T120 headlight on 2012 bonnie - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 8 (permalink) Old 11-12-2012, 07:00 PM Thread Starter
Main Motorcycle: 2012 base bonneville
Other Motorcycle: 2013 victory hammer
lookin at the original style t-120 bonneville at british bike bits, same place my beautiful DS003 seat came from, anyone fit one or can give fitment details would be appreciated, it has the toggle switch on top for on-off and some idiot lights, better looking bullet shape IMO. thanks
rodhotter is offline
post #2 of 8 (permalink) Old 11-13-2012, 12:31 PM
Main Motorcycle: 2004 T100 Black
sayonora's Avatar
Other Motorcycle: '55 royal enfield bullet
Extra Motorcycle: N/A
uhm make sure you got a H2 lamp, so you can install halogen (unless you want dim light),
you will need to get the idiot lights for that headlamp, the stock new bonneville ones wint fit, about a milimeter shy of fitting :/
also try to get one with 3 holes in the bottom, I have a 1 hole and I'm not sure I will be able to fit all the plugs, theres space enough for each one single and for all the wires together, but getting them all trough might involve dismanteling some. You will probably need new bolts, and maybe even to drill out the headlight brackets, depending on which year your bonneville is.
sayonora is offline
post #3 of 8 (permalink) Old 11-13-2012, 01:23 PM
Slinky's Avatar
Other Motorcycle: Down to my last 1
You should be able to get away with buying the shell and rim, the original reflector should fit. I found it easier to use the single wiring hole, and elongate it. It looks neater than the version with 3 wiring holes.
I also got the plain shell, without idiot lights and switch.
'98 Thunderbird
Slinky is offline
post #4 of 8 (permalink) Old 11-13-2012, 05:56 PM
sayonora's Avatar
how did you elongate it? I'd like to not have to change my shell
sayonora is offline
post #5 of 8 (permalink) Old 11-14-2012, 01:34 PM
Slinky's Avatar
I used a hacksaw blade, then a dremel to keep a rounded shape at the top. The grommet will no longer fit, so I used a piece of thin rubber channel held in place with silicone to cover the sharp edge and protect against corrosion. It only really need to be just big enough to pass the connectors through.
'98 Thunderbird
Slinky is offline
post #6 of 8 (permalink) Old 11-14-2012, 07:01 PM Thread Starter
thanks guys, the only other side mount i see is 5 3/4" i would like to stay with a 7" headlight, is that the size of the t120 light and where did you get a bucket and rim without cutouts for idiot lights thanks again
post #7 of 8 (permalink) Old 11-15-2012, 03:14 PM
Slinky's Avatar
The T120 would have been a 7" light- but the parts are generic, fitted to lots of old Brit bikes. You are looking for a 7" Lucas pattern bucket and rim. Like this, but this one has 3 wiring entry holes and it's in the UK. You also get various permutations of holes in the top (or none at all..)
http://www.ebay.co.uk/itm/99-7098-LU...item3f1c0f9b46
'98 Thunderbird
Slinky is offline
post #8 of 8 (permalink) Old 11-16-2012, 02:16 PM Thread Starter
thanks! just what i am lookin for
2012 to 2011 style round headlight conversion ajfriedm Street Triple Forum 51 11-21-2014 11:39 AM
2012 Bonnie T100 or 2006 Bonnie black Cotton7 Air Cooled Twins Talk 19 04-06-2012 11:27 AM
Question on 69 T120 Bonnie The Big Bobber Classic, Vintage & Veteran 15 05-02-2008 04:28 PM
US spec T120 Bonnie for sale TJRCARRILLO Classic, Vintage & Veteran 5 01-03-2007 06:22 PM
