Cam gasket swap - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 12 (permalink) Old 11-15-2012, 05:08 PM Thread Starter
Cam gasket swap
Im swapping out my cam cover this weekend and have a replacement gasket because the current one is weeping.
I have some gasket sealant in stock and was planning on using that when installing everything. It's the type that does not set hard.
I assume I should clean up the surfaces and then apply a thin beed of the sealant and then place the new cover and gasket on top of the engine.
I don't have a manual so if anyone can confirm the correct torque setting I'd appreciate that very much.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx is offline
post #2 of 12 (permalink) Old 11-15-2012, 05:22 PM
Torque - 14 Nm.
I'd be reluctant to use gasket sealant in case it squashes out inside and causes a blockage. I used a film of grease to hold the gasket in place and torqued down with new crush seals - no leaks.
denbow is offline
post #3 of 12 (permalink) Old 11-15-2012, 05:57 PM
Main Motorcycle: thruxton
Make sure you replace the cam cover bolt washers also, I torqued mine to I believe 10nm and had no leaks.
tsx123 is offline
post #4 of 12 (permalink) Old 11-15-2012, 06:00 PM
I believe 14Nm is the revised torque setting.
denbow is offline
post #5 of 12 (permalink) Old 11-15-2012, 06:11 PM
Main Motorcycle: '02 Triumph Bonneville
Yes, 14Nm is correct now. I shouldn't even try to contribute on this, having had only miserable failures on three attempts to replace mine. I followed each of several theories on the best method; grease, gasket sealer, and dry with all surfaces wiped clean. I finally succeeded after buying a used aftermarket cam cover to replace my cracked one that came with the gasket somehow embedded in the groove. I cleaned all very well, put it on dry, tightened per spec, nary a leak.
The key is getting that slippery snake of a gasket to stay in place and in the groove...
Good Luck!
LapinAgile is online now
post #6 of 12 (permalink) Old 11-15-2012, 07:39 PM
Main Motorcycle: 03 T100
mikeinva's Avatar
Auto wheather strip glue works great to hold the gasket on the cover thats all I use.
mikeinva is offline
post #7 of 12 (permalink) Old 11-15-2012, 10:23 PM
Main Motorcycle: Bonneville
I replace the bolt seals every time and have been torquing to 10nm. I get both sealing surfaces completely clean and dry using Varsol (mineral spirits). I install the gaskets completely dry and I get no leaks.
2005 Bonnie, Sleepers and Unifilter, AI gone, restrictor gone, Modre's peg kit, headlight & brake modulator, tach, NC wind deflector, gaiters, steibel, vmax mirrors, Hagons & Progressives, PIAA. http://TexasCoastGeology.com
geolpilot is online now
post #8 of 12 (permalink) Old 11-15-2012, 10:49 PM
Other Motorcycle: Honda Postie
Extra Motorcycle: Suzuki DL650 V Strom
Hello
I had a weep at about 18000km. Took cover off, cleaned mating surface and applied a very thin coating of Loctite non hardening gasket sealant. Worked a treat, if you apply a thin coating no chance of squeezing out. I bought new washers but did not use them. I torqued to 10nm and have only just seen the new spec. 10nm seems plenty to me.
Tasmaniablue is offline
post #9 of 12 (permalink) Old 11-16-2012, 01:33 AM Thread Starter
Thanks for your replies. Very kind of you all. That's my Saturday morning job sorted.
post #10 of 12 (permalink) Old 11-16-2012, 01:42 AM
Askari's Avatar
Gasket
No to the sealant.
Lightly oil the faces and seal, this will allow it to move when tightening.
Change the washers, or expect leaks again.
Really clean out the pockets as the washers can leave lumps of rubber in there.
Most importantly torque down in multiple stages, believe the torques have been posted. You cant do to many stages,
Also make sure the groove in the cover is really cleaned out well and the new seal is perfectly seated. As my gasket came in a little bag, probably worth leaving it out to loose the screwed up shape.
Askari is offline
Gasket kit available KitNYC T3 Sport / Touring Forum 2 08-02-2010 04:16 PM
TBS gasket MotT3 Hinckley Classic Triples 2 05-12-2010 08:39 PM
Head gasket swap for lower compression aircap Classic, Vintage & Veteran 27 03-08-2010 01:26 PM
Underseat tray? Type of gasket sealant for sump gasket? ladyhawk Daytona Deliberations 0 09-11-2008 05:30 AM
Gasket? OlyKen Sprint Forum 3 02-23-2005 07:05 PM
