't know the code, I think that's the needles you have) you should not need a shim, ever, and 3 turns is waaaaay too rich.
I can assure you that with my setup a shim is certainly needed. Open pipes, thrux needles and de-baffled air box + breathe.
07 Thruxton: TEC 2 into 1, K&N, TTP Breathe Bellmouth, 135 mains, 40 pilots, std. needles, 1 shim (0.65mm). All baffles removed. Bitubo Fork Cartridges. Bitubo Rear Shocks. TEC Steering Damper. 3 Pot Nissin (Honda) brake caliper.
Gary_spain is offline
post #12 of 17 (permalink) Old 11-24-2012, 12:00 PM
Main Motorcycle: 2008 Bonnie Black Special
triumphrat.net Vendor
PieMan's Avatar
But you're using a 40 pilot Gary, if you moved to a 42's you possibly wouldn't need a shim.
Mike (UK)
PieMan is online now
post #13 of 17 (permalink) Old 11-24-2012, 02:14 PM
Main Motorcycle: GasGas TXT Pro Trials
Bron-Yr-Aur's Avatar
Other Motorcycle: KTM 200 XC 2T
Extra Motorcycle: Kawasaki KX250 2T
After reading many, many posts on this, when setting up my bike, here's what I came up with...
For 865 motors, pods and open exhaust, the guys who were tested and tuned, I saw this pattern: mains, range of 140 to 155. This varied greatly depending on location and weather, but this is the most important factor in tuning, because everything else is affected from the mains down. The mains have to be correct (WOT) to get the low (idle to 1/4 throttle, pilots) and mid range (needles) power right. So I started with a 147.5. (I ended up needing 152's) With Thrux needles, I never saw a member use shims, and my dyno/sniffer confirmed this. With 42 pilots, I saw most members between 1 and 2 turns. Mine is happy around 1 1/2, until lately with crazy weather changes. And the only reason I question them now is difficulty starting when below 40°.
By no means am I a genius at this, which is why I research like I do, but I'm just sharing what a couple of months of research yielded for me. I'm sure others may have a different experience, but I tried to take all things into consideration, at least to establish some sort of baseline. Hope that helps, at least a little.
Bron-Yr-Aur Garage
Bron-Yr-Aur is offline
post #14 of 17 (permalink) Old 11-24-2012, 04:22 PM Thread Starter
Main Motorcycle: Bonneville T100, 2006
gjones's Avatar
Sure, and I appreciate your input.
My existing set-up is working very well for me. Having found the right configuration, it provides the performance benefits that I expected.
However, I find that in top gear at speed, when I want to pass traffic, given the choice to gear down and accelerate, or to just accelerate, I tend to choose the latter.
So my question regarding shims was to discover whether, theoretically, an extra shim would increase acceleration under these conditions, or not.
gjones is offline
post #15 of 17 (permalink) Old 11-24-2012, 09:11 PM
Main Motorcycle: Yes
B02S4's Avatar
Originally Posted by gjones View Post
...So my question regarding shims was to discover whether, theoretically, an extra shim would increase acceleration under these conditions, or not...
IMO, if the current mains are too small for optimum WOT performance (& I believe the 140's in yours probably are sub-optimally on the lean side), then yes, it is theoretically possible.
An AFM in actual on-road conditions will show AFR indications that you simply can't feel, & the difference between "OK" & "WOW" can sometimes be just a step or two off.
Also IMO, you can get to "good" with seat of the pants carb tuning, however if you want to get to "great" there really is no substitute for tuning with a AFM.
B02S4 is offline
post #16 of 17 (permalink) Old 11-25-2012, 10:48 AM Thread Starter
gjones's Avatar
Originally Posted by B02S4 View Post
...the difference between "OK" & "WOW" can sometimes be just a step or two off.
well, that's quite motivational.
hmmm.... I have 145s in my box that I could try.
thanks, GJ
gjones is offline
post #17 of 17 (permalink) Old 11-27-2012, 10:30 PM
Main Motorcycle: Bonneville black 2007
sonicboom's Avatar
Other Motorcycle: Honda CBR600RR
Extra Motorcycle: Honda CB500F
I would think the larger jet would give better roll on throttle response if that is what you are looking for. Try it out and decide for yourself. Can't hurt anything. Having the bike tuned on a dyno is the best way to go and then you are not guessing at this stuff. But then what happen to all the fun with a dyno. LOL.
sonicboom is offline
Do I have a shim? Arkwright Air Cooled Twins Technical Talk 10 11-18-2012 06:22 PM
Which Shim Kit? phpbiker T3 Sport / Touring Forum 4 01-05-2012 08:56 AM
Swingarm Shim swgee Classic, Vintage & Veteran 6 10-21-2009 07:10 AM
To shim or not to shim... Kramocker Air Cooled Twins Technical Talk 6 12-07-2007 10:05 PM
to shim or not? msioda74 Air Cooled Twins Technical Talk 4 10-16-2007 09:20 AM
