Knocking sound whilst braking - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 14 (permalink) Old 11-20-2012, 06:44 AM Thread Starter
Main Motorcycle: Thruxton/Daytona 675R
ThruxOZ's Avatar
Extra Motorcycle: Yz250f
Hello all
Been experiencing knocking noise whilst braking hard.
Not a once off per braking application,but a continual knock whilst braking.
It's like it may be the disc moving on the washers as mine has a floating disc.
Anyone else experienced this?
ThruxOZ is offline
post #2 of 14 (permalink) Old 11-20-2012, 06:53 AM
Main Motorcycle: Bonneville
Other Motorcycle: Vespa PX200
Extra Motorcycle: Kawasaki GTR and Sidecar
Originally Posted by ThruxOZ View Post
Hello all
Hello
Loose caliper bolt or missing anti rattle spring, if front brake may be steering bearings loose?
My guess's.
Barry
threewheelsuk is offline
post #3 of 14 (permalink) Old 11-20-2012, 06:58 AM Thread Starter
ThruxOZ's Avatar
Hi
Have checked caliper bolts & slides all nice and secure.
It's like pad knock but anti rattle retainer is in place
ThruxOZ is offline
post #4 of 14 (permalink) Old 11-20-2012, 10:18 AM
Main Motorcycle: 2007 bonnie black
killian101's Avatar
Other Motorcycle: 68 BSA (RIP)
Extra Motorcycle: 2015 Daytona
remove your front sprocket cover, check the nut. It maybe loose. At least, that was my experience
killian101 is offline
post #5 of 14 (permalink) Old 11-20-2012, 09:42 PM
Main Motorcycle: 2013 Bonneville
Checkered's Avatar
Other Motorcycle: Aprilia Scarabeo 200
Check the clearance between the caliper bolts and the disc. My last service the techos were a bit concerned about the clearance on my America,and removed the bolts and ground them down !
Checkered is offline
post #6 of 14 (permalink) Old 11-21-2012, 03:42 PM
Main Motorcycle: Thruxton 04
Other Motorcycle: Ariel VHA Special
Extra Motorcycle: Honda Pan European ST1300
Have you checked the Disc....Inspect closely it may be some Crud! in one of the holes in the disc inspect for any imperfections like a crack spin the wheel and see if the disc is warped or any of the above........
T.U.D.
tonupdave is offline
post #7 of 14 (permalink) Old 11-22-2012, 07:20 AM Thread Starter
ThruxOZ's Avatar
Hi thanks for all your replies thus far
I have inspected closely for clearance, the noise only appears once the brakes have been heat cycled several times.Once brake temp is up,it only occurs under heavy braking.Ive checked disc once up to temp and have found a fair bit of movement between disc and inner section.
I suppose the rivets have worn on the disc
ThruxOZ is offline
post #8 of 14 (permalink) Old 11-22-2012, 05:37 PM
Main Motorcycle: 2003 Triumph T100
Sheepdog's Avatar
I put an EBC floating disc on the front of my T100 and it makes a bit of noise...but not a knocking sound. Its more insectoid...like cicadas. Maybe its a fork issue. Check your preload adjusters and your fork oil levels.
Sheepdog is offline
post #9 of 14 (permalink) Old 11-22-2012, 05:50 PM
Main Motorcycle: 2012 bonneville T100
Choprocker's Avatar
is it def a knocking?
could be just where the holes in disc connect with brake pad when braking
Choprocker is offline
post #10 of 14 (permalink) Old 11-23-2012, 05:35 PM
plodalong's Avatar
Other Motorcycle: 08 Bonneville efi
Mine does it when on the brakes over bumps. Not all the time and usally around town, can't say that I've noticed it at speed. Not sure if it's the brake or the forks. Was doing it the other day on the way home from work, said to myself that I'll check that out this weekend, but the other bike needs new tyres fitted 1st.
07 thrux,breathe,Dna airfilter,airbox X restrictor,135 mains,tp +3 ignitor,yss emulators,hp springs, Bitubo shocks,pingle steering damper,D9 layflat,3" rise clipons,corbin seat, tt350 taillight,alloy indicators.shorai battery,Changes daily
plodalong is online now
Knocking sound from rear hub tubbyhubby Sprint Forum 30 07-03-2013 04:53 AM
Knocking sound in 1st gear DanR Air Cooled Twins Talk 23 05-17-2012 05:34 PM
knocking sound up by the front sprocket killian101 Air Cooled Twins Technical Talk 7 03-28-2012 02:41 PM
Unusual knocking during braking hinkleyozzy Speed Triple Forum 17 09-25-2010 03:20 AM
help knocking/tapping sound :( Treehugger Triumph SuperSports 17 07-18-2005 11:47 AM
