Cam gasket swap - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
post #11 of 12 (permalink) Old 11-16-2012, 08:13 PM
sob
Main Motorcycle: 07 thruxton
sob's Avatar
Other Motorcycle: 77 gs550 gone not forgot
Hey plumpton make sure when you loosen bolts, do so that you break em all free and turn each one a turn or so at a time until there out & tighten them finger tight same way then start to torque down a 1/2 turn or two at a time. This should prevent warping cam cover & keep seal in place. Give it a once over before you fully commit to torque spec & inspect seal for consistent mating. Good luck!
sob is offline
post #12 of 12 (permalink) Old 11-17-2012, 11:25 AM Thread Starter
Cam cover and all gaskets swapped out... Think the new gasket is still weeping a bit though. Can't tell just yet because I used some oil to seat the gasket in to the new cam cover. As you can see I've gone yellow. Fancied a change.
Bonneville yellow can cover by Fat Biker, on Flickr
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx is offline
Gasket kit available KitNYC T3 Sport / Touring Forum 2 08-02-2010 04:16 PM
TBS gasket MotT3 Hinckley Classic Triples 2 05-12-2010 08:39 PM
Head gasket swap for lower compression aircap Classic, Vintage & Veteran 27 03-08-2010 01:26 PM
Underseat tray? Type of gasket sealant for sump gasket? ladyhawk Daytona Deliberations 0 09-11-2008 05:30 AM
Gasket? OlyKen Sprint Forum 3 02-23-2005 07:05 PM
