I don't deny the good experiences that many of you have had with this oil in your bikes, but for my '01 Bonnie, Rotella T6 has not been a winner.
My shifting quality has become tougher and notchier with the Rotella over the Mobil synthetic that was in it before.
It's cheap and it works, but the fact is is that it doesn't work well for MY bike.
I will be switching back to Mobil 1 v-twin synthetic or trying Motul 5100 in 2000 miles. I might even try draining a quart or so of the Rotella and throwing in a quart of the Mobil or Motul to see if that helps.
I don't think it would be a good idea to mix different oils. I had a similar situation with another motorcycle and the oil actually looked like it was globbing up. I quickly changed the oil out and replaced it with what was recommended by the manual.........The bike loved it and I had no more problems ! The Meister
I've noticed the clutching action is worse as well. I dunno if it's a "sticking" but I've noticed that I need alot of clutch slip to get the bike moving from stopped.
The Shell Rotella T6 does not meet the requirements for our motorcycles.
Why would anyone who has spent thousands of dollars on the purchase of their Triumph want to save a few dollars to run an oil that does not meet the manufacturer's requirements ? And chance doing damage to the motor/trans. Or than complain about the poor performance of the product not designed for the application.
Found it cheap on amazon: [ame]http://www.amazon.com/Castrol-06412-10W-50-4-Stroke-Motorcycle/dp/B008MISF54/ref=sr_1_3?s=automotive&ie=UTF8&qid=1352818124&sr=1-3&keywords=castrol+power+rs[/ame]
I do not understand why some guys will spend between 7-9 thousand dollars for their Triumph, then want to put in 5 dollar a quart oil. Yes, Mobil racing 4T synthetic is expensive. It also works great in the Bonneville. I use the Mobil 4t syn and a Triumph factory oil filter exclusively for my beloved Bonneville. On a side note, my carburator Bonneville also LOVES non ethanol gas. It is worth it to use both of those products in my bike.
At least for Florida, I would think 5w-40 would be at the light end of the acceptable viscosity range for the bike. I run 15w-50 and shifting is very smooth with no clutch issues. In any case, I don't think a 5w-40 is going to make a clutch slip- there's more going on if that happens- but it could affect shifting smoothness.
I've used Rotella T6 in several bikes, including my 2012 T100. I've not noticed any issues with shifting in any of the bikes, including Honda VTX 1800, Shadow Sabre 1100, V-Strom, Kawasaki ER-6n.
This oil seems to be the oil of choice at the V-Strom forum.
Could there be something specific about Triumphs that doesn't agree with Rotella T6? I put just over 2000 miles on my 2012 T100, with about 1500 using the Rotella T6. As I mentioned, shifting seems to be very smooth.
It doesn't seem to meet the Factory specs, clearly stated in the handbook, either in viscosity or classification. It's also an "energy saving" oil which has been known to interfere with wet clutches.
Why not just stick to the Factory recommendations?, I quote:
"...semi or fully synthetic 10W/40 or 15W/50 motorcycle engine oil which meets specification API SH or higher (i.e. SJ, SK or SL) AND JASO MA..."
I maybe wrong but I think there is more then 1 type of Rotella and you maybe useing the wrong type. I have used alot of brands of oil in these bikes over the years.I dont think any oil will make them shift better.But temp can change the way they shift If it has cooled off where you are lately that can and will make them harder to shift.
Yes it does. T6 is JASO-MA rated. It shifts just fine in my 865/270, although in hot weather the oil temp runs a bit hotter with 5/40 T6 than it does with Mobil-1 15/50
The stuff works great in 1050 engines and IS rated for use in motorcycles with a jaso rating. Im thinking it has something to do with the sloppier tolerances of the p twin tractor motor needing thicker oil.
OIL is the cheapest form of insurance to keep the engine in good shape. Go ahead and put the cheap stuff in, save a few pennies, cents, centimes, and then shell out some really BIG POUNDS, DOLLARS,FRANCS; when you replace all the parts later. Don't start WHINING about your bikes longevity because it'll definitely WHINE when its gears and bearings get fed cheap oil.
As already stated, "unless its built to the hilt". Sad part is that it would take that much money and alteration to just barely beat a stock bike. That leaves ME and my crankcase full of cheap oil with the last laugh.
Let me have the last word here: stop putting down other people's bikes period.
What's the point? We all love our bikes for very specific and unquantifiable reasons so it doesn't make sense to play e-wang "ima tell you what's what" armchair racing on the internet.
Settle it on a dragstrip, and keep it yourselves. :highfive
Related Threads
Triumph Rat Motorcycle Forums
3.9M posts
167.7K members
Since 2002
