Carb jets ? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 8 (permalink) Old 11-15-2012, 06:49 PM Thread Starter
Main Motorcycle: Bonneville cafe racer
timfish's Avatar
Other Motorcycle: 6 but none work...one day
Carb jets ?
Now then, i'mm sure one of you technicaly minded chappies out there could tell me which jets i should fit into my 2006 carbs ,my bonnie has 2 into 1 Arrow pipes and has had air box removed and K+N cone air filters fitted. it runs ok but now and again i get a spit back,and at full throttle it feels fuel starved. i am happy to change the jets but i don't know to which ones.i can find which to change to when fitting the arrow exhaust,also when romoving the air box , but not when both conversions are carried out,there has got to be someone out there done these conversions, and will know which jets to fit . Thanks for listening..
Here i stand foot in hand talking to my wall........im'm not quite right at all,...........am i.
timfish is offline
post #2 of 8 (permalink) Old 11-15-2012, 11:02 PM
Main Motorcycle: 2006 Thruxton CaspianBlue
Other Motorcycle: HDtouring/Ducati/Honda
Extra Motorcycle: YES...
factory Keihin jets
If you bike is close to being properly tuned as you say what ever main jet you HAVE IN THERE NOW, when you pull out the main jet it will be marked (for example 125) if it is a stock factory Keihin jet then you can just go to any motorcycle shop and buy the next jet size up. (richer) That sounds like what you need. Change the main before you dink around with other settings. Do ONE step at a time.
Von Dutch is offline
post #3 of 8 (permalink) Old 11-16-2012, 12:19 AM
El Moderatore
Main Motorcycle: 2007 Bonneville
Calliway's Avatar
Other Motorcycle: 2007 Kawasaki Versys
Yeah, it would be good to let us know what you have in there now. You should probably be in the 42/145 range. Is your motor the 790 or 865? If you have a T100 in 2006 I think they have the 865.
Calliway is offline
post #4 of 8 (permalink) Old 11-16-2012, 02:07 AM
Main Motorcycle: GasGas TXT Pro Trials
Bron-Yr-Aur's Avatar
Other Motorcycle: KTM 200 XC 2T
Extra Motorcycle: Kawasaki KX250 2T
Honestly, no one can tell you accurately what to run. They can give you a ballpark idea, but I wouldn't go that route IMO. Every single bike is different, and so are climates and altitudes. I'm running jets that many think are too rich, but 2 dynos/2 sniffers that tell the same story aren't lying. Once you start engine mods, either a dyno or an a/f gauge become a necessary part of the game, unless you just like to live on the edge.
Bron-Yr-Aur Garage
Bron-Yr-Aur is offline
post #5 of 8 (permalink) Old 11-16-2012, 03:01 AM
Askari's Avatar
Jets
If the conversion is new then you will be extremely lean.
There is no right jet as there are many variables, altitude etc.
As stated you will need to see what you have in there at present.
The simple, quickest but least rewarding is to get it put on a dyno and have it tuned.
You need to check the serch engine in the forum as the jet removal is easy once you have done it once! As there will be a few strip downs unless you are lucky. Screws need to be changed (bowls). To do it right you may well benefit from some shims for the needles.
If your bike was previously converted, you need to balance the carbs and if the mileage ius up check the valve clearances. These both make a big difference to smooth running.
You might want to google up jenks guide or check in the stickyies as there is lots on carbs. There is pics of where the jets are. They have some guidlines on jets, i found they werent to far off others disagree, just goes to show the value of a dyno! At least you can get a ball park.
As for jets ideally a Keihin dealer (and the shims) cheapest option, Harley dealers they have used Keihins and are cheaper than your Local Triumph dealer.
Me on a 865 bonnie, staintunes with a totally gutted airbox and opened inlet was running 135 main in the end and good on the A/F. Bear in mind that is at sea level, with Aus quality fuel (good/ bad who knows, no ethanol!!)
Askari is offline
post #6 of 8 (permalink) Old 11-16-2012, 04:02 AM
Main Motorcycle: 08 Scramblinator 9000
ItsForrest's Avatar
Other Motorcycle: Kawasaki Darth Versys
Here's an old thread that might be useful:
http://www.triumphrat.net/twins-tech...esults-11.html
Get off my lawn!
ItsForrest is offline
post #7 of 8 (permalink) Old 11-17-2012, 01:37 AM
Main Motorcycle: Bonneville T100, 2006
gjones's Avatar
On my 2006 T100 I'm running 140/42 with one shim and 3 turns out, to great satisfaction.
I will try another shim, but I think I'm in the sweet spot.
gjones is offline
post #8 of 8 (permalink) Old 11-18-2012, 09:50 AM Thread Starter
timfish's Avatar
Thanks to all for your advice, thats what i love about this forum so meny knowledgable and helpfull people, ill strip my jets out and see where i stand.
Thanks again . Tim.
timfish is offline
114 carb jets John50 Air Cooled Twins Technical Talk 5 09-18-2012 05:09 PM
1958 t 110 carb jets ronboonville Maintenance & Workshop Talk 1 09-11-2012 10:30 AM
Carb Jets? NewMetal T3 Sport / Touring Forum 10 01-20-2009 11:23 AM
Carb jets KitNYC T3 Sport / Touring Forum 16 08-17-2007 04:01 PM
Carb jets pdanth Air Cooled Twins Technical Talk 7 10-26-2006 09:35 AM
