Mag Wheel bearings and CBR600F3 - Page 3 - Triumph Forum: Triumph Rat Motorcycle Forums
post #21 of 59 (permalink) Old 11-21-2012, 01:24 AM
Main Motorcycle: Hyde Harrier
Siskiyou's Avatar
Other Motorcycle: BMW GS
If it helps, I took a (somewhat crude) measurement to compare the stock Triumph
wheel to a CBR wheel. I measured the distance on each rim from the center of the
wheel to the sprocket to see how far off from center the rear wheel would be with the
sprockets lined up. The difference was about 2mm, so if you get the chain line straight,
the wheels will be pretty close.
Siskiyou is offline
post #22 of 59 (permalink) Old 11-21-2012, 10:35 AM
Main Motorcycle: 2012 Thruxton
Actionabe's Avatar
Other Motorcycle: 71 CB350
Extra Motorcycle: 86 SRX600
thats a pretty helpful mesurement, that is really close.... I was planning on doing this http://www.yamahafz1oa.com/sportryde...ntmethod.shtml once I get the wheel installed, seems like a pretty simple way to know for sure.
Actionabe is offline
post #23 of 59 (permalink) Old 11-21-2012, 10:41 AM Thread Starter
Main Motorcycle: Cafe'd Bonneville SE
cashmore1985's Avatar
Send a message via AIM to cashmore1985
That sounds close enough to me. I like it.
'09 Bonnie SE Blue and White
MODS- Lots of 'em
Host and Producer - Cafe Racer Podcast
www.caferacerpodcast.com
cashmore1985 is offline
post #24 of 59 (permalink) Old 11-21-2012, 12:03 PM
Main Motorcycle: 2004 Thruxton
Other Motorcycle: 1954 BMW R25/3
Extra Motorcycle: 1971 CB350
Originally Posted by beemerrich View Post
I did notice that the sprocket alignment is a little off...the sprocket needs to move to the right a bit.
At least that is what I saw with my 51 year old laser-calibrated eyeball when refitting the rear wheel & adjusting the chain....
I measured the distance on each rim from the center of the wheel to the sprocket to see how far off from center the rear wheel would be with the sprockets lined up. The difference was about 2mm, so if you get the chain line straight,
The hard part about getting the spocket aligned without shimming it to the right is moving the brake caliper/rotor as a unit. I suppose you could try shimming the brake rotor in lieu of the sprocket to move the entire wheel to the right. An equal amount would then need to be added to the left side axle spacer and removed from the right side spacer. The right side already provides very little space for movement to the right, so that constraint would likely drive how far the wheel can be moved over.
Personally, I'm much less comforable with shimming the rotor than running the wheel ~2mm (~0.079") off center and then putting some washers under the sprocket/on the rather substantial spocket carrier studs to get the chain to align. The rotor bolts are soft and don't have tons of shear strength. The sprocket carrier bolts, however, were engineered for a machine that puts out 100+ crank HP.
Regards,
--Rich
beemerrich is offline
post #25 of 59 (permalink) Old 11-23-2012, 03:27 PM Thread Starter
I had a conversation with Pieman today and in order to get everything lined up he had to get new spacers for both sides of the wheel, spacers behind the brake rotor, machine the face of the cush drive to allow the sprocket to sit closer to the rim, and a spacer behind the front sprocket to line up the chain.
MODS- Lots of 'em
post #26 of 59 (permalink) Old 11-24-2012, 01:10 AM
Actionabe's Avatar
Wow sounds like ill be hitting up the machinist a lot more once I get everything bolted together and make some measurements. Thanks to you and pie man for the information!
post #27 of 59 (permalink) Old 11-24-2012, 01:58 AM Thread Starter
I don't know the exact measurements for the rotor but he had 7mm machined off the face where the sprocket bolts up. He also had to have the studs that hold it on made shorter so they wouldn't hit the chain or something
MODS- Lots of 'em
post #28 of 59 (permalink) Old 11-24-2012, 08:28 AM
Mike is meticulous in his work, so I'm assuming his goal was to precisely center the wheel in the swingarm. The cush drive sits pretty tight to the right side (i.e. the spacer doesn't have much meat to allow movement in that direction), so I'm assuming he moved the wheel 7mm in that direction?
If all he did was move the sprocket inboard, then this runs counter to what I see on my bike...which is that the sprocket needs to move outboard to get better alignment with the countershaft sprocket. When I get some time in the shop, I'll measure how far the sprocket has to move to the right to perfectly line up, but it can't be more than 2-3 mm. Any shimming of the rotor would take that amount out of this distance...
Regards,
--Rich
post #29 of 59 (permalink) Old 11-24-2012, 01:05 PM
Main Motorcycle: 2008 Bonnie Black Special
triumphrat.net Vendor
PieMan's Avatar
Correct Rich, my wheels are exactly centred. All the existing spacers required replacing as the CBR600 rear wheel complete with sprocket carrier and spacers is around 2mm narrower than the factory rear wheel complete with sprocket carrier and spacers. The sprocket carrier required 7mm taken off the outer face to give enough clearance to centre the wheel, and the sprocket studs required shortening to clear the swinging arm. To help compensate for the rear wheel moving over, I added a 3mm spacer behind the gearbox sprocket, I could have done with another 1mm, but that is the max you can get away with so the serrated sprocket tab washer still sits on the splined shaft. 2.5 years later the discrepancy between the front and rear sprockets has had no effect on chain or sprocket wear.
The front wheel also needed new spacers as the factory spacers moved the front wheel too far to the left. My wheels are inline to the millimetre and there is absolutely no bias in taking left or right handers.
If anyone is thinking about carrying out the F3 mod, go ahead, you won't regret it. It improves the caperbility of the Bonnie or Thruxton in every way. The factory CBR600 front calipers are more than enough to stop you very quickly and they work great with the factory Triumph master cylinder. The F3 cartridge forks, although old technology compared to modern cartridge forks, are far better than the antiquated factory damper rod forks and also seem a perfect match for the ZXR rear shocks with lighter springs. Also using 160 rear and 120 front rubber on rims that they are intended for, is excellent. It's not easy to lock front or rear when braking hard and unusual for the rear to break away when accelerating hard out of a corner.
Mike (UK)
PieMan is offline
post #30 of 59 (permalink) Old 11-24-2012, 05:49 PM
Thanks for the information Mike. For it to be done properly, it seems there's a bit more involved than the laundry list of details I've previously come across on the forum.
Or I can do what most other's have done and just shim the wheel sprocket to align it with the countershaft sprocket and call it good. I guess it's a good thing I like right-hand corners...
Regards,
--Rich
Wheel bearings? T3 Sport / Touring Forum 11 03-25-2013 10:41 PM
wheel bearings jjimmydutch Air Cooled Twins Technical Talk 1 08-22-2009 02:41 PM
Front Wheel Bearings on mag wheel pogue54 Classic, Vintage & Veteran 3 05-18-2009 10:03 PM
Front Wheel Bearings on mag wheel pogue54 Classic, Vintage & Veteran 0 05-15-2009 09:27 PM
Wheel bearings triplemike Maintenance & Workshop Talk 1 04-30-2008 06:14 PM
