Wonky Tach - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 5 (permalink) Old 11-15-2012, 11:14 PM Thread Starter
Main Motorcycle: The One I Gots
LukiSevenAce's Avatar
Other Motorcycle: Only This One Now
Wonky Tach
Cruising on the slab the other day.
65 - 75 mph.
Cooler temps, in the low 40's (F).
I cannot help but notice the tach needle intermittently jumping 200 to 500 rpm- with me just holding steady on the throttle.
Flat road mostly, freshly repaved (nice).
A bit windy, about 15kn steady, gusting to 25kn.
Tach is electric.
I flip on my volt meter, it shows normal deviation in the 1/100's.
Nothing unusual there.
Roll on the throttle to 75 mph, tach needle climbs up like normal.
When I roll off, back down to 4K- there it goes again with the intermittent jumping.
I count seconds to see if it's a pattern. None detected.
Just every once in a while, sometimes 200, back to 4K, then a 500 jump, back to 4K.
Sometimes just 100 rpm jump.
Weird.
Haven't looked to see if the connector under the seat is nicked or grounding yet.
Just wondering if anyone else may have experienced this odd behavior.
Or, if there's a short course on remedy available.
TNX in advance.
LukiSevenAce is offline
post #2 of 5 (permalink) Old 11-15-2012, 11:41 PM Thread Starter
Oh never mind.
Did the thing I should have before I posted-- did a friggin' SEARCH on the subject.
Even found a few with 'wonky' in the title!
Seems this is a common problem.
What's weird (in my estimation) is that a number of the complaints come from cruising at highway speeds and/or high wind situations.
Like what I was in two days ago.
I'll check leads to see they are properly seated.
I've never noticed the problem before though.
No reason to reply.
Mod can pull this thread out if they want.
Move along, nothing to see here.
post #3 of 5 (permalink) Old 11-16-2012, 10:33 AM
Main Motorcycle: 2008 Bonnie Black
ruger's Avatar
Other Motorcycle: 2007 HD Total Loss
I was going to offer that it might be an intermittent ground problem but then the tach light would go out as well and the tach would go to zero.
Fairly common you say? That's interesting. And unacceptable.
Ruger
Long may you run-Neil Young
ARK/Dominators/Works/Progressive/EBC rotor/Rocket III master cyl/Pazzos/170 rear/D9 Dash/520 chain/Denalis/DEcosse MOSFET upgrade/More crud/Ruger's Garage
ruger is offline
post #4 of 5 (permalink) Old 11-16-2012, 12:20 PM
Main Motorcycle: 2007 bonnie black
killian101's Avatar
Other Motorcycle: 68 BSA (RIP)
Extra Motorcycle: 2015 Daytona
Mine did the same thing till the needle broke off whole going over a bumb
killian101 is offline
post #5 of 5 (permalink) Old 11-16-2012, 12:43 PM
Supernova
Extra Motorcycle: '14 Triumph Thruxton 900
My tach has the moves like Jagger, too. From idle to 4k, all is well. From 4k to 5k, it dances and then works fine above that.
Sometimes you just have to go out to the beaver dam with a machete and start chopping wood
leftarmlogan is offline
Wonky Tacho BonnieRider Trophy 10 02-20-2010 10:43 AM
Wonky Thread Archimedes Biker Hang-Out 5 06-04-2008 04:42 AM
Is my EFI map wonky? ables Daytona Deliberations 4 05-13-2006 03:50 PM
95 Tiger with wonky tach Maintenance & Workshop Talk 4 05-26-2004 08:52 AM
