Thruxton 900 Gear Change Issues - Page 7 - Triumph Forum: Triumph Rat Motorcycle Forums
post #61 of 121 (permalink) Old 12-02-2012, 02:55 PM
sprouty115's Avatar
Check the loom just below the front rubber tank supports. When the tank is rotated up to be removed the flanges can cut into the harness.
- Stephen
sprouty115 is offline
post #62 of 121 (permalink) Old 12-02-2012, 05:18 PM Thread Starter
Main Motorcycle: 2012 EFI Thruxton 900
Hotboppincat's Avatar
Other Motorcycle: Honda CBF 125 2011
I had a good look round, no loose wiring connections obvious, if you flex the loom between the tank and the headlight it cuts out. It's gotta be a cracked wire.
I've had it 3 or 4 times over my lifetime with other bikes. I suspect thats what it is.
I have had the engine management light up too.
I can't touch anything or I will void the warranty!
Statistically, 6 out of 7 Dwarfs are not Happy.
Hotboppincat is offline
post #63 of 121 (permalink) Old 12-02-2012, 05:20 PM Thread Starter
Theres no cuts obvious into the wiring, but the wrapping is nicked just where it rubs on the tank.......It's been stressed there.
Suspicious???
I think so!
post #64 of 121 (permalink) Old 12-02-2012, 05:56 PM
sprouty115's Avatar
Suspicious???
I think so!
I know what you mean, because here is what I found today when I pulled my tank to yank the AI pump:
- Stephen
post #65 of 121 (permalink) Old 12-03-2012, 07:06 AM
Main Motorcycle: Thruxton 04
Other Motorcycle: Ariel VHA Special
Extra Motorcycle: Honda Pan European ST1300
I know it sounds daft, you say wires to the headlight have you eliminated the cables to the ignition switch and the cable to the left hand switchgear & clutch switch......We are all trying!!!!!
T.U.D.
tonupdave is offline
post #66 of 121 (permalink) Old 12-04-2012, 01:22 AM Thread Starter
I had emailed the sales guy I deal with at the dealership, the dealer came and got the bike yesterday morning, and called me at close of play yesterday to inform me they had found a loose connector block under the tank. They are delivering it back to me today, but I won't be able to look at it till tonight. Will keep you posted.
Trouble is Guys, I am not willing to start stripping things apart to investigate, it's under 2 months old and also under warranty. They can have all the hassle, not me!
Lets hope it is fixed.
post #67 of 121 (permalink) Old 12-04-2012, 01:25 AM Thread Starter
T.U.D.
What I meant to say was the loom adjacent to the petrol tank near to the headstock.....that was the bit of the loom that caused it to cut out if you wiggled it. I'm not sure where all the wires went, I didn't unwrap it! The dealer took all that on board, but then said it was a connector block.
post #68 of 121 (permalink) Old 12-04-2012, 07:16 AM
Perhaps now many miles of untroubled riding .........Fingers crossed
T.U.D.
post #69 of 121 (permalink) Old 12-04-2012, 07:35 AM
Main Motorcycle: Thruxton R
Other Motorcycle: Honda CB750 K0
Extra Motorcycle: Honda CBX 750f cafe
Good luck. You deserve it.
Timinoz is offline
post #70 of 121 (permalink) Old 12-04-2012, 08:31 AM Thread Starter
Just got in from work, unwrapped her, fired her up and the problem seems to have been fixed.
Perhaps it was just a loose block!
I will leave it a bit and then go and take her out for a jolly sound thrashing!
Bwoar Har Har Har Har!!!
First oil change, gear change still clunky M2MG Speed Triple Forum 21 09-27-2012 01:01 AM
Thruxton Rarsets Gear Change Lever, fix or fail? Thornton Melon Air Cooled Twins Technical Talk 2 05-15-2012 12:43 AM
Daytona 600 gear Change 4th to 5th gear Housedog Triumph SuperSports 5 06-01-2011 03:53 PM
Gear change lever hitting exhaust on Thruxton w/ bonnie headers jlearman Air Cooled Twins Talk 22 06-01-2010 02:04 PM
Second gear issues itcha Air Cooled Twins Technical Talk 7 11-21-2007 08:34 PM
