Uni Filter Pods - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 9 (permalink) Old 11-15-2012, 01:32 PM Thread Starter
Main Motorcycle: 98 Valkyrie
Other Motorcycle: 08 Triumph America
Extra Motorcycle: 08 Moto Guzzi Nevada
Uni Filter Pods
I just checked my Uni filters and found that the side of the filter that gets all the air is almost completely dry (I touch it with my finger and don't get any oil on my finger), but the bottom and inside of the filter (the portion that faces the center of the engine) are still well oiled.
I'm wondering if I need to re-oil the filters now, or just twist them so that the oily part is on the outside. It's only been about 2,000 miles since I cleaned and oiled them, and I haven't ridden in any dusty conditions.
Has anyone else encountered a similar situation, and if so, what did you determine?
Stan
08 America, 904 kit, Bub slip ons, A/I removed, emissions "stuff" & air box removed, billet intakes, UNI Pods, carbs balanced, intminators, Progressive 412's, 1" risers, Corbin seat with driver back rest, TP USA Option 2 Igniter, 813 cams
skromfols is offline
post #2 of 9 (permalink) Old 11-15-2012, 03:20 PM
Main Motorcycle: 04 Thruxton
Aussiematt's Avatar
Other Motorcycle: 13 Str Trple R
Extra Motorcycle: 16 Thruxton R
Use less oil. The filter should not feel overly oily. I used way too much oil in the past until a knowledeable person showed me the correct amount. An excessively oily filter will rob you of HP
FCR, Uni, 813 cams, Works shocks, drilled Ricor valves, Pieman ignitor, green springs, Beringer caliper, preds, damper, brace, Corbin, custom tinware, JMC swingarm, Brembo radial M/C, oil cooler, rearsets, clip ons, tubeless rims, Acewell, T/Clamp
Aussiematt is offline
post #3 of 9 (permalink) Old 11-15-2012, 03:44 PM
Main Motorcycle: 2004 Thruxton
Other Motorcycle: 1954 BMW R25/3
Extra Motorcycle: 1971 CB350
+1 @ aussiematt. Some folks run these dry w/o issue. I only use a light, distant spray to get some highly atomized oil on the very outside. The filters should not have oil on the inner surface.
Regards,
--Rich
beemerrich is offline
post #4 of 9 (permalink) Old 11-15-2012, 04:21 PM
Main Motorcycle: 03 T100
mikeinva's Avatar
I never oil mine put them on right out the bag.I replace them every year .They are cheap enough that it dont hurt to bad to replace them .To much oil will kill there air flow.They come new with very little oil on them.
mikeinva is offline
post #5 of 9 (permalink) Old 11-15-2012, 04:33 PM Thread Starter
Thanks for the responses. I'll use less oil next time.
Stan
post #6 of 9 (permalink) Old 11-15-2012, 07:17 PM
Driftless Moderator
Main Motorcycle: 2008 Bonneville Black
BonnieBlack's Avatar
Other Motorcycle: Spousal 2009 Bonnie Black
On the other hand, just trying to keep the interweb in balance
It's friggen amazing how much dirt my oiled filters pick up when I wash them out. I'm glad that's not going into my engine. Of course, I don't know how much of that an un-oiled filter would pick up.
It does sound like your over oiling for sure though. Oil doesn't need to be showing up on the inside of the filter. Sounds like I use more than beemerrich, but I give it a solid outer coating and rub it into the filter a bit and compress/uncompress the foam a few times. The goal in my mind is to coat the inner surface of those voids in the foam (on the outer edges of the filter at least) while still allowing plenty of air flow. But I want some oil in there to trap the dust and fine dirt so it doesn't eventually work through the foam and enter the engine.
I bet you could run these engines with just a screen over the carbs instead of a filter at all for quite a while without issue. But it's like using decent oil, replacing your brake fluid once in a while, adjusting valve clearances, etc. The bike will run without issue without doing those things for many, many miles, but I want mine to run forever without issues
BonnieBlack is offline
post #7 of 9 (permalink) Old 11-16-2012, 04:42 AM
Very good post,10/10.
Plasma.
plasma is offline
post #8 of 9 (permalink) Old 11-16-2012, 12:05 PM
mikeinva's Avatar
Best way to see if you have to much oil on a uni filter is to check a/f with the filter on then check it again with the filter off .I f it goes richer with the filter on then you have over oiled the filter.Another thing about uni filters the ones with the red outter foam cover dont flow as good with the red cover on them,you dont need the red cover for clean street use.If you run on dirt or in a real dusty place you need more oil then you do for street use.
mikeinva is offline
post #9 of 9 (permalink) Old 11-16-2012, 12:16 PM Thread Starter
Thanks Mike. I don't have an a/f meter, and the nearest drno with an A/f meter is an hours ride from me, so that option won't work. I have the black pods and they don't have the red outer foam cover. I'll just have to be careful about how I clean and oil my pods. As an aside, I have the Uni filter with the red outer cover on my Polaris ATV and it seems to do a good job of keeping the dust out of the engine.
Stan
Air filter pods /sidecar Wavey T3 Sport / Touring Forum 1 08-10-2010 07:54 AM
1200 Air Filter Pods mushman T3 Sport / Touring Forum 1 08-30-2009 01:21 AM
Pods on the carbs vs high flow filter, baffles removed etc... Fast_Fashion Club Cafe' 2 04-30-2007 05:29 PM
K&nN Filter pods on a 95 Speed Triple RGDED T3 Sport / Touring Forum 14 02-04-2007 08:43 AM
Vance & Hines Air Filter Pods 5bassman Air Cooled Twins Technical Talk 12 12-04-2006 10:03 PM
