How lean will I be running? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 9 (permalink) Old 11-23-2012, 12:46 AM Thread Starter
Main Motorcycle: Scrambler
Other Motorcycle: Sprint GT
I've got an EFI Scrambler and I'm thinking about pulling the snorkel and baffle. Obviously, this is going to make me run a bit leaner. If I do this, should I stop riding until I get the new tune or will it be alright to ride for short trips (to and from work, etc.)?
potato_peeler is offline
post #2 of 9 (permalink) Old 11-23-2012, 01:03 AM
Forchetto's Avatar
It will run quite a bit leaner. On carbed bikes, as a comparison, snorkel and restrictor plate removal means increasing main jet size by 5 points.
Read the post linked to below. Pieman comments on doing just that on EFI bikes.
http://www.triumphrat.net/twins-tech...ml#post2376399
In normal day to day running you'll be OK until such time as it can be re-mapped.
Forchetto is online now
post #3 of 9 (permalink) Old 11-23-2012, 10:36 AM
Main Motorcycle: '07 Black
Easy13's Avatar
If you were to do away with the Air Injection at the same time, you might not be running as lean; the two changes would sort of offset each other.
"Cognito Ergo Wrenchum"
Easy13 is offline
post #4 of 9 (permalink) Old 11-23-2012, 11:35 AM
Main Motorcycle: Triumph Thruxton EFi
Other Motorcycle: Yamaha R1, Honda CB1000R
Apart from the fact the the AI injects air into the exhaust (and then only under specific conditions) so won't affect the AFR in the cylinder..
GDCobra is offline
post #5 of 9 (permalink) Old 11-23-2012, 02:47 PM Thread Starter
Thanks Forchetto. Some days I long for the ease that came with a good old carb. Luckily winter is getting into full swing here so I'm not planning on making any long rides so I think I'll go ahead and pull that stuff today.
post #6 of 9 (permalink) Old 11-23-2012, 04:43 PM
Main Motorcycle: Yes
B02S4's Avatar
AI removal will not impact combustion AFR;removal will effect (reduce) exhaust popping in non-cat exhaust
B02S4 is offline
post #7 of 9 (permalink) Old 11-23-2012, 09:16 PM
Easy13's Avatar
Y'all are correct, my mistake. What I meant to say is removing the AI will help the engine run a bit cooler, thus allieviating some of the heat buildup from a leaner mixture.
Easy13 is offline
post #8 of 9 (permalink) Old 11-24-2012, 12:49 PM Thread Starter
Yeah, I shoved a marble into the AI hose the week after I got the bike (what a huge difference that makes in the throttle).
As an update, I pulled the baffle and snorkel and love the extra intake sound. I still need to do the adaptive reset, but so far I like it.
post #9 of 9 (permalink) Old 11-25-2012, 12:34 PM
Main Motorcycle: 2012 Scrambler
warrewp's Avatar
Extra Motorcycle: 2015 Moto Guzzi V7 II
It does sound way nicer once removed. It is a lot throatier. I've been running mine without the snorkel for a few weeks. I actually feel like the bike got a little hotter, but its so cold here I can't really tell (although getting cool makes more sense with the leaner mix). I am planning a remap soon. To answer your question though: take it off and ride.
warrewp is offline
May Be Running Lean? beerzerker Air Cooled Twins Technical Talk 1 03-12-2012 02:01 AM
Running very lean? bobbo Air Cooled Twins Technical Talk 2 01-23-2011 10:43 AM
Running lean? BonnieBabe Air Cooled Twins Technical Talk 8 08-28-2009 08:50 AM
running lean? sandslinger17 Speed Triple Forum 2 07-09-2008 12:45 PM
Lean running williambonney Classic, Vintage & Veteran 8 09-06-2007 02:56 PM
