Max Tire Size on Bonnie - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 8 (permalink) Old 11-20-2012, 06:26 PM Thread Starter
Main Motorcycle: Thruxton/Bonnie
I have to replace the tires this winter on my 08'bonneville. It has the original spoked rims, which I'm looking to put some thicker and taller sidewall tires on.
I like the look of these tires but this guy changed out his wheels.
What sort of handling changes would occur, anything major? If someone can give me some specs as to what the largest I can go would be it would be greatly appreciated.
Has anyone fit the bridgestone spitfires on their bonnie?
jac55 is offline
post #2 of 8 (permalink) Old 11-20-2012, 09:35 PM
Main Motorcycle: '07 Black
Easy13's Avatar
With the stock rims, I ran Metzeler ME880 tires, with a 140-80/17 on the rear, and a 110-90/19 on the front. They looked beefy enough and performed excellently. I had to trim down the four bolts that attach the front fender to the big steel fender bracket to avoid them cutting into the 110 front tire, but that was it. An added benefit is that the ME880 has great longevity and excellent grip.
There are a couple of 150-series tires that will fit on your stock rear rim, but I'm unsure of the specifics.
"Cognito Ergo Wrenchum"
Easy13 is offline
post #3 of 8 (permalink) Old 11-21-2012, 12:23 AM
Main Motorcycle: Cafe'd Bonneville SE
cashmore1985's Avatar
Send a message via AIM to cashmore1985
Within reason, 140/80-17 on the rear. Many people put a 150 back there and while it looks nice, there are some contact patch/reduced traction issues. As for the front, I have a 120/70 on there now but i think the best looking is either a 110/80 or 110/90. My front wheel is a 17 though (mag wheel bonnie)
'09 Bonnie SE Blue and White
MODS- Lots of 'em
Host and Producer - Cafe Racer Podcast
www.caferacerpodcast.com
cashmore1985 is offline
post #4 of 8 (permalink) Old 11-21-2012, 11:40 AM
Main Motorcycle: 03 T100
mikeinva's Avatar
nope I have had 140/80 and 150/70 on the rear the 150/70 has more tire on the road.
mikeinva is offline
post #5 of 8 (permalink) Old 11-21-2012, 03:11 PM
From what I understand, the contact patch when putting a 150/70 on a 3.5" rim becomes wider left to right but shorter front to back.
MODS- Lots of 'em
post #6 of 8 (permalink) Old 11-26-2012, 11:52 AM
Main Motorcycle: 2012 base bonneville
Other Motorcycle: 2013 victory hammer
if you are willing to upsize your rim width $$$$ for proper fitment do some measurments for clearance then go to a tyre site michelin has full specs as a pdf download, gives diameters, section widths etc, also recommended fitment for rims and tyre combos, some tyres grow a little when hot or at speed, you will see radials require more rim, lower profiles are lighter enhanching handling, reasons for aluminum wire wheel rims or lighter aftermarket mag styles. used wider 18" wheels with mich radials on sportster, stock front 100/90/19 2.5"rim replacement 120/70/18 3.5" rim rear 150/80/16 3"rim replaced with 160/60/18 4.25" rim mich pilot road II tyres handling EXCELLENT!!!!
rodhotter is online now
post #7 of 8 (permalink) Old 11-27-2012, 10:16 PM
Main Motorcycle: Bonneville black 2007
sonicboom's Avatar
Other Motorcycle: Honda CBR600RR
Extra Motorcycle: Honda CB500F
Dunlop 501, 150-17 will fit on the rear rim.
sonicboom is online now
post #8 of 8 (permalink) Old 11-27-2012, 10:52 PM
Main Motorcycle: 04 Thruxton
Aussiematt's Avatar
Other Motorcycle: 13 Str Trple R
Extra Motorcycle: 16 Thruxton R
I went wide (150 rear GT501) on OEM rims. It can be done but the resultant slower cumbersome handling was not a compromise I was willing to accept. I pretty well only ride mountain curves so quick nimble handling is important to me. It may be a different matter for those commuting or predominantly riding highways.
FCR, Uni, 813 cams, Works shocks, drilled Ricor valves, Pieman ignitor, green springs, Beringer caliper, preds, damper, brace, Corbin, custom tinware, JMC swingarm, Brembo radial M/C, oil cooler, rearsets, clip ons, tubeless rims, Acewell, T/Clamp
Aussiematt is offline
Tire size KingCrawford Classic, Vintage & Veteran 3 08-21-2009 07:44 AM
tire size timwu Daytona Deliberations 4 05-24-2009 08:37 AM
Bonnie Rear tire - next size up Nathan Air Cooled Twins Technical Talk 8 06-21-2007 07:38 PM
tire size for 69 Bonnie Classic, Vintage & Veteran 1 11-13-2004 04:20 PM
Tire size Maintenance & Workshop Talk 0 05-09-2002 01:25 PM
