Knocking sound whilst braking - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
post #11 of 14 (permalink) Old 11-23-2012, 06:29 PM
Main Motorcycle: 04 Thruxton
Aussiematt's Avatar
Other Motorcycle: 13 Str Trple R
Extra Motorcycle: 16 Thruxton R
Originally Posted by plodalong View Post
Mine does it when on the brakes over bumps. Not all the time and usally around town, can't say that I've noticed it at speed. Not sure if it's the brake or the forks. Was doing it the other day on the way home from work, said to myself that I'll check that out this weekend, but the other bike needs new tyres fitted 1st.
Mine has always made the same noise as you describe. I have changed pads and checked all the bolts. I put it down to the EBC floating disk
FCR, Uni, 813 cams, Works shocks, drilled Ricor valves, Pieman ignitor, green springs, Beringer caliper, preds, damper, brace, Corbin, custom tinware, JMC swingarm, Brembo radial M/C, oil cooler, rearsets, clip ons, tubeless rims, Acewell, T/Clamp
Aussiematt is offline
post #12 of 14 (permalink) Old 11-23-2012, 08:31 PM Thread Starter
Main Motorcycle: Thruxton/Daytona 675R
ThruxOZ's Avatar
Extra Motorcycle: Yz250f
Hi
I believe it's the rotor as well as mine has a fair bit of movement now after 23500 kms .
What's the wear limit as far as movement is concerned, I wonder
Before it could cause a problem?
ThruxOZ is offline
post #13 of 14 (permalink) Old 11-24-2012, 01:32 AM
plodalong's Avatar
Other Motorcycle: 08 Bonneville efi
Mine has side to side movement, but thats why they call it a floating disc. Manual only calls for thickness and runout checks. Probably nothing to be concerned about, at least after some basic checks to make sure nothings loose. Now its beer oclock, hot work spooning tyres on in 35deg c
07 thrux,breathe,Dna airfilter,airbox X restrictor,135 mains,tp +3 ignitor,yss emulators,hp springs, Bitubo shocks,pingle steering damper,D9 layflat,3" rise clipons,corbin seat, tt350 taillight,alloy indicators.shorai battery,Changes daily
plodalong is online now
post #14 of 14 (permalink) Old 11-24-2012, 02:46 AM Thread Starter
ThruxOZ's Avatar
Hi
Mine has up and down movement which means the friction part can go out of round.
I've ordered a new oem disc from bikebandit, I fit that when it arrives and see how it goes
ThruxOZ is offline
Knocking sound from rear hub tubbyhubby Sprint Forum 30 07-03-2013 03:53 AM
Knocking sound in 1st gear DanR Air Cooled Twins Talk 23 05-17-2012 04:34 PM
knocking sound up by the front sprocket killian101 Air Cooled Twins Technical Talk 7 03-28-2012 01:41 PM
Unusual knocking during braking hinkleyozzy Speed Triple Forum 17 09-25-2010 02:20 AM
help knocking/tapping sound :( Treehugger Triumph SuperSports 17 07-18-2005 10:47 AM
