Is there a trick to doing this.... - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 11 (permalink) Old 11-19-2012, 05:28 AM Thread Starter
Main Motorcycle: Bonneville
Arkwright's Avatar
Extra Motorcycle: Yamaha XJ600 Diversion
Removed my carb needles to do some checking on shims and now have a bugger of a job re seating the rubber diaphragm in the groove around the carb top.
Is there a trick to doing this or do I just have to be a bit more patient and play around with it until it seats properly?
Arkwright is offline
post #2 of 11 (permalink) Old 11-19-2012, 06:44 AM
Main Motorcycle: Triumph America
Try warming with a hair dryer to shrink the diaphragm, if not replace
huggy39 is offline
post #3 of 11 (permalink) Old 11-19-2012, 08:28 AM
Use a smear or vaseline around the rim to hold it in position. There's a location dimple moulded into the rubber that should be automatically aligned if you haven't removed the diaphrams from the pistons.
Also note the following -
1/ When you replace the white plastic holder make sure one of the feet doesn't cover the air hole in the piston.
2/ When replacing the chrome caps make sure the spring fits squarely around the two tabs.
denbow is offline
post #4 of 11 (permalink) Old 11-19-2012, 09:24 AM
It's been a while, but I don't think that I removed the diaphragm to deal with needles and shims. Someone please correct me if I'm wrong.
Marty
Baltobonneville is offline
post #5 of 11 (permalink) Old 11-19-2012, 10:55 AM
Baltobonneville - You don't but not everybody knows that and removes them regardless
denbow is offline
post #6 of 11 (permalink) Old 11-19-2012, 12:44 PM
I had no trouble removing and replacing the rubber diaphram on my '01. Strange.
Now I'm all nervous and want to go check em to make sure they are secure.
luckyduck is offline
post #7 of 11 (permalink) Old 11-19-2012, 12:52 PM
Main Motorcycle: GasGas TXT Pro Trials
Bron-Yr-Aur's Avatar
Other Motorcycle: KTM 200 XC 2T
Extra Motorcycle: Kawasaki KX250 2T
It's a very delicate process, but the diaphragm should sit in the groove with no help, you just can't bump it around or it will pop out. Be very careful and look the whole way around it as you're placing the cap. I pinched my diaphragm when I first got the bike and ended up paying the $80 to replace it.
Since then, I've had the caps off many times with no problems. But like I said, verrrrry carefully. It just rests in the groove, it doesn't 'pop' in, thus the constant inspection as the cap is going down.
Bron-Yr-Aur Garage
Bron-Yr-Aur is offline
post #8 of 11 (permalink) Old 11-19-2012, 03:16 PM
triumphrat.net Vendor
Main Motorcycle: 2008 Bonnie Black Special
PieMan's Avatar
Similar to what Huggy39 said.
In the Summer you can remove and refit the slides without a problem, but as it gets colder the rubber tends to expand a little and it would seem impossible to re-fit. I know it doesn't sound right, but if you put the slide on a central heating radiator for ten minutes before re-fitting, the rubber will contract and fit in the groove with few problems.
Mike (UK)
04 Bonnie Black Special
PieMan is online now
post #9 of 11 (permalink) Old 11-19-2012, 06:08 PM
Main Motorcycle: 2007 Bonnie T100
bonza's Avatar
Other Motorcycle: Jeep Wrangler
yes, rubber reacts to heat in an interesting way as heating causes rubber to contract, and cooling causes it to expand. there is a "law" that describes it, but can no longer remember its name
important to understand with anyone who has to work with hydraulics and seals like o-rings, especially when rubber is under tension
2007 Tuxedo T100.
Dom Tourers, TTP breathe, DNA filter,baffle gone, 40/140/1 shim 3 turns, TTP igniter tune, Hagon Nitros, Thruxton Bars, Halcyon bar end mirrors, Pingel fuel valve, Monza gas cap, Burton seat, Avon Roadriders
bonza is offline
post #10 of 11 (permalink) Old 11-20-2012, 01:18 AM
Askari's Avatar
Stages
Believe it is called "Hookes" law
Rubber goes through 3 stages Glass( when real cold), Elastic (will return to correct length and visco elastic doesnt return to original.
Believe this is why the Challenger blew up, an ulatra cold seal.
Could this have any relationship to cam gasket issue!
Askari is offline
Hat Trick...or Lucky 7's Heretic13 Air Cooled Twins Talk 9 02-13-2012 11:38 PM
Is there a trick to this ? FC7711 Air Cooled Twins Technical Talk 25 12-19-2010 03:34 PM
this is like a trick right... tkedge1 Classic, Vintage & Veteran 12 10-05-2009 04:14 PM
These are trick little pieces ohiorider Air Cooled Twins Technical Talk 0 07-01-2009 06:38 PM
Hat Trick ooobaby Biker Hang-Out 8 11-20-2007 08:07 AM
