Do I have a shim? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 11 (permalink) Old 11-18-2012, 09:08 AM Thread Starter
Main Motorcycle: Bonneville
Arkwright's Avatar
Extra Motorcycle: Yamaha XJ600 Diversion
Do I have a shim?
In the middle of rejetting my carbs to account for my spiffing new DNA pods and it's recommended I apply 1 shim to my needle.
When I had my carbs rejetted recently by my mechanic, he said he had put a shim in, but I thought i would check.
When I removed the needle I was expecting a small metal washer, but what I found was a very small rubber washer and no metal washer.
Is this supposed to be the shim or should that rubber washer be there anyway and he didn't put any shims in as indicated?
Any help would be much appreciated...
Arkwright is offline
post #2 of 11 (permalink) Old 11-18-2012, 09:25 AM
Other Motorcycle: Honda Postie
Extra Motorcycle: Suzuki DL650 V Strom
Hello
Shims as far as I know are metal washers in the order of 0.5mm thick and approx 3mm hole. No shim means just that.....no shim and nothing else either. Anything else (eg rubber plastic etc) would evoke a raised eyebrow from me. I would diplomatically quiz your mechanic about this.
Tasmaniablue is offline
post #3 of 11 (permalink) Old 11-18-2012, 09:32 AM Thread Starter
Arkwright's Avatar
Originally Posted by Tasmaniablue View Post
Hello
I am a little concerned at what I found in there...
I sort of resigned myself to the fact that there wasn't a shim, I just wondered if the small rubber washers were part of the original factory set up.
post #4 of 11 (permalink) Old 11-18-2012, 09:37 AM
Hello
Not as far as I know. I have an 06 btw.
post #5 of 11 (permalink) Old 11-18-2012, 09:40 AM Thread Starter
Arkwright's Avatar
Hello
Thanks...
I'll see if anyone else has come across the mysterious rubber washers before removing them and sourcing some proper shims.
post #6 of 11 (permalink) Old 11-18-2012, 11:34 AM
Main Motorcycle: 08 Scramblinator 9000
ItsForrest's Avatar
Other Motorcycle: Kawasaki Darth Versys
I just had mine apart for the first time. No rubber shims. I have had many carbs apart never seen a rubber shim under a needle clip, plenty of metal and sometimes hard plastic but not rubber. Some rubbers may have a tendency to swell, harden or shrink from exposure to gas, in which case it may very well affect jetting. Were it me, I would swap it out since you've got it apart anyway. I like to use little stainless washers, which cost pennies when you buy a bag of them from a hobby store or electrical supply shop like Radio Shack here in the states.
Get off my lawn!
ItsForrest is online now
post #7 of 11 (permalink) Old 11-18-2012, 12:02 PM Thread Starter
Arkwright's Avatar
Can you give me an idea of what size washers I would need to buy?
post #8 of 11 (permalink) Old 11-18-2012, 12:58 PM
Forchetto's Avatar
I seem to remember reading that they were just M3 washers with a thickness of 0.5mm.
Forchetto is online now
post #9 of 11 (permalink) Old 11-18-2012, 02:00 PM
triumphrat.net Vendor
Main Motorcycle: 2008 Bonnie Black Special
PieMan's Avatar
M3 washers aren't the best for the job, they have a burring on the under side where they're punched out of a sheet. If you mic them they of inconsistent thickness, not by much, but i've had some at 0.61mm which is too much if the other washer is 0.5mm.
The shims are of a much tighter tolerance, which is good for consistancy between cylinders.
Mike (UK)
PieMan is online now
post #10 of 11 (permalink) Old 11-18-2012, 03:59 PM Thread Starter
Arkwright's Avatar
Any idea where I can order some Mike?
Which Shim Kit? phpbiker T3 Sport / Touring Forum 4 01-05-2012 08:56 AM
Shim or pilots or both Motolink Air Cooled Twins Technical Talk 8 01-20-2009 04:58 AM
The effect of a shim. PieMan Air Cooled Twins Technical Talk 7 01-12-2009 01:55 PM
To shim or not to shim... Kramocker Air Cooled Twins Technical Talk 6 12-07-2007 10:05 PM
to shim or not? msioda74 Air Cooled Twins Technical Talk 4 10-16-2007 09:20 AM
