Ignition Coil Specs - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 8 (permalink) Old 11-12-2012, 07:04 PM Thread Starter
Main Motorcycle: Bonneville
Other Motorcycle: Honda Postie
Extra Motorcycle: Suzuki DL650 V Strom
Ignition Coil Specs
Hello
I have posted regarding an intermittent ignition fault on my 06 Bonneville. I have fitted a new PVL coil and the bike seems to be ok now. I have been measuring the old coil primary resistance everyday for about a week. The reading was variable at first (I wonder why) and has now settled down to 0.1 ohm, sometimes 0. Spec is 0.5 ohm. My question is; does this reading indicate a faulty coil? My thoughts are that a low primary resistance reading would result if some of the windings were shorted together leading to insufficient flux to create a secondary voltage sufficient for a spark.
Here is another thought; Could a device be made along the lines of a buzzer that could be connected to the primary and a tester or spark plug connected to the secondary so that the coil would behave just as it would in a running engine. This set up could be run for a time to see if the coil breaks down. As you can see I just like to know what is going on.
Tasmaniablue is offline
post #2 of 8 (permalink) Old 11-14-2012, 01:14 PM
Main Motorcycle: 1068cc '05 Thruxton
H3CT1C's Avatar
If it makes you feel any better my '05 Thruxton has been having similar problems.... secondary coil is in spec, but the primary coil is at 0.8 ohms. My first coil died after just over three years, coil number two just died, and coil number three is on the way, hope it corrects the problem... hope it also lasts longer than three and a half years...
~Thruxton~Sport Evolution 1100~FCRs~790 cams~shim-under-bucket~+1.5mm valves~45mm headers~Ignitech CDI~m-Lock~m-Unit~Race Tech springs~Ricor Intiminators~Hagon Nitros~Pretech caliper~520 chain~wide 17" rims~sticky rubber~
H3CT1C is online now
post #3 of 8 (permalink) Old 11-14-2012, 02:15 PM
Forchetto's Avatar
Yes, it's called something like "ignition coil driver". There are several circuit diagrams on the Net, like these:
And this super simple one using just a self-oscillating connection of a 12 volt relay with heavy contacts and a 0.47mf capacitor fed by a small 12 volt battery:
Forchetto is offline
post #4 of 8 (permalink) Old 11-14-2012, 05:24 PM Thread Starter
Hello
Brilliant Forchetto. I wish I had the electronic assembly skills to make one of those. I presume they can be purchased commercially. Interesting that some people have multiple failures and others have no problems over many years of ownership. Coils in automotive applications seem to be super reliable. I wonder why failures in our motorcycles are not uncommon. The factors that I can identify that affect coil life are heat, vibration and quality of manufacture. Has anyone autopsied a dead coil to see precisely how it failed?
post #5 of 8 (permalink) Old 11-15-2012, 04:50 PM
Main Motorcycle: 03 T100
mikeinva's Avatar
about 50% that people that think they have coil troubles end up being igniter troubles or other troubles.
mikeinva is online now
post #6 of 8 (permalink) Old 11-15-2012, 10:56 PM Thread Starter
Hello
Hope I am in the right 50%! So far so good but any hint of further trouble and a Procom it will have to be.
post #7 of 8 (permalink) Old 11-16-2012, 11:50 AM
Main Motorcycle: GasGas TXT Pro Trials
Bron-Yr-Aur's Avatar
Other Motorcycle: KTM 200 XC 2T
Extra Motorcycle: Kawasaki KX250 2T
Yep, that's what happened to me. Now I have a backup coil, which isn't a bad thing. Fortunately they're not expensive. My HT side seemed to be out of spec, but it still worked.
Bron-Yr-Aur Garage
Bron-Yr-Aur is offline
post #8 of 8 (permalink) Old 11-16-2012, 12:09 PM
mikeinva's Avatar
Everyone that has one of these bikes and wants to keep it should buy cheap used spare parts.They will keep you from chaseing your tail when things go wrong.If I go on a long trip i carry a extra coil and igniter with me,they dont take up much room and it far better then being on the side the road dead.
PVL Coil Resistance Specs? Beemie Classic, Vintage & Veteran 12 07-11-2012 11:12 PM
Carbed Twin Ignition specs. alfacliff Air Cooled Twins Technical Talk 7 06-21-2012 08:18 AM
ignition coil? jsprinter Sprint Forum 4 06-04-2012 08:15 PM
New pick-up coil, ignition coil, & ignitor. No Dice... Flyhalf_Keith Air Cooled Twins Technical Talk 22 04-18-2010 03:19 PM
bad ignition coil Hinckley Classic Triples 4 02-15-2004 12:11 PM
