Thumbs down for Rotella T6 - Page 6 - Triumph Forum: Triumph Rat Motorcycle Forums
post #51 of 72 (permalink) Old 11-16-2012, 12:56 PM
Main Motorcycle: 03 T100
mikeinva's Avatar
Originally Posted by Sayantsi View Post
Fwiw, the Rotella oils have all passed JASO specs and some are actually certified. No reason to call them diesel oils - all oils are basically the same but for the additives put in them. There's nothing extra special about motorcycle additives to justify the price hikes for motorcycle-branded oil other than the fact that oil companies can get away with it.
One thing to remember in general, any multi-weight oil is basically a lighter weight oil "buffed" to make the heavier weight viscosity when hot. A 5w-40 may just be too thin a 40 weight while a 15W-40 is not. Either way, if I was going to put Rotella into a bike, I'd put the 15W-40 in.
One think I like about the "old" style oils though is that the formulations still focus on engine protection, and not a compromise between protection and mpg.
THAT IS TRUE.What will work in these bikes has more to do with whats not in the oil then whats in it.Car oil with friction aditives does not work good with our clutches (tends to make them slip.As far as the trans goes any oil would work ok there is nothing new to them dino oil would do a good job in the trans.The trans is not a high wear item on these bikes.I would say any shift troubles that happen with oil will be clutch related.The trans on these bikes works better after it is worn in good because they have ruff spots when new that have to wear in.
mikeinva is online now
post #52 of 72 (permalink) Old 11-16-2012, 12:57 PM
Supernova
Extra Motorcycle: '14 Triumph Thruxton 900
I'll hook all three of you up behind my 747! Now what?
Sometimes you just have to go out to the beaver dam with a machete and start chopping wood
leftarmlogan is offline
post #53 of 72 (permalink) Old 11-16-2012, 05:11 PM
mikeinva's Avatar
Then I will have to nuc your 747 with my B52.Now what lol?
post #54 of 72 (permalink) Old 11-16-2012, 09:54 PM
Main Motorcycle: '07 Black
Easy13's Avatar
Not to start the whole thing over again, but I misspoke in my post way back on page one: I was using Rotella T 15w40 and the bike shifted poorly. Using Mobil 1/Castrol makes for a much happier Bonneville.
And for the record, no stock Tiger wants anything to do with Mikes Bonne. If you aint on a 1050 Sprint, just stay on the porch and watch the show.
"Cognito Ergo Wrenchum"
Easy13 is offline
post #55 of 72 (permalink) Old 11-16-2012, 10:57 PM
357Bob's Avatar
I forgot what the question was. Why not just get some good old Castrol 20W50 regular oil & keep it changed? I got away from the synthetic 20,000 miles ago. I ride a real bike & it needs real oil. Didn't notice a thing except the extra money. Now I can go buy a holster for Oklahomas new open carry law. Also heard OKC was losing it's Triumph Dealer. I'll be riding an orphan.
357Bob
357Bob is online now
post #56 of 72 (permalink) Old 11-16-2012, 11:12 PM
I have to say I have used rotella T6 and was a believer then tried motul 7100 single ester, there is quite a difference as shifting is way smoother . Next try will be amsoil 20-50 as I already bought two one gallon containers
doger5 is offline
post #57 of 72 (permalink) Old 11-16-2012, 11:13 PM
357Bob's Avatar
Like I said.
357Bob
post #58 of 72 (permalink) Old 11-16-2012, 11:57 PM
DrX
Main Motorcycle: 2008 bonneville black
DrX's Avatar
Originally Posted by Askari View Post
Me i will stick with Triumph and Forchettos reccomendations.
Same here!!
DrX is offline
post #59 of 72 (permalink) Old 11-17-2012, 12:37 AM
Askari's Avatar
No worries!
Just land your plane in my back paddock, bit rough lots a trees and we are on. I ll supply barbie and first aid!
Askari is offline
post #60 of 72 (permalink) Old 11-17-2012, 01:29 AM
Askari's Avatar
Jaso
JASO is like SAE just a standard i would suggest that you steer away from JASO FC as that is for twostroke engines.
As i stated rotella is a commercial vehicle oil. You may well be able to use it in 2 stroke m/cycles as it is only going to be for the gearbox.
Totally agree that oil is oil, but using a non compatible one can drastically affect an engine.
Some "diesel oils" are multi purpose engine, gearbox, hydraulics and brakes (tractors etc). Pretty sure that the "brakes" compatible would have no no effect on clutch slippage, not sure ill chnage though!
Rotella is not 1 oil but a whole product line. Within the line you get monograde product as well. Suggest that anyone deciding to use the product researchs well and maybe contact Shell to protect there pride and joy.
Askari is offline
Anybody using Rotella T6 robertrichhart Thunderbird Twin - Technical Talk 8 10-09-2012 02:48 PM
rotella t6 oil warped929RR Speed Triple Forum 21 07-08-2012 03:25 AM
Rotella T and my Bonnie..... kliff Air Cooled Twins Talk 7 03-21-2007 12:55 AM
Thumbs Up..or..Thumbs Down; Need Feedback Shorty Air Cooled Twins Technical Talk 13 07-14-2006 09:01 AM
Rotella 5-40T synthetic Ramsey1200 Trophy 24 04-12-2005 06:58 PM
